更新时间:2026-09-16 GMT+08:00
应用侧对接
属性上报
以下消息转换为IoTDA平台的属性,应用可以通过查询设备影子或者数据转发接收属性上报消息。
上报位置信息
对应的消息ID:0x0200
推送样例:
  "resource": "device.property",
  "event": "report",
  "event_time": "20151212T121212Z",
  "notify_data": {
    "header": {
      "device_id": "00000000000012345678",
      "product_id": "ABC123456789",
      "app_id": "d4922d8a-6c8e-4396-852c-164aefa6638f",
      "gateway_id": "00000000000012345678",
      "node_id": "00000000000012345678",
      "tags": [
          "tag_value": "testTagValue",
          "tag_key": "testTagName"
    "body": {
      "services": [
          "service_id": "Location",
          "properties": {
            "alarm": {
              "emergencyAlarm": 0,
              "overSpeedAlarm": 0,
              "fatigueDrivingAlarm": 0,
              "dangerousDrivingAlarm": 0,
              "powerVoltageAlarm": 0,
              "powerOffAlarm": 0,
              "cameraErrorAlarm": 0,
              "overSpeedWarning": 0,
              "fatigueDrivingWarning": 0,
              "violationDrivingAlarm": 0,
              "tirePressureWarning": 0,
              "rightTurnErrorAlarm": 0,
              "overDrivingTimeAlarm": 0,
              "overParkAlarm": 0,
              "drivingAreaAlarm": 0,
              "drivingRouteAlarm": 0,
              "drivingTimeAbnormalAlarm": 0,
              "offCourseAlarm": 0,
              "gasolineAlarm": 0,
              "stolenAlarm": 0,
              "startingAbnormalAlarm": 0,
              "displacementAbnormalAlarm": 0,
              "rolloverAlarm": 0,
              "rolloverWarning": 0,
              "icerrorAlarm": 0,
              "lcderrorAlarm": 0,
              "ttserrorAlarm": 1,
              "gnssantennaShortCircuitAlarm": 0,
              "gnsserrorAlarm": 0,
              "gnssantennaNotConnectedAlarm": 0,
              "vssalarm": 0
            "status": {
              "accStatus": 0,
              "positioningStatus": 0,
              "latitudeStatus": 0,
              "longitudeStatus": 0,
              "businessStatus": 0,
              "encryptedStatus": 0,
              "forwardCollisionWarningStatus": 0,
              "laneDeviationAlarmStatus": 0,
              "loadStatus": 0,
              "oilStatus": 0,
              "powerStatus": 1,
              "doorStatus": 0,
              "firstDoorStatus": 0,
              "secondDoorStatus": 0,
              "thirdDoorStatus": 0,
              "fourthDoorStatus": 0,
              "fifthDoorStatus": 0,
              "galileoStatus": 0,
              "vehicleStatus": 0,
              "gpsstatus": 0,
              "glonassstatus": 0,
              "bdsstatus": 0
            "longitude": 116.307629,
            "latitude": 40.058359,
            "height": 312,
            "speed": 3,
            "direction": 99,
            "dateTime": "200707192359",
            "extend": [
表1 协议报文字段与属性对应表
起始字节
字段
数据类型
对应属性
0
报警标志
DWORD
alarm
4
状态
DWORD
status
8
纬度
DWORD
latitude
12
经度
DWORD
longitude
16
高程
WORD
height
18
速度
WORD
speed
20
方向
WORD
direction
21
时间
BCD[6]
dateTime
表2 报警预警标志位与alarm属性对应表
位
定义
对应属性
0
1:紧急报警
emergencyAlarm
1:超速报警
overSpeedAlarm
2
1:疲劳驾驶报警
fatigueDrivingAlarm
3
1:危险驾驶行为报警
4
1:GNSS模块发生故障报警
gnsserrorAlarm
5
1:GNSS天线未接或被剪断报警
6
1:GNSS天线短路报警
7
1:终端主电源欠压报警
powerVoltageAlarm
8
