更新时间:2026-10-20 GMT+08:00
NGINX-INGRESS仪表盘模板
日志服务支持采集NGINX-INGRESS日志,并进行多维度分析。云日志服务支持日志采集向导一站式采集NGINX-INGRESS日志,并为NGINX-INGRESS日志配置结构化和仪表盘。Nginx Ingress是专为Kubernetes集群设计的Ingress控制器,用于管理外部访问到集群内服务的路由规则。
NGINX-INGRESS仪表盘模板支持查看NGINX-INGRESS秒级监控、查看NGINX-INGRESS访问中心和查看NGINX-INGRESS监控中心。
前提条件
查看NGINX-INGRESS秒级监控
  1. 登录云日志服务控制台,进入“日志管理”页面。
  2. 在左侧导航栏中选择“仪表盘”。
  3. 在仪表盘模板下方,选择“NGINX-INGRESS仪表盘模板 > NGINX-INGRESS秒级监控”,查看图表详情。
    图1 NGINX-INGRESS秒级监控
    • 过滤appName,所关联的查询分析语句如下所示:
      * | SELECT appName group by appName
    • QPS图表所关联的查询分析语句如下所示:
      * | SELECT  TIME_FORMAT(TIME_CEIL(__time,'PT1S'),'yyyy-MM-dd HH:mm:ss','+08:00') AS _time_ , COUNT(*) as QPS from log where req_id is not null group by _time_
    • 成功率图表所关联的查询分析语句如下所示:
      * | SELECT __time,round(CASE WHEN "成功率" > 0 THEN "成功率" else 0 end,2) as "成功率" from (select TIME_FORMAT(TIME_CEIL(__time,'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time, sum(case when status < 400 then 1 else 0 end) * 100.0 / count(1) as '成功率' from log where req_id is not null group by __time)
    • 延迟图表所关联的查询分析语句如下所示:
      * | SELECT __time,round(CASE WHEN "访问延迟" > 0 THEN "访问延迟" else 0 end,2) as "访问延迟",round(CASE WHEN "Upstream延迟" > 0 THEN "Upstream延迟" else 0 end,2) as "Upstream延迟" from (select TIME_FORMAT(TIME_CEIL(__time,'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time, avg(request_time)* 1000 as '访问延迟',avg(upstream_response_time)* 1000 as 'Upstream延迟' from log where req_id is not null group by __time)
    • 流量图表所关联的查询分析语句如下所示:
      * | SELECT TIME_FORMAT(TIME_CEIL(__time,'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time , sum("request_length") as "请求流量", sum("body_bytes_sent") as "返回body流量" where req_id is not null group by __time
    • 状态码图表所关联的查询分析语句如下所示:
      * | SELECT t.t as "time",
            CASE WHEN a."2XX" IS NOT NULL THEN  CAST(a."2XX" AS BIGINT) ELSE 0 END as "2XX",
            CASE WHEN b."3XX" IS NOT NULL THEN  CAST(b."3XX" AS BIGINT) ELSE 0 END as "3XX",
            CASE WHEN c."4XX" IS NOT NULL THEN  CAST(c."4XX" AS BIGINT) ELSE 0 END as "4XX",
            CASE WHEN d."5XX" IS NOT NULL THEN  CAST(d."5XX" AS BIGINT) ELSE 0 END as "5XX",
            CASE WHEN e."其他" IS NOT NULL THEN  CAST(e."其他" AS BIGINT)  ELSE 0 END as "其他"
            from (select TIME_CEIL(__time,'PT5S') as t from log where req_id is not null group by t order by t asc  ) t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "2XX" from log WHERE "status" >= 200 and "status" < 300 and req_id is not null group by t order by t asc ) a on t.t =a.t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "3XX" from log WHERE "status" >= 300 and "status" < 400 and req_id is not null group by t order by t asc) b on t.t =b.t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "4XX" from log WHERE "status" >= 400 and "status" < 500 and req_id is not null group by t order by t asc) c on t.t =c.t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "5XX" from log WHERE "status" >= 500 and "status" < 600 and req_id is not null group by t order by t asc) d on t.t =d.t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "其他" from log WHERE "status" < 200 or "status" >= 600 and req_id is not null group by t order by t asc) e on t.t =e.t
    • 后端响应码图表所关联的查询分析语句如下所示:
            from (
            ) t
            left join(
            SELECT TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "2XX" from log WHERE "upstream_status" >= 200 and "upstream_status" < 300 and req_id is not null group by t order by t asc) a
            on t.t = a.t
            left join (
            SELECT TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "3XX" from log WHERE "upstream_status" >= 300 and "upstream_status" < 400 and req_id is not null group by t order by t asc) b
