Updated on 2026-01-09 GMT+08:00
Creating a Custom Policy
Custom policies can be created to supplement the system-defined policies of BCS.
You can create custom policies in either of the following ways:
  • Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
  • JSON: Edit policies from scratch or based on an existing policy in JSON format.
For details, see Creating a Custom Policy. The following section contains examples of common BCS custom policies.
  1. On the management console homepage, click Identity and Access Management.
  2. In the navigation pane, choose Permissions > Policies/Roles and click Create Custom Policy.
  3. On the Create Custom Policy page, set the policy name, view, content, and description, then click OK.
    • Policy Name: Enter a custom policy name, for example, "partial BCS permissions".
    • Policy View: Select JSON.
    • Policy Content: Enter the policy content based on the template.
      For example, use the following content to query instances and channels and create channels.
          "Version": "1.1",
          "Statement": [
                  "Effect": "Allow",
                  "Action": [
                      "bcs:fabricInstance:getDetail",
                      "bcs:fabricChannel:create",
      	        "bcs:fabricChannel:list"
      Table 1 Policy content parameters
      Setting
      Version
      Policy version
      Fixed to 1.1.
      Statement
      Effect
      Whether the actions are allowed
      • Allow
      • Deny
      Action
      Operations to be performed on BCS
      Each action name is in the format of Service name:Resource type:Operation and cannot be customized. Table 2 lists the fine-grained permissions supported by BCS. After you set any action, the permissions for the action will be granted to the IAM user.
      Table 2 Action description
      Action
      Action Description
      bcs:fabricInstance:listQuota
      Querying quotas
      bcs:fabricInstance:getFlavor
      Querying Flavors
      bcs:fabricInstance:listRecord
      Querying Asynchronous Operation Results
      bcs:fabricInstance:createOnDemand
      Creating a BCS Service
      Querying the BCS Service List
      bcs:fabricInstance:getStatus
      Querying Creation Status of a BCS Service
      Querying Service Information
      bcs:fabricInstance:getNodes
      Querying Peer Information
      bcs:fabricInstance:update
      Modifying a BCS Service
      bcs:fabricInstance:delete
      Deleting Service Instances
      bcs:fabricInstance:downloadCert
      Downloading Certificates
      bcs:fabricInstance:downloadSdkCfg
      Downloading the SDK Configuration
      bcs:fabricInstance:createUserCert
      Generating a User Certificate
      bcs:fabricInstance:freezeUserCert
      Freezing a User Certificate
      bcs:fabricInstance:unfreezeUserCert
      Unfreezing a User Certificate
      bcs:fabricInstance:listInstanceMetric
      Querying BCS Monitoring Data
      bcs:fabricInstance:listOrgMetric
      Listing Entity Monitoring Data of a BCS Service
      bcs:fabricInstance:getOrgMetric
      Querying the Number of Monitored BCS Organization Instances
      Creating a Channel
      Querying Channel Information
      bcs:fabricChannel:addPeer
      Adding Peers to a Channel
      bcs:fabricChannel:removePeer
      Removing a Peer from a Channel
      bcs:fabricChannel:removeOrg
      Removing Organizations from a Channel
      bcs:fabricChannel:delete
      Deleting a Channel
      bcs:fabricMember:createInvitation
      Inviting Tenants to Join a Consortium
      bcs:fabricMember:deleteInvitation
      Deleting Invitation Information
      bcs:fabricMember:list
      Listing Consortium Members
      bcs:fabricMember:quit
      Exiting a Consortium
      bcs:fabricNotification:list
      Querying All Notifications
      bcs:fabricNotification:handle
      Processing an Invitation
