هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Patch Management/
Automatic Patch Operations
You can create automatic tasks for patch scanning or patch repair.
Create automatic patch tasks on COC.
- Log in to COC.
- In the navigation pane, choose Resource O&M > Automation > Patch Management. On the displayed page, click Click here in the upper part of the page to configure an automation task.
Figure 1 Learn more
- Set automation execution parameters and click OK.
The automatic patch task will be performed periodically on all Linux ECSs where agents are running properly in your selected region. Ensure you understand the impact scope of the task.
Figure 2 Scheduled task parameters - Click OsPatchAutomaticScanning or OsPatchAutomaticRepair in the upper part of the page to view or modify the task.
Figure 3 Completing configurationFigure 4 Viewing the scheduled O&M task
Parent topic: Patch Management
