更新时间:2026-10-20 GMT+08:00
CCE仪表盘模板
云容器引擎(Cloud Container Engine,简称CCE)提供高度可扩展的、高性能的企业级Kubernetes集群。
CCE仪表盘模板支持查看CCE日志节点操作、查看CCE日志K8s对象操作、查看CCE日志K8s事件查询、查看CCE日志K8s事件中心、查看CCE日志聚合检索、查看CCE日志账号操作审计和查看CCE日志审计中心。
前提条件
- 已采集CCE日志,详情请参见云容器引擎CCE应用日志接入LTS。
- 日志配置结构化,详情请参见设置云端结构化解析日志。
查看CCE日志节点操作
- 登录云日志服务控制台,进入“日志管理”页面。
- 在左侧导航栏中选择“仪表盘 ”。
- 在仪表盘模板下方,选择“CCE仪表盘模板 > CCE日志节点操作”,查看图表详情。
- 过滤节点名称,所关联的查询分析语句如下所示:
select distinct("objectRef.name") - 过滤操作用户,所关联的查询分析语句如下所示:
select distinct("user.username") - 过滤状态码,所关联的查询分析语句如下所示:
select distinct("responseStatus.code") - 过滤操作类型,所关联的查询分析语句如下所示:
select distinct("verb")
- 节点数趋势图表所关联的查询分析语句如下所示:
SELECT time_series( TIME_PARSE(LEFT(requestReceivedTimestamp, 23),'yyyy-MM-dd''T''HH:mm:ss.SSS'), 'PT1H', 'yyyy-MM-dd HH', '0' ) as "dt", count(DISTINCT("objectRef.name")) as "节点数" where "objectRef.resource" = 'nodes' and "objectRef.subresource" = 'status' and "verb" in ('update', 'patch') and "user.username" = 'system:node' group by "dt" order by "dt" desc limit 10000 - 非系统用户操作趋势图表所关联的查询分析语句如下所示:
SELECT time_series( TIME_PARSE(LEFT(requestReceivedTimestamp, 23),'yyyy-MM-dd''T''HH:mm:ss.SSS'), 'PT1H', 'yyyy-MM-dd HH', '0' ) as "dt", count(*) as "请求", "user.username" where "objectRef.resource" = 'nodes' and "user.username" not in ( 'kube-controller-manager','kube-apiserver-kubelet-client','apiserver') and "user.username" not like 'system:%' and "verb" in ('create','delete','update','patch') group by "dt", "user.username" order by "dt","请求" desc limit 10000 - create操作状态码分布图表所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" = 'create' group by "状态码" - delete操作状态码分布图表所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" = 'delete' group by "状态码" - patch操作状态码分布图表所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" = 'patch' group by "状态码" - update操作状态码分布图表所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" = 'update' group by "状态码" - 节点封锁/解除封锁操作状态码分布图表所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "requestObject" in ('{"spec":{"unschedulable":false}}','{"spec":{"unschedulable":true}}') group by "状态码" - Label操作状态码分布图表所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" in ('patch','update') and "requestObject" = 'labels' and "requestObject" = 'metadata' group by "状态码" - Taint操作状态码分布图表所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.resource" = 'nodes' and "verb" in ('patch','update') and "requestObject" = 'taints' group by "状态码" - 驱逐操作状态码分布图表所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "objectRef.subresource" = 'eviction' and "objectRef.resource" = 'pods' and "verb" = 'create' group by "状态码" - 节点增删操作列表图表所关联的查询分析语句如下所示:
select "auditID" AS "Audit ID", "objectRef.name" AS "节点名", "verb" AS "操作动作", "stageTimestamp" AS "操作时间", "user.username" AS "操作账号", "responseStatus.code" AS "状态码" where "objectRef.resource" = 'nodes' and "verb" in ('create','delete') - Taint操作列表图表所关联的查询分析语句如下所示:
select "auditID" AS "Audit ID", "objectRef.name" AS "节点名","requestObject" AS "Taints", "requestReceivedTimestamp" AS "操作时间", "user.username" AS "操作账号", "responseStatus.code" AS "状态码" where "objectRef.resource" = 'nodes' and "verb" = 'patch' and "requestObject" = 'taints'
- 驱逐操作列表图表所关联的查询分析语句如下所示:
select "auditID" AS "Audit ID", "objectRef.name" AS "pod", "sourceIPs" AS "源地址", "requestReceivedTimestamp" AS "操作时间", "user.username" AS "操作账号", "responseStatus.code" AS "状态码" where "objectRef.resource" = 'pods' and "verb" = 'create' and "objectRef.subresource" = 'eviction'
