APIG秒级监控
APIG秒级监控仪表盘主要展示Upstream状态码等信息,全方位展示网站访问情况。您还可以使用云日志服务的查询分析语句,分析网站的延时情况,及时调优网站。
背景信息
APIG(API Gateway)提供高性能、高可用、高安全的API托管服务,能快速将企业服务能力包装成标准API服务,帮助您轻松构建、管理和部署任意规模的API,并上架API云商店进行售卖。借助API网关,可以简单、快速、低成本、低风险地实现内部系统集成、业务能力开放及业务能力变现。API网关帮助您变现服务能力的同时,降低企业研发投入,让您专注于企业核心业务,提升运营效率。
分析APIG监控情况
- 登录云日志服务控制台,在左侧导航栏中选择“日志管理”。
- 在“日志应用”模块中,单击“APIG日志中心”,选择“进入仪表盘”。
- 单击左上角下拉框,在仪表盘模板下方,选择“APIG仪表盘模板>APIG秒级监控”仪表盘,查看图表详情。
重要图表说明
APIG秒级监控仪表盘中的重要图表说明如下所示:
- QPS图展示QPS的变化情况,所关联的查询分析语句如下所示:
SELECT TIME_FORMAT(TIME_CEIL(__time,'PT1S'),'yyyy-MM-dd HH:mm:ss','+08:00') AS _time_ , COUNT(*) as QPS from log group by _time_
- 成功率图展示成功率的变化情况,所关联的查询分析语句如下所示:
select __time,round(CASE WHEN "成功率" > 0 THEN "成功率" else 0 end,2) as "成功率" from (select TIME_FORMAT(TIME_CEIL(__time,'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time, sum(case when status < 400 then 1 else 0 end) * 100.0 / count(1) as '成功率' from log group by __time)
- 延迟图展示访问延时的变化情况,所关联的查询分析语句如下所示:
select __time,round(CASE WHEN "访问延迟" > 0 THEN "访问延迟" else 0 end,2) as "访问延迟",round(CASE WHEN "Upstream延迟" > 0 THEN "Upstream延迟" else 0 end,2) as "Upstream延迟" from (select TIME_FORMAT(TIME_CEIL(__time,'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time, avg(request_time)* 1000 as '访问延迟',avg(upstream_response_time)* 1000 as 'Upstream延迟' from log group by __time)
- 流量图展示请求流量和返回body流量的变化情况,所关联的查询分析语句如下所示:
select TIME_FORMAT(TIME_CEIL(__time,'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time , sum("request_length") as "请求流量", sum("body_bytes_sent") as "返回body流量" group by __time
- 状态码图展示响应状态码的变化情况,所关联的查询分析语句如下所示:
select t.t as "time", CASE WHEN a."2XX" IS NOT NULL THEN CAST(a."2XX" AS BIGINT) ELSE 0 END as "2XX", CASE WHEN b."3XX" IS NOT NULL THEN CAST(b."3XX" AS BIGINT) ELSE 0 END as "3XX", CASE WHEN c."4XX" IS NOT NULL THEN CAST(c."4XX" AS BIGINT) ELSE 0 END as "4XX", CASE WHEN d."5XX" IS NOT NULL THEN CAST(d."5XX" AS BIGINT) ELSE 0 END as "5XX", CASE WHEN e."其他" IS NOT NULL THEN CAST(e."其他" AS BIGINT) ELSE 0 END as "其他" from( select TIME_CEIL(__time,'PT5S') as t from log group by t order by t asc ) t left join ( select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "2XX" from log WHERE "status" >= 200 and "status" < 300 group by t order by t asc ) a on t.t =a.t left join ( select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "3XX" from log WHERE "status" >= 300 and "status" < 400 group by t order by t asc) b on t.t =b.t left join ( select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "4XX" from log WHERE "status" >= 400 and "status" < 500 group by t order by t asc) c on t.t =c.t left join ( select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "5XX" from log WHERE "status" >= 500 and "status" < 600 group by t order by t asc) d on t.t =d.t left join ( select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "其他" from log WHERE "status" < 200 or "status" >= 600 group by t order by t asc) e on t.t =e.t
- 后端响应码图展示后端响应状态码的变化情况,所关联的查询分析语句如下所示:
SELECT TIME_CEIL ( TIME_PARSE ( time_local, 'dd/MMM/yyyy:HH:mm:ss' ), 'PT5S' ) AS "time", SUM( CASE WHEN "upstream_status" >= 200 AND "upstream_status" < 300 THEN 1 ELSE 0 END ) AS "2XX", SUM( CASE WHEN "upstream_status" >= 300 AND "upstream_status" < 400 THEN 1 ELSE 0 END ) AS "3XX", SUM( CASE WHEN "upstream_status" >= 400 AND "upstream_status" < 500 THEN 1 ELSE 0 END ) AS "4XX", SUM( CASE WHEN "upstream_status" >= 500 AND "upstream_status" < 600 THEN 1 ELSE 0 END ) AS "5XX", SUM( CASE WHEN "upstream_status" < 200 OR "upstream_status" >= 600 THEN 1 ELSE 0 END ) AS "其他" FROM log WHERE TIME_PARSE ( time_local, 'dd/MMM/yyyy:HH:mm:ss' ) IS NOT NULL GROUP BY "time" ORDER BY "time" ASC LIMIT 100000
