Annotations for Configuring LoadBalancer Ingresses
You can add annotations to a YAML file for more advanced ingress functions. This section describes the annotations that can be used when you create a LoadBalancer ingress.
Indexes
Category |
Ingress Annotation |
Load balancer configuration |
Port or protocol configuration |
Advanced features of ELB listeners |
In a cluster, multiple ingresses can share a listener, allowing them to use the same port on a single load balancer. If two ingresses have different listener configurations, the listener configuration of the earlier ingress (known as the first route) will be used.
This case involves the following scenarios:
Ensure that the configurations of different listeners for various ingresses are synchronized.
Basic Configurations for Interconnecting with ELB
- Associate an existing load balancer. For details, see Associating an Existing Load Balancer to an Ingress While Creating the Ingress.
- Automatically create a load balancer. For details, see Automatically Creating a Load Balancer While Creating an Ingress.
Parameter |
Type |
Description |
Supported Cluster Version |
kubernetes.io/elb.class |
String |
Select a proper load balancer type.
v1.9 or later |
kubernetes.io/ingress.class |
String |
This parameter is mandatory when an ingress is created by calling the API. For clusters of v1.23 or later, use the parameter ingressClassName. For details, see Creating a LoadBalancer Ingress Using kubectl. |
Only clusters of v1.21 or earlier |
kubernetes.io/elb.port |
String |
This parameter indicates the external port registered with the address of the LoadBalancer Service. The value ranges from 1 to 65535. The default value is 80 for HTTP and 443 for HTTPS.
Some ports on a shared load balancer are highly risky and blocked by default, for example, port 21. |
v1.9 or later |
kubernetes.io/elb.id |
String |
When associating only existing load balancers, you can use either this parameter or kubernetes.io/elb.ip. If they conflict, kubernetes.io/elb.id will take precedence. This parameter indicates the ID of a load balancer. How to obtain: On the management console, click Service List, and choose Networking > Elastic Load Balance. Click the name of the target load balancer. On the Summary tab page, find and copy the ID. |
v1.9 or later |
kubernetes.io/elb.ip |
String |
When associating only existing load balancers, you can use either this parameter or kubernetes.io/elb.id. If they conflict, kubernetes.io/elb.id will take precedence. This parameter indicates the service address of a load balancer. The value can be the public IP address of a public network load balancer or the private IP address of a private network load balancer. |
v1.9 or later |
kubernetes.io/elb.autocreate |
Table 13 object |
Mandatory when load balancers are automatically created. Example
v1.9 or later |
kubernetes.io/elb.enterpriseID |
String |
Optional when load balancers are automatically created. Clusters of v1.15 and later versions support this field. In clusters earlier than v1.15, load balancers are created in the default project by default. This parameter indicates the ID of the enterprise project in which the ELB load balancer will be created. If this parameter is not specified or is set to 0, resources will be bound to the default enterprise project. How to obtain: Log in to the management console and choose Enterprise > Project Management on the top menu bar. In the list displayed, click the name of the target enterprise project, and copy the ID on the enterprise project details page. |
v1.15 or later |
kubernetes.io/elb.subnet-id |
String |
Optional when load balancers are automatically created. ID of the subnet where the cluster is located. The value can contain 1 to 100 characters.