            on t.t =b.t
            left join (
            SELECT TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "4XX" from log WHERE "upstream_status" >= 400 and "upstream_status" < 500 and req_id is not null group by t order by t asc) c
            on t.t =c.t
            left join (
            SELECT TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "5XX" from log WHERE "upstream_status" >= 500 and "upstream_status" < 600 and req_id is not null group by t order by t asc) d
            on t.t =d.t
            left join (
            SELECT TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "其他" from log WHERE "upstream_status" < 200 or "upstream_status" >= 600 and req_id is not null group by t order by t asc) e
            on t.t =e.t
查看NGINX-INGRESS访问中心
  1. 在仪表盘模板下方,选择“NGINX-INGRESS仪表盘模板 > NGINX-INGRESS访问中心”,查看图表详情。
    图2 NGINX-INGRESS访问中心
    • PV对比昨日图表所关联的查询分析语句如下所示:
      * | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "pv" , 86400) as diff from (select count(1) as "pv" from log where req_id is not null))
    • PV对比上周图表所关联的查询分析语句如下所示:
      * | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "pv" , 604800) as diff from (select count(1) as "pv" from log where req_id is not null))
    • UV对比昨日图表所关联的查询分析语句如下所示:
      * | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "uv" , 86400) as diff from (select APPROX_COUNT_DISTINCT(remote_addr) as "uv" from log where req_id is not null))
    • UV对比上周图表所关联的查询分析语句如下所示:
      * | SELECT diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "uv" , 604800) as diff from (select APPROX_COUNT_DISTINCT(remote_addr) as "uv" from log where req_id is not null))
    • 访问量PV分布(中国)图表所关联的查询分析语句如下所示:
      * | SELECT ip_to_province(remote_addr) as province, count(1) as pv where IP_TO_COUNTRY (remote_addr) = '中国' and req_id is not null  group by province HAVING province not in ('','保留地址','*')
    • 访问量PV分布(世界)图表所关联的查询分析语句如下所示:
      * | SELECT ip_to_country(remote_addr) as country,COUNT(1) as PV where req_id is not null GROUP BY country HAVING country not in ('','保留地址','*')
    • 访问量UV分布(中国)图表所关联的查询分析语句如下所示:
      * | SELECT ip_to_province(remote_addr) as province, APPROX_COUNT_DISTINCT(remote_addr) as UV where IP_TO_COUNTRY (remote_addr) = '中国'  and req_id is not null group by province HAVING province not in ('','保留地址','*')
    • 访问量UV分布(世界)图表所关联的查询分析语句如下所示:
      * | SELECT ip_to_country(remote_addr) as country, APPROX_COUNT_DISTINCT(remote_addr) as uv where req_id is not null group by country HAVING country not in ('','保留地址','*')
    • 平均时延分布(中国)图表所关联的查询分析语句如下所示:
      * | SELECT province,round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)"FROM (SELECT ip_to_province(remote_addr) as province,avg(request_time) * 1000 AS "平均延迟(ms)" WHERE  IP_TO_COUNTRY (remote_addr) = '中国' and req_id is not null GROUP BY province HAVING province not in ('','保留地址','*'))
    • 平均时延分布(世界)图表所关联的查询分析语句如下所示:
      * | SELECT country,round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 2 ) AS "平均延迟(ms)"FROM (SELECT ip_to_country(remote_addr) as country,avg(request_time) * 1000 AS "平均延迟(ms)" where req_id is not null GROUP BY country HAVING country not in ('','保留地址','*'))
    • 今日PV/UV图表所关联的查询分析语句如下所示:
      * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,PV,UV FROM (select TIME_CEIL(__time,'PT600S') AS _time_ , count(1) as PV,  APPROX_COUNT_DISTINCT(remote_addr) as UV from log WHERE __time <= CURRENT_TIMESTAMP  and __time >= DATE_TRUNC( 'DAY',(CURRENT_TIMESTAMP + INTERVAL '8' HOUR)) - INTERVAL '8' HOUR and req_id is not null group by _time_ order by _time_) WHERE _time_ <= CURRENT_TIMESTAMP order by _time_ LIMIT 100000 OFFSET 1