- Label操作列表图表所关联的查询分析语句如下所示:
select "auditID" AS "Audit ID", "objectRef.name" AS "节点名", "requestObject" AS "Label", "requestReceivedTimestamp" AS "操作时间", "user.username" AS "操作账号", "responseStatus.code" AS "状态码" where "objectRef.resource" = 'nodes' and "verb" = 'patch' and "requestObject" = 'labels'
- 封锁操作列表图表所关联的查询分析语句如下所示:
select "auditID" AS "Audit ID", "objectRef.name" AS "节点名", "requestReceivedTimestamp" AS "操作时间", "user.username" AS "操作账号", "responseStatus.code" AS "状态码" where "verb" = 'patch' and "objectRef.resource" = 'nodes' and "requestObject" ='true' and "requestObject" = 'unschedulable'
- 取消封锁操作列表图表所关联的查询分析语句如下所示:
select "auditID" AS "Audit ID", "objectRef.name" AS "节点名", "requestReceivedTimestamp" AS "操作时间", "user.username" AS "操作账号", "responseStatus.code" AS "状态码" where "verb" = 'patch' and "objectRef.resource" = 'nodes' and "requestObject" not in ('true','taints','unschedulable')
查看CCE日志K8s对象操作
- 在仪表盘模板下方,选择“CCE仪表盘模板 > CCE日志K8s对象操作”,查看图表详情。
- 过滤命名空间,所关联的查询分析语句如下所示:
select distinct("objectRef.namespace") - 过滤操作类型,所关联的查询分析语句如下所示:
select distinct("verb") - 过滤状态码,所关联的查询分析语句如下所示:
select distinct("responseStatus.code") - 过滤资源对象,所关联的查询分析语句如下所示:
select distinct("objectRef.name") - 过滤资源类型,所关联的查询分析语句如下所示:
select distinct("objectRef.resource") - 过滤操作用户,所关联的查询分析语句如下所示:
- 重要操作趋势图表所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT(requestReceivedTimestamp, 16),'T',' ') AS "dt", "verb" as "操作类型", count(*) as "count" where "verb" in ('create','delete','update','patch') and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "dt","操作类型" order by "dt" limit 10000 - 非系统用户操作趋势图表所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT(requestReceivedTimestamp, 16),'T',' ') AS "dt", count(*) as "请求次数","user.username" WHERE "user.username" not in ('kube-controller-manager','kube-apiserver-kubelet-client','apiserver') and "user.username" not like 'system:%' and "verb" in ('create','delete','update','patch') and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','secrets','pvcs') group by "dt", "user.username" limit 10000 - create操作资源类型分布图表所关联的查询分析语句如下所示:
select "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'create' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "objectRef.resource" - delete操作资源类型分布图表所关联的查询分析语句如下所示:
select "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'delete' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "objectRef.resource" - update操作资源类型分布图表所关联的查询分析语句如下所示:
select "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "objectRef.resource" - patch操作资源类型分布图表所关联的查询分析语句如下所示:
select "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'patch' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "objectRef.resource" - create操作用户分布图表所关联的查询分析语句如下所示:
select "user.username" as "操作用户", count(*) as "count" where "verb" = 'create' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "user.username" - delete操作用户分布图表所关联的查询分析语句如下所示:
select "user.username" as "操作用户", count(*) as "count" where "verb" = 'delete' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "user.username" - update操作用户分布图表所关联的查询分析语句如下所示:
select "user.username" as "操作用户", count(*) as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "user.username"select "user.username" as "操作用户", count(*) as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "user.username" - patch操作用户分布图表所关联的查询分析语句如下所示:
select "user.username" as "操作用户", count(*) as "count" where "verb" = 'patch' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "user.username" - create操作状态码分布图表所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "verb" = 'create' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "responseStatus.code" - delete操作状态码分布图表所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "verb" = 'delete' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "responseStatus.code" - update操作状态码分布图表所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "responseStatus.code" - patch操作状态码分布图表所关联的查询分析语句如下所示:
select cast("responseStatus.code" as varchar) as "状态码", count(*) as "count" where "verb" = 'patch' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by "responseStatus.code" - create操作趋势图表所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'create' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by dt, "objectRef.resource" order by dt limit 10000 - delete操作趋势图表所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'delete' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by dt, "objectRef.resource" order by dt limit 10000 - update操作趋势图表所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'update' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by dt, "objectRef.resource" order by dt limit 10000 - patch操作趋势图表所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "资源类型", count(*) as "count" where "verb" = 'patch' and "objectRef.resource" in ('deployments','statefulsets','cronjobs','daemonsets','jobs','pods','services','ingresses','configmaps','configmaps','persistentvolumeclaims') group by dt, "objectRef.resource" order by dt limit 10000
查看CCE日志K8s事件查询
- 在仪表盘模板下方,选择“CCE仪表盘模板 > CCE日志K8s事件查询”,查看图表详情。
- 事件等级分为Warning、Normal、Error。
- 过滤事件类型,所关联的查询分析语句如下所示:
select distinct("name") - 过滤集群ID,所关联的查询分析语句如下所示:
select distinct("cluster_id") - 过滤命名空间,所关联的查询分析语句如下所示:
select distinct("namespace") - 过滤名称,所关联的查询分析语句如下所示:
select distinct("resource_name") - 事件总数图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT( "_time_", 'yyyy-MM-dd HH:mm:ss', '' ) as "_time_","total" FROM ( SELECT TIME_CEIL ( __time, 'PT1H' ) AS "_time_", count( 1 ) AS "total" FROM log GROUP BY "_time_" )
- 普通事件数图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT( "_time_", 'yyyy-MM-dd HH:mm:ss', '' ) as "_time_","total" FROM ( SELECT TIME_CEIL ( __time, 'PT1H' ) AS "_time_", count( 1 ) AS "total" FROM log where "type" = 'Normal' GROUP BY "_time_" )
- 警告事件数图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT( "_time_", 'yyyy-MM-dd HH:mm:ss', '' ) as "_time_","total" FROM ( SELECT TIME_CEIL ( __time, 'PT1H' ) AS "_time_", count( 1 ) AS "total" FROM log where "type" = 'Warning' GROUP BY "_time_" )
- 错误事件数图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT( "_time_", 'yyyy-MM-dd HH:mm:ss', '' ) as "_time_","total" FROM ( SELECT TIME_CEIL ( __time, 'PT1H' ) AS "_time_", count( 1 ) AS "total" FROM log where "type" = 'Error' GROUP BY "_time_" )
- 重要事件分布图表所关联的查询分析语句如下所示:
select "name",count(1) as 'total' from log group by "name"
- 重要事件统计图表所关联的查询分析语句如下所示:
SELECT "type" as "等级", "name" as "类型", count(1) as "总数", "reason" as "详细内容" from log where "type" != 'Normal' group by "type", "name", "reason" order by "总数" desc
SELECT "type" as "等级", "name" as "类型", count(1) as "总数", "reason" as "详细内容" from log where "type" != 'Normal' and "resource_kind" = 'Pod' group by "type", "name", "reason" order by "总数" desc
- 最近100条事件图表所关联的查询分析语句如下所示:
select TIME_FORMAT( __time, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as "Time","type" as "等级", "name" as "类型", "reason" as "详细内容", "namespace" as "命名空间" from log order by __time desc limit 100
