CCE日志审计中心
CCE日志审计中心仪表盘主要展示总审计记录数、操作用户数、活跃节点数、异常访问次数等。
前提条件
- 已采集CCE日志,详情请参见云容器引擎CCE应用日志接入LTS。
- 日志配置结构化,详情请参见结构化配置。
背景信息
云容器引擎(Cloud Container Engine,简称CCE)提供高度可扩展的、高性能的企业级Kubernetes集群。借助云容器引擎,您可以在华为云上轻松部署、管理和扩展容器化应用程序。
分析网站访问情况
- 登录云日志服务控制台。
- 在左侧导航栏中选择“仪表盘 ”。
- 在仪表盘模板下方,选择“CCE日志审计中心”仪表盘,查看图表详情。
CCE日志审计中心仪表盘中的过滤器说明如下所示:
- 命名空间,所关联的查询分析语句如下所示:
select distinct("objectRef.namespace")
- 操作用户,所关联的查询分析语句如下所示:
select distinct("user.username")
- 操作类型,所关联的查询分析语句如下所示:
select distinct("verb")
- 状态码,所关联的查询分析语句如下所示:
select distinct("responseStatus.code")
- 资源对象,所关联的查询分析语句如下所示:
select distinct("objectRef.name")
- 资源类型,所关联的查询分析语句如下所示:
select distinct("objectRef.resource")
- 请求URL,所关联的查询分析语句如下所示:
select distinct("requestURI")
- UserAgent,所关联的查询分析语句如下所示:
select distinct("userAgent")
重要图表说明
CCE日志审计中心仪表盘中重要图表说明如下所示:
- 总审计记录数,所关联的查询分析语句如下所示:
select diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log ) )
- 操作用户数,所关联的查询分析语句如下所示:
select diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(distinct("user.username")) as total from log ) )
- 活跃节点数,所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(DISTINCT "user.username") as total from log where "objectRef.resource" = 'nodes' and "objectRef.subresource" = 'status' and "verb" in ('update','put','patch') and "user.username" in ('node','system')) )
- 异常访问次数,所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where "responseStatus.code" >= 400) )
- 敏感操作次数,所关联的查询分析语句如下所示:
select diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as "total" from log where ("verb" = 'create' AND "objectRef.subresource" = 'exec') OR ("verb" = 'create' AND "objectRef.subresource" = 'attach' AND "objectRef.resource" = 'pods') OR ("objectRef.resource" = 'secrets' AND "verb"= 'get' AND ( "user.username" != 'apiserver') AND ("user.username" not like 'system:node:%')) OR ("verb"= 'delete' AND ( "user.username" not like 'system:node:%') AND ( "user.username" not like 'system:serviceaccount:kube-system:%') AND ( "user.username" != 'system:apiserve') AND ( "user.username" != 'system:apiserve') AND ( "user.username" != 'system:kube-scheduler') AND ("user.username" != 'system:kube-controller-manager'))) )
- 创建操作次数,所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where verb = 'create') )
- 更新操作次数,所关联的查询分析语句如下所示:
select diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where verb in ('update','patch')) )
- 删除操作次数,所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where verb = 'delete') )
- 操作用户分布,所关联的查询分析语句如下所示:
select "user.username" as "用户名", count(*) as "count" group by "用户名" order by "count" desc
- 命名空间分布,所关联的查询分析语句如下所示:
select "objectRef.namespace" as "命名空间", count(*) as "count" group by "命名空间"
- 资源类型分布,所关联的查询分析语句如下所示:
select "objectRef.resource" as "资源类型", count(*) as "count" group by "资源类型" order by "count" desc limit 20
- 操作类型分布,所关联的查询分析语句如下所示:
select verb as "操作类型", count(*) as "count" group by "操作类型" order by "count" desc
- 节点操作分布,所关联的查询分析语句如下所示:
select "verb" as "操作类型", count(*) as "count" where "objectRef.resource" = 'nodes' AND ("verb" in ('create','delete') ) group by "操作类型" order by "count" desc
- 状态码分布,所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" group by "状态码" order by "count" desc
- 工作负载操作分布,所关联的查询分析语句如下所示:
select "verb" as "操作类型", count(*) as "count" where "verb" in ('create', 'delete') and "objectRef.resource" in ('deployments','statefulsets','daemonsets','jobs','cronjobs') group by "操作类型" order by "count" desc
- Service/Ingress操作分布,所关联的查询分析语句如下所示:
select "verb" as "操作类型", count(*) as "count" where "verb" in ('create', 'delete') and "objectRef.resource" in ('ingressess','services') group by "verb" order by "count" desc
- 重要操作趋势,所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT("stageTimestamp", 16),'T',' ') AS "dt", "verb", count(*) as "count" where "verb" in ('create','delete','update','patch') group by "dt", "verb" order by "dt" limit 10000
- 非系统用户操作趋势,所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT("stageTimestamp", 16),'T',' ') AS "dt", count(*) as "count", "user.username" as "用户名称" where "user.username" not in ('kube-controller-manager','kube-apiserver-kubelet-client','system','apiserver') group by "dt", "用户名称" order by "dt" limit 10000