    • 7日PV/UV图表所关联的查询分析语句如下所示:
      * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,PV,UV FROM (select  TIME_CEIL(__time,'PT600S') AS _time_ , count(1) as PV,  APPROX_COUNT_DISTINCT(remote_addr) as UV from log WHERE __time <= CURRENT_TIMESTAMP  and __time >= DATE_TRUNC( 'DAY',(CURRENT_TIMESTAMP + INTERVAL '8' HOUR)) - INTERVAL '8' HOUR - INTERVAL '7' DAY and req_id is not null group by _time_ order by _time_ ) WHERE _time_ <= CURRENT_TIMESTAMP order by _time_ LIMIT 100000 OFFSET 1
    • 区域访问TOP10(省份)图表所关联的查询分析语句如下所示:
      * | SELECT ip_to_province(remote_addr) as "province", count(1) as "访问次数" where req_id is not null group by "province" HAVING "province" <> '-1' order by "访问次数" asc limit 10
    • 区域访问TOP10(城市)图表所关联的查询分析语句如下所示:
      * | SELECT ip_to_city(remote_addr) as "city", count(1) as "访问次数" where req_id is not null group by "city" HAVING  "city" <> '-1' order by "访问次数" asc  limit 10
    • Host访问TOP10图表所关联的查询分析语句如下所示:
      * | SELECT  remote_addr as "Host", count(1) as "PV" where req_id is not null group by "Host" order by "PV" asc limit 10
    • UserAgent访问TOP10图表所关联的查询分析语句如下所示:
      * | SELECT http_user_agent as "UserAgent", count(1) as "PV" where req_id is not null group by "UserAgent" order by "PV" asc limit 10
    • 设备占比(终端)图表所关联的查询分析语句如下所示:
      * | SELECT case when regexp_like(lower(http_user_agent), 'iphone|ipod|android|ios') then '移动端' else 'PC端' end as type , count(1) as total where req_id is not null group by  type
    • 设备占比(系统)图表所关联的查询分析语句如下所示:
      * | SELECT case when regexp_like(lower(http_user_agent), 'iphone|ipod|ios') then 'IOS' when regexp_like(lower(http_user_agent), 'android') then 'Android' else 'other' end as type , count(1) as total where req_id is not null group by  type HAVING type != 'other'
    • TOP URL图表所关联的查询分析语句如下所示:
      * | SELECT request_uri , count(1) as PV, APPROX_COUNT_DISTINCT(remote_addr) as UV, round(sum( case when status < 400 then 1 else 0 end ) * 100.0 / count(1), 2) as "访问成功率" where req_id is not null group by request_uri ORDER by PV desc
    • TOP 访问IP图表所关联的查询分析语句如下所示:
      * | SELECT remote_addr as "来源IP",ip_to_country(remote_addr) as "国家",ip_to_province(remote_addr) as "省份",ip_to_city(remote_addr) as "城市",ip_to_provider(remote_addr) as "运营商",count(1) as "PV",http_user_agent as "UserAgent采样",request_uri as "URL采样" where req_id is not null group by remote_addr,http_user_agent,request_uri ORDER by "PV" desc
查看NGINX-INGRESS监控中心
  1. 在仪表盘模板下方,选择“NGINX-INGRESS仪表盘模板 > NGINX-INGRESS监控中心”,查看图表详情。
    图3 NGINX-INGRESS监控中心
    • 访问量PV图表所关联的查询分析语句如下所示:
      * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,PV FROM ( SELECT TIME_CEIL ( __time, 'PT300S' ) AS _time_, count( 1 ) AS PV FROM log where req_id is not null GROUP BY _time_ )  WHERE _time_ <= CURRENT_TIMESTAMP  LIMIT 100000 OFFSET 1
    • 请求成功率图表所关联的查询分析语句如下所示:
      * | SELECT ROUND(sum(case when status < 400 then 1 else 0 end) * 100.0 / count(1),2) as cnt where req_id is not null
    • 平均延迟图表所关联的查询分析语句如下所示:
      * | SELECT round(avg(request_time) * 1000, 3) as cnt where req_id is not null
    • 4XX请求数图表所关联的查询分析语句如下所示:
      * | SELECT COUNT(1) as cnt WHERE "status" >= 400 and "status" < 500 and req_id is not null
    • 404请求数图表所关联的查询分析语句如下所示:
      * | SELECT COUNT(1) as cnt WHERE "status" = 404 and req_id is not null
    • 429请求数图表所关联的查询分析语句如下所示:
      * | SELECT COUNT(1) as cnt WHERE "status" = 429 and req_id is not null
    • 504请求数图表所关联的查询分析语句如下所示:
      * | SELECT COUNT(1) as cnt WHERE "status" = 504 and req_id is not null
    • 5XX请求数图表所关联的查询分析语句如下所示:
      * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,cnt FROM ( SELECT TIME_CEIL ( __time, 'PT300S' ) AS _time_, count( 1 ) AS cnt FROM log where "status" >= 500 and req_id is not null GROUP BY _time_ )  WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
    • 状态码分布图表所关联的查询分析语句如下所示:
      * | SELECT status, COUNT(1) AS rm where req_id is not null GROUP BY status
    • 访问量UV图表所关联的查询分析语句如下所示:
      * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,UV FROM (select TIME_CEIL(__time,'PT600S') AS _time_ , APPROX_COUNT_DISTINCT(remote_addr) as UV  from log where req_id is not null group by _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
      * | SELECT TIME_FORMAT(_time_,'yyyy-MM-dd HH:mm:ss','+08:00') AS _time_,round( CASE WHEN "入流量" > 0 THEN "入流量" ELSE 0 END, 2 ) AS "入流量",round( CASE WHEN "出流量" > 0 THEN "出流量" ELSE 0 END, 2 ) AS "出流量" FROM (SELECT TIME_CEIL(__time,'PT600S') AS _time_,sum(request_length) / 1024.0 AS "入流量",sum(body_bytes_sent) / 1024.0 AS "出流量" where req_id is not null group by  _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
    • 访问失败率图表所关联的查询分析语句如下所示:
      * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,round( CASE WHEN "失败率" > 0 THEN "失败率" ELSE 0 END, 2 ) AS "失败率",round( CASE WHEN "5XX比例" > 0 THEN "5XX比例" ELSE 0 END, 2 ) AS "5XX比例" from (select TIME_CEIL(__time,'PT600S') AS _time_,sum(case when status >= 400 then 1 else 0 end) * 100.0 / count(1) as '失败率' , sum(case when status >=500 THEN 1 ELSE 0 END)*100.0/COUNT(1) as '5XX比例' where req_id is not null group by  _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
      * | SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,round( CASE WHEN "平均" > 0 THEN "平均" ELSE 0 END, 2 ) AS "平均",round( CASE WHEN "P50" > 0 THEN "P50" ELSE 0 END, 2 ) AS "P50",round( CASE WHEN "P90" > 0 THEN "P90" ELSE 0 END, 2 ) AS "P90",round( CASE WHEN "P99" > 0 THEN "P99" ELSE 0 END, 2 ) AS "P99",round( CASE WHEN "P9999" > 0 THEN "P9999" ELSE 0 END, 2 ) AS "P9999" from (select TIME_CEIL(__time,'PT600S') as _time_,avg(request_time) * 1000 as "平均", APPROX_QUANTILE_DS("request_time", 0.50)*1000 as "P50", APPROX_QUANTILE_DS("request_time", 0.90)*1000 as "P90" ,APPROX_QUANTILE_DS("request_time", 0.99)*1000 as 'P99',APPROX_QUANTILE_DS("request_time", 0.9999)*1000 as 'P9999' where req_id is not null group by  _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
    • Host请求TOP图表所关联的查询分析语句如下所示:
      * | SELECT "remote_addr", pv, uv, round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "入流量(KB)" > 0 THEN "入流量(KB)" ELSE 0 END, 3 ) AS "入流量(KB)", round( CASE WHEN "出流量(KB)" > 0 THEN "出流量(KB)" ELSE 0 END, 3 ) AS "出流量(KB)"  FROM ( SELECT "remote_addr", count( 1 ) AS pv, APPROX_COUNT_DISTINCT ( remote_addr ) AS uv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", sum( request_length ) / 1024.0 AS "入流量(KB)", sum( body_bytes_sent ) / 1024.0 AS "出流量(KB)"  WHERE "remote_addr" != '' and req_id is not null  GROUP BY "remote_addr" ) ORDER BY pv DESC
    • Host延迟TOP图表所关联的查询分析语句如下所示:
      * | SELECT "remote_addr", pv, round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)", round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM ( SELECT "remote_addr", count( 1 ) AS pv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)",APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "remote_addr" != '' and req_id is not null GROUP BY "remote_addr" ) ORDER BY "平均延迟(ms)" desc
    • Host失败率TOP图表所关联的查询分析语句如下所示:
      * | SELECT "remote_addr", pv,round( CASE WHEN "访问失败率(%)" > 0 THEN "访问失败率(%)" ELSE 0 END, 2 ) AS "访问失败率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)", round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)"  FROM ( SELECT "remote_addr", count( 1 ) AS pv, sum( CASE WHEN "status" >= 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问失败率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "remote_addr" != '' and req_id is not null GROUP BY "remote_addr"  ) ORDER BY "访问失败率(%)" desc
