Updated on 2026-09-30 GMT+08:00
Managing Cross-Account Resources
COC provides secure and reliable cross-account data aggregation and resource O&M capabilities. If your account is an enterprise account and is an administrator registered in the Organizations service or a delegated administrator of the COC service, you can manage resources of other accounts in the organization in a unified manner. In addition, you can view and manage all resources in the organization on the COC console.
A view consists of a group of filters. You can configure the filter criteria to access desired resources on Huawei Cloud in cross-account scenarios.
To create a view, you can set the basic view information and configure filter criteria such as organization unit and resource type.
Figure 1 Creating a view
Precautions
Creating a View
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Cross-Account Resources and click View Management.
    Figure 2 View management
  4. On the view management page, click Create View.
  5. Set basic view information based on Table 1.
    Figure 3 Setting basic information
    Table 1 Parameters for creating a view
    Name
    Customize a view name based on the naming rule.
    The view name can contain 3 to 50 characters, including letters, digits, hyphens (-), and underscores (_).
    Select Organization
    Select the target organizational units.
    An OU is a container of accounts. You can group accounts into an OU and apply policies to the OU based on your business requirements.
  6. Click Next. The page for selecting resources is displayed.
  7. Select the resource types that need to be managed across accounts.
    Figure 4 Selecting resources
  8. Click OK. The view is created.
  9. After synchronizing resources, you can view the resource information of the corresponding view in the resource list.
    Cross-account resources under management may only be centrally viewed and managed and cannot be directly invoked using the automated O&M capability.
    Figure 5 Viewing cross-account resources
Modifying a View
  1. Log in to COC.
    Figure 6 View management
  4. Locate the row that contains the view you want to modify and click Modify in the Operation column.
  5. Modify the view by referring to Table 2.
    Table 2 Parameters for modifying a view
    Name
    Select Organization
    Select Resource
    Select the target resource type.
  6. After confirming that the information is correct, click OK. The view is modified.
    After the view is modified, you need to manually synchronize resources again.
Deleting a View
  1. Log in to COC.
    Figure 7 View management
  4. Locate the view you want to delete and click Delete in the Operation column.
  5. In the displayed dialog box, click OK. The view is deleted.
    After the view is deleted, it will no longer be displayed in the view list.
