Updated on 2026-01-09 GMT+08:00
Creating a User and Granting BCS Permissions
This section describes how to use IAM to implement fine-grained permissions control for your BCS resources. With IAM, you can:
  • Create IAM users for employees based on your enterprise's organizational structure. Each IAM user will have their own security credentials for accessing BCS resources.
  • Grant only the permissions required for users to perform a specific task.
  • Entrust a Huawei Cloud account or a cloud service to perform professional and efficient O&M on your BCS resources.
If your Huawei Cloud account does not require individual IAM users, skip this section.
This section describes the procedure for granting permissions (see Figure 1).
Learn about the permissions (see Permissions Management) supported by BCS and choose policies or roles according to your requirements. For the permissions of other services, see System-defined Policies/Roles.
  • If you select BCS Administrator, you also need to select the following dependent permissions: Tenant Guest, Server Administrator, ELB Administrator, SFS Administrator, SWR Admin, APM FullAccess, AOM FullAccess, CCE Administrator, VPC Administrator, EVS Administrator, and CCE Cluster Admin.
  • Contact the account administrator to obtain the operation permissions on other services.
Process Flow
Figure 1 Process of granting BCS permissions
  1. Create a user group and assign permissions to it.
    Create a user group on the IAM console, and assign the BCS Administrator policy to the group.
  2. Create a user and add the user to the user group.
    Create a user on the IAM console and add the user to the group created in 1.
  3. Log in and verify permissions.
    Log in to the BCS console as the created user, and verify that the user has the BCS operating permissions.