    • URL请求TOP图表所关联的查询分析语句如下所示:
      * | SELECT request_uri, pv,uv, round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "入流量(KB)" > 0 THEN "入流量(KB)" ELSE 0 END, 3 ) AS "入流量(KB)", round( CASE WHEN "出流量(KB)" > 0 THEN "出流量(KB)" ELSE 0 END, 3 ) AS "出流量(KB)"  FROM ( SELECT request_uri, count( 1 ) AS pv, APPROX_COUNT_DISTINCT ( remote_addr ) AS uv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", sum( request_length ) / 1024.0 AS "入流量(KB)", sum( body_bytes_sent ) / 1024.0 AS "出流量(KB)"  WHERE "remote_addr" != '' and req_id is not null GROUP BY request_uri  ) ORDER BY pv desc
    • URL延迟TOP图表所关联的查询分析语句如下所示:
      * | SELECT request_uri, pv,round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)",round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)",round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)",round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM (SELECT request_uri, count( 1 ) AS pv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "remote_addr" != '' and req_id is not null GROUP BY request_uri  ) ORDER BY "平均延迟(ms)" desc
    • URL失败率TOP图表所关联的查询分析语句如下所示:
      * | SELECT request_uri, pv, round( CASE WHEN "访问失败率(%)" > 0 THEN "访问失败率(%)" ELSE 0 END, 2 ) AS "访问失败率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)",round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)", round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM( SELECT request_uri, count( 1 ) AS pv, sum( CASE WHEN "status" >= 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问失败率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "remote_addr" != '' and req_id is not null GROUP BY request_uri  )ORDER BY "访问失败率(%)" desc
    • 后端请求TOP图表所关联的查询分析语句如下所示:
      * | SELECT addr, pv, uv, round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "入流量(KB)" > 0 THEN "入流量(KB)" ELSE 0 END, 3 ) AS "入流量(KB)", round( CASE WHEN "出流量(KB)" > 0 THEN "出流量(KB)" ELSE 0 END, 3 ) AS "出流量(KB)"  FROM ( SELECT upstream_addr as addr, count( 1 ) AS pv, APPROX_COUNT_DISTINCT ( remote_addr ) AS uv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", sum( request_length ) / 1024.0 AS "入流量(KB)", sum( body_bytes_sent ) / 1024.0 AS "出流量(KB)"  WHERE "remote_addr" != '' and req_id is not null GROUP BY addr  having length(upstream_addr) > 2) ORDER BY "pv" desc
    • 后端延迟TOP图表所关联的查询分析语句如下所示:
      * | SELECT addr,pv,round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)",round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)",round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)",round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM (SELECT upstream_addr as addr,count( 1 ) AS pv,sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)",avg( request_time ) * 1000 AS "平均延迟(ms)",APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)",APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "remote_addr" != '' and req_id is not null GROUP BY addr having length(upstream_addr) > 2) ORDER BY "平均延迟(ms)" desc
    • 后端失败率TOP图表所关联的查询分析语句如下所示:
      * | SELECT addr, pv, round( CASE WHEN "访问失败率(%)" > 0 THEN "访问失败率(%)" ELSE 0 END, 2 ) AS "访问失败率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)", round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)"  FROM ( SELECT upstream_addr as addr, count( 1 ) AS pv, sum( CASE WHEN "status" >= 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问失败率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "remote_addr" != '' and req_id is not null GROUP BY addr having length(upstream_addr) > 2)ORDER BY "访问失败率(%)" desc