Mandatory for clusters of a version earlier than v1.11.7-r0 Discarded in clusters of a version later than v1.11.7-r0 |
Configuring ELB Certificates
For details about application scenarios and use cases, see Configuring an HTTPS Certificate for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.tls-certificate-ids |
String |
ELB certificate IDs, which are separated by comma (,). The list length is greater than or equal to 1. The first ID in the list is the server certificate, and the other IDs are SNI certificates in which a domain name must be contained. To obtain the certificate, log in to the CCE console, choose Service List > Networking > Elastic Load Balance, and click Certificates in the navigation pane. In the load balancer list, copy the ID under the target certificate name. |
v1.19.16-r2, v1.21.5-r0, v1.23.3-r0, or later |
kubernetes.io/elb.tls-ciphers-policy |
String |
The default value is tls-1-2, which is the default security policy used by the listener and takes effect only when HTTPS is used. Options:
For details of cipher suites for each security policy, see Table 3. |
Clusters of v1.17.17 or later |
kubernetes.io/elb.security_policy_id |
String |
The ID of the custom security group policy on ELB. Obtain it on the ELB console. This field takes effect only when HTTPS is used and has a higher priority than the default security policy. |
Adding Resource Tags
For details about application scenarios and use cases, see Automatically Creating a Load Balancer While Creating an Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.tags |
String |
Add resource tags to a load balancer. This parameter can be configured only when a load balancer is automatically created. A tag is in the format of "key=value". Use commas (,) to separate multiple tags. |
v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later |
Using HTTP/2
For details about application scenarios and use cases, see Configuring HTTP/2 for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.http2-enable |
String |
Whether HTTP/2 is enabled. Request forwarding using HTTP/2 improves the access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server. Options:
Note: HTTP/2 can be enabled or disabled only when the listener uses HTTPS. This parameter is invalid and defaults to false when the listener protocol is HTTP. |
v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later |
Interconnecting with HTTPS Backend Services
For details about application scenarios and use cases, see Configuring HTTPS Backend Services for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.pool-protocol |
String |
To interconnect with HTTPS backend services, set this parameter to https. |
v1.23.8, v1.25.3, or later |
Configuring Timeout for an Ingress
For details about application scenarios and use cases, see Configuring Timeout for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.keepalive_timeout |
String |
Timeout for client connections. If there are no requests reaching the load balancer during the timeout duration, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request. The value ranges from 0 to 4000 (in seconds). The default value is 60. |
Dedicated load balancers: v1.19.16-r30, v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, or later Shared load balancers: v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later |
kubernetes.io/elb.client_timeout |
String |
Timeout for waiting for a request from a client. There are two cases:
The value ranges from 1 to 300 (in seconds). The default value is 60. |
kubernetes.io/elb.member_timeout |
String |
Timeout for waiting for a response from a backend server. After a request is forwarded to the backend server, if the backend server does not respond within the duration specified by member_timeout, the load balancer will stop waiting and return HTTP 504 Gateway Timeout. The value ranges from 1 to 300 (in seconds). The default value is 60. |
Configuring a Slow Start
For details about application scenarios and use cases, see Configuring a Slow Start for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.slowstart |
String |
Duration of slow start, in seconds. The slow start duration ranges from 30 to 1200.
The load balancer linearly increases the proportion of requests to backend servers in slow start mode. When the configured slow start duration elapses, the load balancer sends full share of requests to backend servers and exits the slow start mode. |
v1.23 or later |
Configuring a Range of Listening Ports
A custom listening port can be configured for an ingress. In this way, both ports 80 and 443 can be exposed.
For details about application scenarios and use cases, see Configuring a Range of Listening Ports for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.listen-ports |
String |
Create multiple listening ports for an ingress. The port number ranges from 1 to 65535. The following is an example for JSON characters: kubernetes.io/elb.listen-ports: '[{"HTTP":80},{"HTTPS":443}]'
v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later |
Configuring the Priorities of Forwarding Rules
When ingresses use the same load balancer listener, forwarding rules can be prioritized based on the following rules:
- Forwarding rules of different ingresses: The rules are sorted based on the priorities (ranging from 1 to 1000) of the kubernetes.io/elb.ingress-order annotation. A smaller value indicates a higher priority.
- Forwarding rules of an ingress: If the kubernetes.io/elb.rule-priority-enabled annotation is set to true, the forwarding rules are sorted based on the sequence in which they are added during ingress creation. A forwarding rule added earlier indicates a higher priority. If the kubernetes.io/elb.rule-priority-enabled annotation is not configured, the default sorting of the forwarding rules on the load balancer will be used.
If the preceding annotations are not configured, the default sorting of the forwarding rules on the load balancer will be used, regardless of whether the forwarding rules are of the same ingress or different ingresses under the same load balancer listener.
For details about application scenarios and use cases, see Configuring the Priorities of Forwarding Rules for LoadBalancer Ingresses.
Parameter |
Type |
Description |
kubernetes.io/elb.ingress-order |
String |
Specifies the sequence of forwarding rules of different ingresses. The value ranges from 1 to 1000. A smaller value indicates a higher priority. The priority of a forwarding rule must be unique under the same load balancer listener. This parameter is available only for dedicated load balancers.
