هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
Overview
CCE provides multiple types of add-ons to extend cluster functions and meet feature requirements. You can install add-ons as required.
NOTICE:
CCE uses Helm charts to deploy add-ons. To modify or upgrade an add-on, perform operations on the Add-ons page or use open add-on management APIs. Do not directly modify resources related to add-ons in the background. Otherwise, add-on exceptions or other unexpected problems may occur.
Scheduling and Elasticity Add-ons
Add-on Name
Volcano Scheduler
This add-on is a scheduler for general-purpose, high-performance computing such as job scheduling, heterogeneous chip management, and job running management, serving end users through computing frameworks for different industries such as AI, big data, gene sequencing, and rendering.
CCE Cluster Autoscaler
This add-on resizes a cluster based on pod scheduling status and resource usage.
CCE Advanced HPA
This add-on is developed by CCE. It can be used to flexibly scale in or out Deployments based on metrics such as CPU usage and memory usage.
Cloud Native Observability Add-ons
Add-on Name
CCE Node Problem Detector
This add-on monitors abnormal events of cluster nodes and connects to a third-party monitoring platform. It is a daemon running on each node. It collects node issues from different daemons and reports them to the API server. It can run as a DaemonSet or a daemon.
CCE Network Metrics Exporter
This add-on monitors and manages container network traffic. It collects how many IPv4 packets and bytes are received and sent (including those sent to the Internet) and allows you to obtain pod labels. It supports multiple monitoring tasks, allows you to select monitoring metrics, and uses a PodSelector to select monitoring backends. The monitoring information has been adapted to Prometheus. You can call the Prometheus API to view monitoring data.
Kubernetes Metrics Server
This add-on is an aggregator for monitoring data of core cluster resources.
Prometheus
This add-on is an open-source system monitoring and alerting framework. CCE allows you to quickly install Prometheus as an add-on.
Cloud Native Heterogeneous Computing Add-ons
Add-on Name
CCE AI Suite (NVIDIA GPU)
NVIDIA GPU is a device management add-on that supports GPUs in containers. It supports only NVIDIA drivers.
Container Network Add-ons
Add-on Name
CoreDNS
CoreDNS is a DNS server that provides domain name resolution for Kubernetes clusters through a chain add-on.
NGINX Ingress Controller
This add-on forwards application data such as the data of virtual hosts, load balancers, SSL proxy, and HTTP routing for Services that can be directly accessed outside a cluster.
NodeLocal DNSCache
NodeLocal DNSCache improves cluster DNS performance by running DNS cache proxies as DaemonSets on cluster nodes.
Container Storage Add-on
Add-on Name
CCE Container Storage (Everest)
This add-on is a cloud native container storage system, which enables clusters of Kubernetes v1.15.6 or later to use cloud storage through the Container Storage Interface (CSI).
Container Security Add-on
Add-on Name
CCE Secrets Manager for DEW
This add-on is used to interconnect with Data Encryption Workshop (DEW), which allows you to mount secrets stored outside a cluster (DEW for storing sensitive information) to pods. In this way, sensitive information can be decoupled from the cluster environment, which prevents information leakage caused by program hardcoding or plaintext configuration.
Other Add-ons
Add-on Name
Kubernetes Dashboard
This add-on is a general-purpose, web-based UI for Kubernetes clusters and integrates all commands that can be used in the CLI. It allows users to manage applications running in a cluster and troubleshoot faults, as well as manage the cluster itself.
Add-on Lifecycle
An add-on lifecycle involves all the statuses of the add-on from installation to uninstallation.
Table 1 Add-on statuses
Status
Attribute
Running
Stable state
The add-on is running properly, all add-on instances are deployed properly, and the add-on can be used properly.
Partially ready
Stable state
The add-on is running properly, but some add-on instances are not properly deployed. In this state, the add-on functions may be unavailable.
Unavailable
Stable state
The add-on malfunctions, and all add-on instances are not properly deployed.
Installing
Intermediate state
The add-on is being deployed.
If all instances cannot be scheduled due to incorrect add-on configuration or insufficient resources, the system sets the add-on status to Unavailable 10 minutes later.
Installation failed
Stable state
Install add-on failed. Uninstall it and try again.
Upgrading
Intermediate state
The add-on is being upgraded.
Upgrade failed
Stable state
Upgrade add-on failed. Upgrade it again, or uninstall it and try again.
Rolling back
Intermediate state
The add-on is rolling back.
Rollback failed
Stable state
The add-on rollback failed. Retry the rollback, or uninstall it and try again.
Deleting
Intermediate state
The add-on is being deleted.
If this state stays for a long time, an exception occurred.
Deletion failed
Stable state
Delete add-on failed. Try again.
Unknown
Stable state
No add-on chart found.
When an add-on is in an intermediate state such as Installing or Deleting, you are not allowed to edit or uninstall the add-on.
If the add-on status is unknown and the returned status.Reason is "don't install the addon in this cluster", the secret associated with the Helm release of the add-on in the cluster is typically deleted by mistake. In this case, uninstall the add-on and reinstall it with the same configurations.
Related Operations
You can perform the operations listed in Table 2 on the Add-ons page.
Table 2 Related operations
Operation
Install
Install a specified add-on.
  1. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Add-ons.
  2. Click Install under the target add-on.
    Each add-on has different configuration parameters. For details, see the corresponding chapter.
  3. Click OK.
Upgrade
Upgrade an add-on to the new version.
  2. If an add-on can be upgraded, the Upgrade button is displayed under it.
    Click Upgrade. Each add-on has different configuration parameters. For details, see the corresponding chapter.
  3. Click OK.
Edit
Edit add-on parameters.
  2. Click Edit under the target add-on.
  3. Click OK.
Uninstall
Uninstall an add-on from the cluster.
  2. Click Uninstall under the target add-on.
  3. In the displayed dialog box, click Yes.
    This operation cannot be undone.
Roll back
Roll back an add-on to the source version.
  • This function is used to roll back an upgraded add-on to the source version, not to undo the editing of add-on parameters.
  • An add-on cannot be rolled back repeatedly.
  2. If an add-on can be rolled back, the Roll Back button is displayed under it.
    Click Roll Back.
Add-on rollback is supported in certain add-on versions.
  • CoreDNS: 1.25.11 and later versions
  • Everest: 2.1.19 and later versions
  • Autoscaler:
    • v1.21 clusters: v1.21.22 and later versions
    • v1.23 clusters: v1.23.24 and later versions
    • v1.25 clusters: v1.25.14 and later versions
  • kube-prometheus-stack: v3.7.2 and later versions
  • Volcano: 1.11.4 and later versions
  • NPD: 1.18.22 and later versions
