هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Application and Resource Management/
Multi-cloud Configurations/
Importing On-premises IDC
You can import on-premises IDCs.
Import on-premises IDCs on COC.
- Log in to COC.
- On the Multi-cloud Configurations page, click On-premises IDCs.
Figure 1 Importing on-premises IDCs
- Click download template and complete the downloaded template.
Figure 2 Entering information in an Excel file
- Click Add File to add the completed excel file.
- Click
in the upper left corner to return to the Resources tab page. You can view the imported on-premises IDC resource information.
Figure 3 On-premises IDCs
Parent topic: Multi-cloud Configurations
