هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Help Center/
Cloud Operations Center/
User Guide/
Faults/
Improvement Management/
Create improvement tickets using incidents, war rooms, drills, and PRRs.
Handling Improvement Tickets
- Log in to COC.
- In the navigation pane on the left, choose Fault Management > Improvement Tickets. On the displayed page, click the Pending tab and click an improvement ticket name to go to the improvement ticket details page.
Figure 1 Improvement ticket list
- Click Process or Forward in the upper right corner.
Figure 2 Improvement ticket details
Improvement Ticket Verification
- Log in to COC.
- In the navigation pane on the left, choose Fault Management > Improvement Tickets. On the displayed page, click the Pending tab and click an improvement ticket that is in the state of waiting for validation to go to the improvement ticket details page.
Figure 3 Improvement ticket list
- Click Validate in the upper right corner and enter the validation conclusion.
Figure 4 Improvement ticket validation
Improvement Ticket History
- Log in to COC.
- On the improvement ticket details page, click the Improvement History tab to view the improvement history.
Figure 5 Improvement ticket history
Parent topic: Improvement Management
