更新时间:2025-09-08
WAF仪表盘模板
Web应用防火墙(Web Application Firewall, WAF),通过对HTTP(S)请求进行检测,识别并阻断SQL注入、跨站脚本攻击、网页木马上传、命令/代码注入、文件包含、敏感文件访问、第三方应用漏洞攻击、CC攻击、恶意爬虫扫描、跨站请求伪造等攻击,保护Web服务安全稳定。
使用日志搜索与分析(即将下线SQL分析方式)时,对应的WAF仪表盘模板支持查看WAF安全日志中心和查看WAF访问日志中心。
前提条件
- 已采集WAF日志,详情请参考Web应用防火墙WAF接入LTS。
- 日志配置结构化,详情请参见设置云端结构化解析日志。
查看WAF安全日志中心
- 登录云日志服务控制台,进入“日志管理”页面。
- 在左侧导航栏中选择“仪表盘”。
- 在仪表盘模板下方,选择“WAF仪表盘模板 > WAF安全日志中心”,查看图表详情。
- 被攻击网站图表所关联的查询分析语句如下所示:
SELECT diff [ 1 ] AS "VALUE", COALESCE ( diff [ 1 ]- diff [ 2 ], 0 ) AS "BEFORE" FROM ( SELECT compare ( "DATA", 86400 ) AS diff FROM ( SELECT count( DISTINCT "host" ) AS "DATA" FROM log WHERE action != '' )) - 攻击来源国家图表所关联的查询分析语句如下所示:
SELECT diff [ 1 ] AS "VALUE" , COALESCE ( diff [ 1 ]- diff [ 2 ], 0 ) AS "BEFORE" FROM ( SELECT compare ( "DATA", 86400 ) AS diff FROM ( SELECT count( DISTINCT ip_to_country ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END) ) AS "DATA" FROM log WHERE action != '' ) ) - Web攻击拦截图表所关联的查询分析语句如下所示:
SELECT CASE WHEN diff [ 1 ] < 1000 THEN concat( cast( diff [ 1 ] AS VARCHAR ), ' 次' ) WHEN diff [ 1 ] < 1000 * 1000 THEN concat( cast( round( diff [ 1 ]/ 1000, 1 ) AS VARCHAR ), ' 千次' ) WHEN diff [ 1 ] < 1000000000 THEN concat( cast( round( diff [ 1 ]/ 1000000.0, 1 ) AS VARCHAR ), ' 百万次' ) WHEN diff [ 1 ]/ 1000.0 < 1000000000 THEN concat( cast( round( diff [ 1 ]/ 1000.0 / 1000000, 1 ) AS VARCHAR ), ' 十亿次' ) ELSE concat( cast( round( diff [ 1 ]/ 1000.0 / 1000 / 1000 / 1000, 1 ) AS VARCHAR ), ' 万亿次' ) END AS "value" , CASE WHEN diff [ 2 ]= 0 THEN 0 ELSE round( diff [ 3 ]- 1, 2 ) END AS ratio FROM ( SELECT compare ( "data", 86400 ) AS diff FROM ( SELECT count( 1 ) AS "data" FROM log WHERE action = '' ) ) - CC攻击拦截图表所关联的查询分析语句如下所示:
SELECT CASE WHEN diff [ 1 ] < 1000 THEN concat( cast( diff [ 1 ] AS VARCHAR ), ' 次' ) WHEN diff [ 1 ] < 1000 * 1000 THEN concat( cast( round( diff [ 1 ]/ 1000, 1 ) AS VARCHAR ), ' 千次' ) WHEN diff [ 1 ] < 1000000000 THEN concat( cast( round( diff [ 1 ]/ 1000000.0, 1 ) AS VARCHAR ), ' 百万次' ) WHEN diff [ 1 ]/ 1000.0 < 1000000000 THEN concat( cast( round( diff [ 1 ]/ 1000.0 / 1000000, 1 ) AS VARCHAR ), ' 十亿次' ) ELSE concat( cast( round( diff [ 1 ]/ 1000.0 / 1000 / 1000 / 1000, 1 ) AS VARCHAR ), ' 万亿次' ) END AS "value" , CASE WHEN diff [ 2 ]= 0 THEN 0 ELSE round( diff [ 3 ]- 1, 2 ) END AS ratio FROM ( SELECT compare ( "data", 86400 ) AS diff FROM ( SELECT count( 1 ) AS "data" FROM log WHERE attack != 'default') ) - 攻击者UV图表所关联的查询分析语句如下所示:
SELECT CASE WHEN diff [ 1 ] < 1000 THEN concat( cast( cast ( diff [ 1 ] AS INTEGER ) AS VARCHAR ), ' 个' ) WHEN diff [ 1 ] < 1000 * 1000 THEN concat( cast( round( diff [ 1 ]/ 1000, 1 ) AS VARCHAR ), ' 千个' ) WHEN diff [ 1 ] < 1000000000 THEN concat( cast( round( diff [ 1 ]/ 1000000.0, 1 ) AS VARCHAR ), ' 百万个' ) WHEN diff [ 1 ]/ 1000.0 < 1000000000 THEN concat( cast( round( diff [ 1 ]/ 1000.0 / 1000000, 1 ) AS VARCHAR ), ' 十亿' ) ELSE concat( cast( round( diff [ 1 ]/ 1000.0 / 1000 / 1000 / 1000, 1 ) AS VARCHAR ), ' 万亿' ) END AS "value", CASE WHEN diff [ 2 ]= 0 THEN 0 ELSE round( diff [ 3 ]- 1, 2 ) END AS ratio FROM ( SELECT compare ( "data", 86400 ) AS diff FROM ( SELECT count( DISTINCT CASE WHEN sip = '-' THEN remote_ip ELSE sip END ) AS "data" FROM log )) - 攻击拦截图表所关联的查询分析语句如下所示:
SELECT CASE WHEN diff [ 1 ] < 1000 THEN concat( cast( diff [ 1 ] AS VARCHAR ), ' 次' ) WHEN diff [ 1 ] < 1000 * 1000 THEN concat( cast( round( diff [ 1 ]/ 1000, 1 ) AS VARCHAR ), ' 千次' ) WHEN diff [ 1 ] < 1000000000 THEN concat( cast( round( diff [ 1 ]/ 1000000.0, 1 ) AS VARCHAR ), ' 百万次' ) WHEN diff [ 1 ]/ 1000.0 < 1000000000 THEN concat( cast( round( diff [ 1 ]/ 1000.0 / 1000000, 1 ) AS VARCHAR ), ' 十亿次' ) ELSE concat( cast( round( diff [ 1 ]/ 1000.0 / 1000 / 1000 / 1000, 1 ) AS VARCHAR ), ' 万亿次' ) END AS "value", CASE WHEN diff [ 2 ]= 0 THEN 0 ELSE round( diff [ 3 ]- 1, 2 ) END AS "ratio" FROM ( SELECT compare ( "data", 86400 ) AS diff FROM ( SELECT count( 1 ) AS "data" FROM log WHERE action != '') ) - CC攻击图表所关联的查询分析语如下所示:
SELECT ip_to_province (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS province, count( 1 ) AS "攻击次数" WHERE attack != 'default' and ip_to_country(CASE WHEN sip = '-' THEN remote_ip ELSE sip END) = '中国' GROUP BY province - 攻击类型分布图表所关联的查询分析语句如下所示:
SELECT time_format( MILLIS_TO_TIMESTAMP( TIMESTAMP_TO_MILLIS(__time) - MOD(TIMESTAMP_TO_MILLIS(__time), 3600)), 'HH:mm' ) AS dt, count( 1 ) AS cnt, CASE WHEN action = 'block' THEN '拦截' WHEN action = 'log' THEN '仅记录' WHEN action = 'captcha' THEN '人机验证' END AS attack FROM log WHERE action != '' GROUP BY TIMESTAMP_TO_MILLIS(__time) - MOD(TIMESTAMP_TO_MILLIS(__time), 3600), attack ORDER BY cnt DESC
- Web攻击图表所关联的查询分析语句如下所示:
SELECT ip_to_province ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS province, count( 1 ) AS "攻击次数" WHERE action = 'block' and ip_to_country(CASE WHEN sip = '-' THEN remote_ip ELSE sip END) = '中国' GROUP BY province - CC攻击(世界)图表所关联的查询分析语句如下所示:
SELECT ip_to_country (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS country, count( 1 ) AS "攻击次数" WHERE attack != 'default' GROUP BY country - Web攻击(世界)图表所关联的查询分析语句如下所示:
SELECT ip_to_country (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS country, count( 1 ) AS "攻击次数" WHERE action = 'block' GROUP BY country
查看WAF访问日志中心
- 在仪表盘模板下方,选择“WAF仪表盘模板 > WAF访问日志中心”,查看图表详情。
- PV图表所关联的查询分析语句如下所示:
SELECT CASE WHEN diff [ 1 ] < 1000 THEN concat( cast( diff [ 1 ] AS VARCHAR ), ' 次' ) WHEN diff [ 1 ] < 1000 * 1000 THEN concat( cast( round( diff [ 1 ]/ 1000, 1 ) AS VARCHAR ), ' 千次' ) WHEN diff [ 1 ] < 1000000000 THEN concat( cast( round( diff [ 1 ]/ 1000000.0, 1 ) AS VARCHAR ), ' 百万次' ) WHEN diff [ 1 ]/ 1000.0 < 1000000000 THEN concat( cast( round( diff [ 1 ]/ 1000 / 1000000.0, 1 ) AS VARCHAR ), ' 十亿次' ) ELSE concat( cast( round( diff [ 1 ]/ 1000.0 / 1000 / 1000 / 1000, 1 ) AS VARCHAR ), ' 万亿次' ) END AS "VALUE" , CASE WHEN diff [ 2 ]= 0 THEN 0 ELSE round( diff [ 3 ]- 1, 2 ) END AS ratio FROM ( SELECT compare ( DATA, 86400 ) AS diff FROM ( SELECT count( 1 ) AS DATA FROM log ) )
