هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Resource Overview
You can view statistics about purchased resources, including ECSs, EIPs, and cloud databases.
View resources (including ECSs, EIPs, and cloud databases) on COC.
- Log in to COC.
- On the Overview page of COC, you can view required resource information.
Figure 1 Resource information
- Enable the Global View feature toggle to view resource information of all regions.
- Click
to query all resource information of the corresponding resource type.
- In the global view, click
to query all resource information of the corresponding resource type in different regions.
Figure 2 Resources in different regions - Move your cursor to resources that are marked by alarms to view alarm details of the resources.
Figure 3 Alarm information
- Click View More to view more alarms.
Figure 4 More alarm information
- Click the refresh icon in the upper right corner of this area to refresh resource and alarm information.
Parent topic: Overview