查看CCE日志K8s事件中心
- 在仪表盘模板下方,选择“CCE仪表盘模板 > CCE日志K8s事件中心”,查看图表详情。
- 事件等级分为Warning和Normal。
- Conntrack Full图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'ConntrackFull' ) )
- 事件同步异常图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'NTPIsDown') )
- 节点Pid不足图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name" in ('PIDPressure','NodeHasPIDPressure') ) ) - 节点FD不足图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'NodeHasFDPressure') )
- 节点磁盘空间不足图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'NodeHasDiskPressure') )
- Pod OOM图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "reason" in ('OOMKilling','PodOOMKilling')) ) - DockerHung图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'Failed' and "reason" = 'DockerHung') )
- 节点重启图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'NodeRebooted') )
- 镜像拉取失败图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'Failed' and "reason" = 'ImagePullBackOff') )
- 节点OOM图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name" = 'SystemOOM') )
- Pod启动失败图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( "total", 3600) as diff from( select count(1) as "total" from log where "name"= 'Failed' and "resource_kind" = 'Pod' and "reason" = 'ImagePullBackOff') )
- 事件分布图表所关联的查询分析语句如下所示:
select "type", count(*) as "事件数" group by "type"
- Warning事件趋势图表所关联的查询分析语句如下所示:
select time_series(__time, 'PT1H', 'yyyy-MM-dd HH', '0') as "dt",count(1) as "count" from log where "type" = 'Warning' group by "dt" order by "dt"
- Error事件趋势图表所关联的查询分析语句如下所示:
select time_series(__time, 'PT1H', 'yyyy-MM-dd HH', '0') as "dt",count(1) as "count" from log where "type" = 'Error' group by "dt" order by "dt"
- Pod OOM事件列表所关联的查询分析语句如下所示:
select TIME_FORMAT( __time, 'yyyy-MM-dd HH:mm:ss', '+08:00') as "Time", "resource_kind" as "事件目标", "name" as "类型", "resource_name" as "目标名", "reason" as "详细内容" from log where "name" in ('OOMKilling','PodOOMKilling') order by __time desc limit 100 - Pod驱动事件列表所关联的查询分析语句如下所示:
select TIME_FORMAT( __time, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as "Time", "resource_kind" as "事件目标", "name" as "类型", "resource_name" as "目标名", "reason" as "详细内容" from log where "name" = 'NodeControllerEviction' order by __time desc limit 100
- 重要事件列表所关联的查询分析语句如下所示:
select TIME_FORMAT( __time, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as "Time", "type" as "等级", "resource_kind" as "事件目标", "name" as "类型", "resource_name" as "目标名", "reason" as "详细内容" from log where "type" in ('Warning','Error') order by __time desc limit 100
查看CCE日志聚合检索
- 在仪表盘模板下方,选择“CCE仪表盘模板 > CCE日志聚合检索”,查看图表详情。
select distinct("objectRef.namespace") - 过滤操作用户,所关联的查询分析语句如下所示:
select distinct("verb") - 过滤资源对象,所关联的查询分析语句如下所示:
select distinct("objectRef.resource") - 过滤请求URL,所关联的查询分析语句如下所示:
select distinct("requestURI") - 过滤userAgent,所关联的查询分析语句如下所示:
select distinct("userAgent")
- 操作用户分布趋势图表所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "user.username" as "操作用户", count(*) as "count" group by dt, "user.username" order by dt limit 10000
- 命名空间分布趋势图表所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.namespace" as "命名空间", count(*) as "count" group by dt, "objectRef.namespace" order by dt limit 10000
- 操作类型分布趋势图表所关联的查询分析语句如下所示:
- 状态码分布趋势图表所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, cast("responseStatus.code" as varchar) as "返回码", count(*) as "count" group by dt, "返回码" order by dt limit 10000 - 资源类型分布趋势图表所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "资源类型", count(*) as "count" group by dt, "objectRef.resource" order by dt limit 10000 SELECT REPLACE(LEFT(stageTimestamp, 16),'T',' ') AS dt, "objectRef.resource" as "资源类型", count(*) as "count" group by dt, "objectRef.resource" order by dt limit 10000
- 重要操作列表所关联的查询分析语句如下所示:
select "auditID" AS "Audit ID", "verb" AS "操作类型", "requestReceivedTimestamp" AS "开始时间", "stageTimestamp" AS "结束时间", "user.username" AS "操作账号", "sourceIPs" AS "操作源","userAgent","objectRef.namespace" AS "命名空间", CONCAT(CONCAT("objectRef.resource", '/'), "objectRef.subresource") AS "操作对象", "objectRef.name" AS "资源名", "responseStatus.code" AS "返回码"
查看CCE日志账号操作审计
- 在仪表盘模板下方,选择“CCE仪表盘模板 > CCE日志账号操作审计”,查看图表详情。
- 过滤用户名,所关联的查询分析语句如下所示:
select distinct("user.username") - 过滤命名空间,所关联的查询分析语句如下所示:
select distinct("objectRef.namespace") - 过滤状态码,所关联的查询分析语句如下所示:
- 资源创建数图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where "verb" = 'create') )
- 资源修改数图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(*) as "total" from log where "verb" in ('update','patch')) ) - 资源删除数图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(*) as "total" from log where "verb" = 'delete') )
- 操作命名空间分布图表所关联的查询分析语句如下所示:
select case when "objectRef.namespace" is null then '_all__' else "objectRef.namespace" end as ns, count(1) as total group by ns limit 10000
- 删除资源分布图表所关联的查询分析语句如下所示:
SELECT "objectRef.resource" as "resource", count(1) as "count" where "verb" = 'delete' group by "resource"
- 操作轨迹图表所关联的查询分析语句如下所示:
select case when "操作" is null then '无' else "操作" end as "操作", "时间", v from (select concat(CASE WHEN "objectRef.subresource" is null then "objectRef.resource" else "objectRef.subresource" end, '[', verb, ']' ) as "操作", time_series(__time, 'PT1H', 'yyyy-MM-dd HH', '0') as "时间", count(1) as v from log where "verb" in ('create', 'patch', 'update', 'delete') group by "操作", "时间" order by "时间" desc limit 10000 ) - 资源操作分布图表所关联的查询分析语句如下所示:
select CASE WHEN "objectRef.subresource" is null then "objectRef.resource" else "objectRef.subresource" end as "资源", verb as "操作", count(1) as total where "verb" in ('create','update','patch','delete') group by "资源", "操作" limit 10000 - 创建资源列表所关联的查询分析语句如下所示:
SELECT "auditID" as "事件ID", time_format("__time",'yyyy-MM-dd HH:mm:ss') as "操作时间", "requestURI" as "资源", "objectRef.name" as "资源名", "responseStatus.code" as "状态码","sourceIPs" as "源地址", "requestObject" as "详细内容" where "verb" = 'create' order by __time desc limit 1000 - 修改资源列表所关联的查询分析语句如下所示:
SELECT auditID as "事件ID", time_format("__time",'yyyy-MM-dd HH:mm:ss') as "操作时间","requestURI" as "资源", "objectRef.name" as "资源名", "responseStatus.code" as "状态码","sourceIPs" as "源地址", requestObject as "详细内容" where "verb" in ('update','patch') order by __time desc limit 1000 - 资源访问列表所关联的查询分析语句如下所示:
SELECT auditID as "事件ID", time_format("__time",'yyyy-MM-dd HH:mm:ss') as "操作时间", "requestURI" as "资源", "objectRef.name" as "资源名", "responseStatus.code" as "状态码","sourceIPs" as "源地址", requestObject as "详细内容" where "verb" in ('get','list') order by __time desc limit 1000 - 资源删除列表所关联的查询分析语句如下所示:
SELECT auditID as "事件ID", time_format("__time",'yyyy-MM-dd HH:mm:ss') as "操作时间", "requestURI" as "资源", "objectRef.name" as "资源名", "responseStatus.code" as "状态码","sourceIPs" as "源地址", requestObject as "详细内容" where "verb" = 'delete' order by __time desc limit 1000
查看CCE日志审计中心
- 在仪表盘模板下方,选择“CCE仪表盘模板 > CCE日志审计中心”,查看图表详情。
select distinct("user.username") - 过滤操作类型,所关联的查询分析语句如下所示:
select distinct("requestURI") - 过滤UserAgent,所关联的查询分析语句如下所示:
- 总审计记录数图表所关联的查询分析语句如下所示:
select diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log ) )
- 操作用户数图表所关联的查询分析语句如下所示:
select diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(distinct("user.username")) as total from log ) ) - 活跃节点数图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(DISTINCT "user.username") as total from log where "objectRef.resource" = 'nodes' and "objectRef.subresource" = 'status' and "verb" in ('update','put','patch') and "user.username" in ('node','system')) ) - 异常访问次数图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where "responseStatus.code" >= 400) )
- 敏感操作次数图表所关联的查询分析语句如下所示:
select diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as "total" from log where ("verb" = 'create' AND "objectRef.subresource" = 'exec') OR ("verb" = 'create' AND "objectRef.subresource" = 'attach' AND "objectRef.resource" = 'pods') OR ("objectRef.resource" = 'secrets' AND "verb"= 'get' AND ( "user.username" != 'apiserver') AND ("user.username" not like 'system:node:%')) OR ("verb"= 'delete' AND ( "user.username" not like 'system:node:%') AND ( "user.username" not like 'system:serviceaccount:kube-system:%') AND ( "user.username" != 'system:apiserver') AND ( "user.username" != 'system:apiserver') AND ( "user.username" != 'system:kube-scheduler') AND ("user.username" != 'system:kube-controller-manager'))) ) - 创建操作次数图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where verb = 'create') )
- 更新操作次数图表所关联的查询分析语句如下所示:
select diff[1] as "total" , round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where verb in ('update','patch')) ) - 删除操作次数图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100 , 2 ) as "inc" from (select compare( total , 86400) as diff from( select count(1) as total from log where verb = 'delete') )
- 操作用户分布图表所关联的查询分析语句如下所示:
select "user.username" as "用户名", count(*) as "count" group by "用户名" order by "count" desc
- 命名空间分布图表所关联的查询分析语句如下所示:
select "objectRef.namespace" as "命名空间", count(*) as "count" group by "命名空间"
- 资源类型分布图表所关联的查询分析语句如下所示:
select "objectRef.resource" as "资源类型", count(*) as "count" group by "资源类型" order by "count" desc limit 20
- 操作类型分布图表所关联的查询分析语句如下所示:
select verb as "操作类型", count(*) as "count" group by "操作类型" order by "count" desc
- 节点操作分布图表所关联的查询分析语句如下所示:
select "verb" as "操作类型", count(*) as "count" where "objectRef.resource" = 'nodes' AND ("verb" in ('create','delete') ) group by "操作类型" order by "count" desc - 工作负载操作分布图表所关联的查询分析语句如下所示:
select "verb" as "操作类型", count(*) as "count" where "verb" in ('create', 'delete') and "objectRef.resource" in ('deployments','statefulsets','daemonsets','jobs','cronjobs') group by "操作类型" order by "count" desc - Service/Ingress操作分布图表所关联的查询分析语句如下所示:
select "verb" as "操作类型", count(*) as "count" where "verb" in ('create', 'delete') and "objectRef.resource" in ('ingresses','services') group by "verb" order by "count" desc - 重要操作趋势图表所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT("stageTimestamp", 16),'T',' ') AS "dt", "verb", count(*) as "count" where "verb" in ('create','delete','update','patch') group by "dt", "verb" order by "dt" limit 10000 - 非系统用户操作趋势图表所关联的查询分析语句如下所示:
SELECT REPLACE(LEFT("stageTimestamp", 16),'T',' ') AS "dt", count(*) as "count", "user.username" as "用户名称" where "user.username" not in ('kube-controller-manager','kube-apiserver-kubelet-client','system','apiserver') group by "dt", "用户名称" order by "dt" limit 10000
