Help Center/ Cloud Operations Center/ User Guide/ Application Management/ Manually Associating Resources with an Application
Updated on 2025-08-08 GMT+08:00
After creating an environment for a group, you can bind resources to this environment. Then, you can monitor the resource usage in real time through application monitoring.
Constraints and Limitations
In Elastic Load Balance (ELB), a listener is automatically associated with a load balancer. Manual association is not supported.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Applications in the upper left corner.
  4. In the application list on the left, select the application to be associated with resources and click Associate with Resource.
    Figure 1 Manually associating resources with an application
  5. Set parameters for associating resources with an application.
    Table 1 Parameters for associating resources with an application
    Example Value
    Select a group under the application
    Select an application, component, and group from the drop-down list.
    Test application/test component/test group
    Resource Type
    Select a cloud vendor and resource type from the drop-down lists.
    Huawei Cloud/Elastic Cloud Server (ECS)/Cloud Server
    Resource List
    Please select the resources that need to be associated.
  6. Click OK.
    Resources are associated with the group.