- UV图表所关联的查询分析语句如下所示:
SELECT CASE WHEN diff [ 1 ] < 1000 THEN concat( cast( diff [ 1 ] AS VARCHAR ), ' 次' ) WHEN diff [ 1 ] < 1000 * 1000 THEN concat( cast( round( diff [ 1 ]/ 1000, 1 ) AS VARCHAR ), ' 千次' ) WHEN diff [ 1 ] < 1000000000 THEN concat( cast( round( diff [ 1 ]/ 1000000.0, 1 ) AS VARCHAR ), ' 百万次' ) WHEN diff [ 1 ]/ 1000.0 < 1000000000 THEN concat( cast( round( diff [ 1 ]/ 1000 / 1000000.0, 1 ) AS VARCHAR ), ' 十亿次' ) ELSE concat( cast( round( diff [ 1 ]/ 1000.0 / 1000 / 1000 / 1000, 1 ) AS VARCHAR ), ' 万亿次' ) END AS "VALUE" , CASE WHEN diff [ 2 ]= 0 THEN 0 ELSE round( diff [ 3 ]- 1, 2 ) END AS ratio FROM ( SELECT compare ( DATA, 86400 ) AS diff FROM ( SELECT count( DISTINCT CASE WHEN sip = '-' THEN remote_ip ELSE sip END ) AS "DATA" FROM log ) )
- 流入流量图表所关联的查询分析语句如下所示:
SELECT CASE WHEN diff [ 1 ] < 102 THEN concat( cast( diff [ 1 ] AS VARCHAR ), ' B' ) WHEN diff [ 1 ] < 1024 * 1024 THEN concat( cast( round( diff [ 1 ]/ 1024, 1 ) AS VARCHAR ), ' KB' ) WHEN diff [ 1 ] < 1024 * 1024 * 1024 THEN concat( cast( round( diff [ 1 ]/ 1024.0 / 1024, 1 ) AS VARCHAR ), ' MB' ) WHEN diff [ 1 ]/ 1024.0 < 1024 * 1024 * 1024 THEN concat( cast( round( diff [ 1 ]/ 1024.0 / 1024 / 1024, 1 ) AS VARCHAR ), ' GB' ) ELSE concat( cast( round( diff [ 1 ]/ 1024.0 / 1024 / 1024 / 1024, 1 ) AS VARCHAR ), ' TB' ) END AS "VALUE" , CASE WHEN diff [ 2 ]= 0 THEN 0 ELSE round( diff [ 3 ]- 1, 2 ) END AS ratio FROM ( SELECT compare ( "DATA", 86400 ) AS diff FROM ( SELECT COALESCE ( sum( request_length ), 0 ) AS "DATA" FROM log ) )
- 网络in带宽峰值图表所关联的查询分析语句如下所示:
SELECT CASE WHEN diff [ 1 ] < 102 THEN concat( cast( round( diff [ 1 ], 2 ) AS VARCHAR ), ' B/s' ) WHEN diff [ 1 ] < 1024 * 1024 THEN concat( cast( round( diff [ 1 ]/ 1024, 1 ) AS VARCHAR ), ' KB/s' ) WHEN diff [ 1 ] < 1024 * 1024 * 1024 THEN concat( cast( round( diff [ 1 ]/ 1024.0 / 1024, 1 ) AS VARCHAR ), ' MB/s' ) WHEN diff [ 1 ]/ 1024.0 < 1024 * 1024 * 1024 THEN concat( cast( round( diff [ 1 ]/ 1024.0 / 1024 / 1024, 1 ) AS VARCHAR ), ' GB/s' ) ELSE concat( cast( round( diff [ 1 ]/ 1024.0 / 1024 / 1024 / 1024, 1 ) AS VARCHAR ), ' TB/s' ) END AS "VALUE" , CASE WHEN diff [ 2 ]= 0 THEN 0 ELSE round( diff [ 3 ]- 1, 2 ) END AS ratio FROM ( SELECT compare ( "DATA", 86400 ) AS diff FROM ( SELECT COALESCE ( max( "DATA" ), 0 ) AS "DATA" FROM ( SELECT TIME_FLOOR(__time,'PT1M') AS dt, sum( request_length )/ 60.0 AS "DATA" FROM log GROUP BY dt LIMIT 10000 )) )
- 网络out带宽峰值图表所关联的查询分析语句如下所示:
SELECT CASE WHEN diff [ 1 ] < 102 THEN concat( cast( round( diff [ 1 ], 2 ) AS VARCHAR ), ' B/s' ) WHEN diff [ 1 ] < 1024 * 1024 THEN concat( cast( round( diff [ 1 ]/ 1024, 1 ) AS VARCHAR ), ' KB/s' ) WHEN diff [ 1 ] < 1024 * 1024 * 1024 THEN concat( cast( round( diff [ 1 ]/ 1024.0 / 1024, 1 ) AS VARCHAR ), ' MB/s' ) WHEN diff [ 1 ]/ 1024.0 < 1024 * 1024 * 1024 THEN concat( cast( round( diff [ 1 ]/ 1024.0 / 1024 / 1024, 1 ) AS VARCHAR ), ' GB/s' ) ELSE concat( cast( round( diff [ 1 ]/ 1024.0 / 1024 / 1024 / 1024, 1 ) AS VARCHAR ), ' TB/s' ) END AS "value", case when diff [ 2 ]= 0 then 0 else round( diff [ 3 ]- 1, 2 ) END AS "ratio" FROM ( SELECT compare ( "DATA", 86400 ) AS diff FROM ( SELECT COALESCE ( max( bytes_out ), 0 ) AS "DATA" FROM ( SELECT time_ceil( __time,'PT1M') AS dt, sum( body_bytes_sent )/ 60.0 AS bytes_out FROM log GROUP BY dt LIMIT 10000 )))
- 流量带宽趋势图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT( MILLIS_TO_TIMESTAMP( TIMESTAMP_TO_MILLIS(__time) - MOD(TIMESTAMP_TO_MILLIS(__time) , 600000)), 'HH:mm' ) AS dt, round( sum( request_length )/ 1024.0 / 600, 2 ) AS "流入流量(KB/s)", round( sum( body_bytes_sent )/ 1024.0 / 600, 2 ) AS "流出流量(KB/s)" where request_length is not null GROUP BY TIMESTAMP_TO_MILLIS(__time) - MOD(TIMESTAMP_TO_MILLIS(__time) , 600000) ORDER BY dt LIMIT 1000
- PV/UV趋势图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT(MILLIS_TO_TIMESTAMP( TIMESTAMP_TO_MILLIS(__time) - MOD(TIMESTAMP_TO_MILLIS(__time) , 3600000)) , 'HH:mm' ) AS dt, count( 1 ) AS PV, APPROX_COUNT_DISTINCT (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS UV FROM log GROUP BY TIMESTAMP_TO_MILLIS(__time) - MOD(TIMESTAMP_TO_MILLIS(__time) , 3600000) ORDER BY dt LIMIT 1000
- 访问状态分布图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT(MILLIS_TO_TIMESTAMP( TIMESTAMP_TO_MILLIS(__time) - MOD(TIMESTAMP_TO_MILLIS(__time) , 3600000)) , 'HH:mm' ) AS dt, count( 1 ) AS cnt, concat( cast( "response_code" / 100 AS VARCHAR ), 'XX' ) AS "status" GROUP BY TIMESTAMP_TO_MILLIS(__time) - MOD(TIMESTAMP_TO_MILLIS(__time) , 3600000) , "response_code" / 100 ORDER BY dt DESC LIMIT 10000
- 访问来源图表所关联的查询分析语句如下所示:
SELECT ip_to_province (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS country, count( 1 ) AS "访问次数" where ip_to_country(CASE WHEN sip = '-' THEN remote_ip ELSE sip END) = '中国' GROUP BY country
- 流入流量来源(中国)图表所关联的查询分析语句如下所示:
SELECT ip_to_province (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS region, round( sum( request_length )/ 1024.0 / 1024, 4 ) AS "流入流量(MB)" where ip_to_country(CASE WHEN sip = '-' THEN remote_ip ELSE sip END) = '中国' GROUP BY region
- 流入流量来源(世界)图表所关联的查询分析语句如下所示:
SELECT ip_to_country (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS region, round( sum( request_length )/ 1024.0 / 1024, 4 ) AS "流入流量(MB)" where request_length is not null GROUP BY region
- 来源网络提供商图表所关联的查询分析语句如下所示:
SELECT ip_to_provider (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) AS provider, round( sum( request_length )/ 1024.0 / 1024.0, 3 ) AS mb_in GROUP BY provider HAVING ip_to_provider (CASE WHEN sip = '-' THEN remote_ip ELSE sip END) != '*' ORDER BY mb_in DESC LIMIT 10
