Viewing Resource Monitoring Metrics in the Resource Monitoring Module
During routine cloud resource management, you need to monitor the usage of various resources to ensure stable service running. However, when you try to monitor these resources in the traditional way, you may find that the data is scattered and difficult to summarize. As a result, all monitoring metrics cannot be quickly obtained. How do you solve this problem and ensure that you can efficiently manage cloud resources? On the resource monitoring module, you can quickly view metrics of purchased resources (such as ECSs, OBS, and cloud databases), such as the ECS CPU usage, disk read/write bandwidth, total number of OBS objects, and TPS. In this way, the resource usage can be monitored in all aspects.
Resource Monitoring
- Log in to COC.
- On the COC overview page, locate the resource monitoring module, and view the resource monitoring information. This module displays monitoring metrics on Cloud Eye.Figure 1 Cloud Eye monitoring information
- Click the drop-down list in the upper right corner to switch the cloud service type you want to view. Figure 2 Switching between cloud services
- Click Configure in the upper right corner to customize the monitoring metrics to be displayed. Figure 3 Editing metrics
- Click More in the upper right corner to go to the Cloud Eye host monitoring or cloud service monitoring page and view the original information.
For details about more monitoring metrics, see Introduction to Server Monitoring and Viewing a Cloud Service Dashboard.
