هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Managing Tags
You can add tags to user-defined jobs and service tickets.
Add tags to a user-defined job or job ticket on COC.
Adding a Tag
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. In the Routine O&M area, click Jobs.
- On the Job Management page, click the Custom Jobs tab, locate the job to be executed, and click Execute in the Operation column.
- In the Basic Information area, click +Add and enter the tag key and value.
- Click the deletion icon on the right of the added tag to delete the tag.
Figure 1 Adding a tag
Editing a Tag
- Log in to COC.
- On the Job Management page, click the Custom Jobs tab, click
in the job list, and click Edit.
- Modify the tag by referring to the steps for adding a tag, and click OK.
Figure 2 Editing a tag
Parent topic: Jobs