- 访问域名图表所关联的查询分析语句如下所示:
SELECT http_host, count( 1 ) AS "被访问次数" GROUP BY http_host ORDER BY "被访问次数" DESC LIMIT 30
- 响应最慢的URL图表所关联的查询分析语句如下所示:
SELECT http_host AS "网站",url_extract_path (COALESCE ( url, '/' )) AS URL,sum( request_time )/ count( 1 ) AS "响应时间(毫秒)",count( 1 ) AS "访问次数" GROUP BY http_host, url ORDER BY "响应时间(毫秒)" DESC LIMIT 100
- 访问最多的客户端图表所关联的查询分析语句如下所示:
SELECT ip AS "客户端", client AS "地理网络", concat( cast( (CASE WHEN pv IS NULL THEN 0 ELSE pv END) AS VARCHAR ), ' (', cast( case when head_pv = 'null' then 0 else (case when head_pv > 0 then head_pv else 0 end) end AS VARCHAR ), '/', cast( case when get_pv = 'null' then 0 else (case when get_pv > 0 then get_pv else 0 end) end AS VARCHAR ), '/', cast( case when put_pv = 'null' then 0 else (case when put_pv > 0 then put_pv else 0 end) end AS VARCHAR ), '/', cast( case when post_pv = 'null' then 0 else (case when post_pv > 0 then post_pv else 0 end) end AS VARCHAR ), '/', cast( case when delete_pv = 'null' then 0 else (case when delete_pv > 0 then delete_pv else 0 end) end AS VARCHAR ), '/', ')' ) AS "PV (Head, Get, Put, Post, Delete方法)", error_count AS "错误访问次数" FROM ( SELECT ip, client, sum( CASE WHEN "method" = 'PUT' AND "status" < 400 THEN pv ELSE 0 END ) AS put_pv, sum( CASE WHEN "method" = 'GET' AND "status" < 400 THEN pv ELSE 0 END ) AS get_pv, sum( CASE WHEN "method" = 'POST' AND "status" < 400 THEN pv ELSE 0 END ) AS post_pv, sum( CASE WHEN "method" = 'DELETE' AND "status" < 400 THEN pv ELSE 0 END ) AS delete_pv, sum( CASE WHEN "method" = 'HEAD' AND "status" < 400 THEN pv ELSE 0 END ) AS head_pv, sum( throughput ) AS throughput, sum( pv ) AS pv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) AS error_count FROM ( SELECT CASE WHEN sip = '-' THEN remote_ip ELSE sip END AS ip, "method", CASE WHEN ip_to_country ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END )= '上海' THEN '中国上海' WHEN ip_to_province ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END )= '*' THEN '未知IP' WHEN ip_to_provider ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END )= '内网IP' THEN '内网IP' ELSE concat( ip_to_country ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END ), '/', ip_to_province ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END ), '/', CASE WHEN ip_to_city ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END )= '*' THEN ' ' ELSE ip_to_city ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END ) END, ' ', ip_to_provider ( CASE WHEN sip = '-' THEN remote_ip ELSE sip END )) END AS client, sum( CASE WHEN "response_code" < 400 THEN 1 ELSE 0 END ) AS pv, round( sum( request_length )/ 1024.0 / 1024, 1 ) AS throughput, "response_code" AS "status" FROM log GROUP BY ip, client, "method", "response_code" ORDER BY pv DESC, client, "method" LIMIT 1000 ) GROUP BY ip, client ORDER BY pv DESC ) LIMIT 100