When this annotation is configured, the kubernetes.io/elb.rule-priority-enabled annotation is enabled by default. The forwarding rules of each ingress will be sorted. |
v1.23.15-r0, v1.25.10-r0, v1.27.7-r0, v1.28.5-r0, v1.29.1-r10, or later |
kubernetes.io/elb.rule-priority-enabled |
String |
This parameter can only be set to true, indicating to sort the forwarding rules of an ingress. The priorities of the forwarding rules are determined based on the sequence in which they are added during ingress creation. A forwarding rule added earlier indicates a higher priority. If this parameter is not configured, the default sorting of the forwarding rules on the load balancer will be used. After this parameter is enabled, it cannot be disabled. This parameter is available only for dedicated load balancers. |
Configuring a Custom Header Forwarding Policy
For details about application scenarios and use cases, see Configuring a Custom Header Forwarding Policy for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.headers.${svc_name} |
String |
Custom header of the Service associated with an ingress. ${svc_name} is the Service name. Format: a JSON string, for example, {"key": "test", "values": ["value1", "value2"]}
v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later |
Configuring a Custom EIP
For details about application scenarios and use cases, see Configuring a Custom EIP for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.custom-eip-id |
String |
ID of the custom EIP, which can be seen on the EIP console The EIP must be bindable. |
v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, v1.30.1-r0, or later |
Configuring Advanced Forwarding Rules
For details about application scenarios and use cases, see Configuring Advanced Forwarding Rules for a LoadBalancer Ingress.
Parameter |
Type |
Description |
kubernetes.io/elb.conditions.${svc_name} |
String |
Configure an advanced forwarding rule. ${svc_name} indicates the Service name, which can contain a maximum of 51 characters. If the annotation value is set to [], the advanced forwarding rule will be deleted. The annotation value is a JSON array. For details, see Table 2.
NOTICE:
v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, v1.30.4-r0, or later |
Parameters for Automatically Creating a Load Balancer
Parameter |
Mandatory |
Type |
Description |
name |
No |
String |
Name of the automatically created load balancer. The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed. Default: cce-lb+service.UID |
type |
No |
String |
Network type of the load balancer.
Default: inner |
bandwidth_name |
Yes for public network load balancers |
String |
Bandwidth name. The default value is cce-bandwidth-******. The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed. |
bandwidth_chargemode |
No |
String |
Bandwidth mode.
Default: bandwidth |
bandwidth_size |
Integer |
Bandwidth size. The value ranges from 1 Mbit/s to 2000 Mbit/s by default. Configure this parameter based on the bandwidth range allowed in your region.
The minimum increment for bandwidth adjustment varies depending on the bandwidth range.
bandwidth_sharetype |
String |
Bandwidth sharing mode.
eip_type |
String |
EIP type.
The specific type varies with regions. For details, see the EIP console. |
vip_subnet_cidr_id |
No |
String |
The ID of the IPv4 subnet where the load balancer resides. This subnet is used to allocate IP addresses for the load balancer to provide external services. The IPv4 subnet must belong to the cluster's VPC. If this parameter is not specified, the load balancer and the cluster will be in the same subnet by default. This field can be specified only for clusters of v1.21 or later. How to Obtain Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the IPv4 Subnet ID on the Summary tab page. |
elb_virsubnet_ids |
No |
Array of strings |
The network ID of the subnet where the load balancer is located. This subnet is used to allocate IP addresses for accessing the backend server. If this parameter is not specified, the subnet specified by vip_subnet_cidr_id will be used by default. Load balancers occupy varying numbers of subnet IP addresses based on their specifications. Do not use the subnet CIDR blocks of other resources (such as clusters or nodes) as the load balancer's CIDR block. This parameter is available only for dedicated load balancers. Example: "elb_virsubnet_ids": [ "14567f27-8ae4-42b8-ae47-9f847a4690dd" ] How to Obtain Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the Network ID on the Summary tab page. |
vip_address |
No |
String |
Private IP address of the load balancer. Only IPv4 addresses are supported. The IP address must be in the ELB CIDR block. If this parameter is not specified, an IP address will be automatically assigned from the ELB CIDR block. This parameter is available only in clusters of v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later versions. |
available_zone |
Yes |
Array of strings |
AZ where the load balancer is located. This parameter is available only for dedicated load balancers. |
l4_flavor_name |
No |
String |
Flavor name of the layer-4 load balancer. This parameter is mandatory when TCP or UDP is used.
l7_flavor_name |
No |
String |
Flavor name of the layer-7 load balancer. This parameter is mandatory when HTTP is used.
This parameter is available only for dedicated load balancers. Its value must match that of l4_flavor_name, meaning both must be either elastic specifications or fixed specifications. |
