更新时间:2024-07-11 GMT+08:00
ICAgent整体状态
云日志服务支持展示ICAgent整体状态仪表盘模板,用于展示活跃ICAgent数、CPU趋势、ICAgent整体状态等图表。
前提条件
在LTS控制台配置中心页面的“ICAgent采集开关”页签,开启ICAgent诊断开关,请参考设置ICAgent日志采集开关。
分析网站访问情况
- 登录云日志服务控制台。
- 在左侧导航栏中选择“仪表盘 ”。
- 在仪表盘模板下方,选择“采集诊断仪表盘模板>ICAgent整体状态”仪表盘,查看图表详情。
ICAgent整体状态仪表盘中的重要图表说明如下所示:
- 活跃ICAgent数图展示常用日志流的变化情况,所关联的查询分析语句如下所示:
select diff[1] as "活跃ICAgent数",case when diff[2] is not null then diff[2] else '昨日无数据' end as "昨日活跃ICAgent数" from (select report_topic,compare(uv,86400) as diff from (SELECT report_topic,COUNT(DISTINCT ip) as uv FROM log where report_topic = 'icagent_status' group by report_topic) group by report_topic)
- 发送延迟/次数趋势图展示延迟/次数变化情况,所关联的查询分析语句如下所示:
select time_floor(__time,'PT5M') as \"time\" , sum(\"metric.lts_cost.below_100_ms\") as \"below_100_ms\" , sum(\"metric.lts_cost.100to500ms\") as \"100to500ms\" , sum(\"metric.lts_cost.500msto1s\") as \"500msto1s\" , sum(\"metric.lts_cost.1sto10s\") as \"1sto10s\", sum(\"metric.lts_cost.10ston\") as \"10ston\" from log where \"report_topic\" = 'icagent_status' group by \"time\"
- 运行状态分布图展示运行状态的变化情况,所关联的查询分析语句如下所示:
select status,count(DISTINCT ip) as pv from log where report_topic = 'icagent_status' group by status
- CPU趋势图展示CPU占用率的变化情况,所关联的查询分析语句如下所示:
select ip,time_floor(__time,'PT5M') as \"time\",avg(\"metric.cpu_usage\") as \"CPU占用率\" from log where report_topic = 'icagent_status' and \"metric.cpu_usage\" is not null group by \"time\",ip order by \"time\"
- ICAgent整体状态图展示主机的整体情况,所关联的查询分析语句如下所示:
select host_name as "主机名",ip as "IP" , version as "版本号" , os as "操作系统" , time_format(MILLIS_TO_TIMESTAMP(ANY_VALUE("metric.start_time")),'yyyy/MM/dd HH:mm:ss ZZZ') as "启动时间",avg("metric.cpu_usage") as "CPU",avg("metric.mem_used")*1.0 as "内存(MB)",status as "运行状态" where report_topic = 'icagent_status' group by host_name,ip,version,os,status
父主题: 采集诊断仪表盘模板
