- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Application and Resource Management/
Multi-cloud Configurations/
Modifying On-premises IDC Information
You can modify on-premises IDC information.
Modify on-premises IDC information on COC.
- Log in to COC.
- In the navigation pane on the left, choose Resources > Application and Resource Management. On the displayed Resources tab page, click IDC, locate the target IDC record, and click Modify in the Operation column.
Figure 1 Modifying on-premises IDC records
- Modify the on-premises IDC resource information based on Table 1, and click OK.
Table 1 On-premises IDC information parameters Parameter
Example Value
Device Name
Device name, which is mandatory.
Test device
Device SN
Device SN, which is mandatory.
Internal IP
Internal IP address, which is mandatory.
192.168.1.1
Device type
Device type, which is mandatory.
Device Vendor
Device vendor, which is mandatory.
OS
Operating system (LINUX or WINDOWS), which is mandatory.
LINUX
Description, which is optional.
Parent topic: Multi-cloud Configurations