1:终端主电源掉电报警
powerOffAlarm
9
1:终端LCD或显示器故障报警
lcderrorAlarm
10
1:TTS模块故障报警
ttserrorAlarm
11
1:摄像头故障报警
cameraErrorAlarm
12
1:道路运输证IC卡模块故障报警
icerrorAlarm
13
1:超速预警
overSpeedWarning
14
1:疲劳驾驶预警
15
1:违规行驶报警
16
1:胎压预警
tirePressureWarning
17
1:右转盲区异常报警
rightTurnErrorAlarm
18
1:当天累计驾驶超时报警
19
1:超时停车报警
overParkAlarm
20
1:进出区域报警
drivingAreaAlarm
21
1:进出路线报警
drivingRouteAlarm
22
1:路段行驶时间不足/过长报警
23
1:路线偏离报警
offCourseAlarm
24
1:车辆VSS故障
vssalarm
25
1:车辆油量异常报警
gasolineAlarm
26
1:车辆被盗报警(通过车辆防盗器)
stolenAlarm
27
1:车辆非法点火报警
28
1:车辆非法位移报警
29
1:碰撞侧翻报警
rolloverAlarm
30
1:侧翻预警
rolloverWarning
31
保留
表3 状态标志位与status属性对应表
位
定义
对应属性
0
0:ACC关;1:ACC开
accStatus
0:未定位;1:定位
positioningStatus
2
0:北纬;1:南纬
latitudeStatus
3
0:东经;1:西经
longitudeStatus
4
0:运营状态;1:停运状态
businessStatus
5
0:经纬度未经保密插件加密;1:经纬度已经保密插加密
encryptedStatus
6
1:紧急刹车系统采集的前撞预警
7
1:车道偏移预警
8~9
00:空车;01:半载;10:保留;11:满载
loadStatus
10
0:车辆油路正常;1:车辆油路断开
oilStatus
11
0:车辆电路正常;1:车辆电路断开
powerStatus
12
0:车门解锁;1:车门加锁
doorStatus
13
0:门1关;1:门1开(前门)
firstDoorStatus
14
0:门2关;1:门2开(中门)
secondDoorStatus
15
0:门3关;1:门3开(后门)
thirdDoorStatus
16
0:门4关;1:门4开(驾驶席门)
fourthDoorStatus
17
0:门5关;1:门5开(自定义)
fifthDoorStatus
18
0:未使用GPS卫星进行定位;1:使用GPS卫星进行定位
gpsstatus
19
0:未使用北斗卫星进行定位;1:使用北斗卫星进行定位
bdsstatus
20
0:未使用GLONASS卫星进行定位;1:使用GLONASS卫星进行定位
glonassstatus
21
0:未使用Galileo卫星进行定位;1:使用Galileo卫星进行定位
galileoStatus
22
0:车辆处于停止状态;1:车辆处于行驶状态
vehicleStatus
23~31
保留
同步命令
以下消息类型,应用可以通过下发同步命令的方式,给终端设备发送消息,参考下发同步命令。
请使用API接口做业务调测,部分命令目前不能通过界面下发。
终端管理-设置终端参数
接口说明
请求对应的消息ID:0x8103
响应对应的消息ID:0x0001(终端通用响应)
请求示例
  "service_id": "TerminalManagement",
  "command_name": "SetTerminalParameters",
  "paras": {
    "parameters": {
      "1": 120
请求参数
paras字段定义
表4 参数描述
字段名
必选/可选
类型
参数描述
parameters
必选
JsonObject
参数说明:设置的终端参数的参数列表,其中key为参数ID(十进制表示),value为参数值。
取值约束:
  • 平台当前固定心跳时长为180s
  • 不支持多值参数
响应示例
    "command_id": "1641969363120826882",
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33027,
            "resultCode": 0
        "result_code": 0
响应参数(终端通用响应)
paras字段定义
表5 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号。
msgId
int
参数说明:对应的平台的消息ID。
resultCode
int
参数说明:结果。
终端管理-查询终端参数
接口说明
请求对应的消息ID:0x8104
响应对应的消息ID:0x0104
请求示例
    "command_name": "QueryTerminalParameters",
    "paras": {}
响应示例
    "command_id": "1641973633890258246",
    "response": {
        "paras": {
            "flowNo": 0,
            "total": 1,
            "parameters": {
                "1": 120
        "result_code": 0
响应参数
paras字段定义
表6 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号。
total
int
参数说明:应答参数个数。
parameters
JsonObject
参数说明:终端参数的参数列表,其中key为参数ID(十进制表示),value为参数值。
终端管理-查询指定终端参数
接口说明
请求对应的消息ID:0x8106
响应对应的消息ID:0x0104
请求示例
    "command_name": "QueryAssignedTerminalParameters",
    "paras": {
        "parameterIds": [1]
请求参数
paras字段定义
表7 参数描述
字段名
必选/可选
类型
参数描述
parameterIds
必选
stringList
参数说明:查询的终端参数的参数ID(十进制表示)列表。
响应示例
    "response": {
        "paras": {
            "flowNo": 0,
            "total": 1,
            "parameters": {
                "1": 120
        "result_code": 0
响应参数
paras字段定义
表8 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号。
total
int
参数说明:应答参数个数。
parameters
JsonObject
终端管理-终端控制
接口说明
请求对应的消息ID:0x8105
请求示例
    "command_name": "TerminalControl",
    "paras": {
        "commandId": 4,
        "parameter": null
请求参数
paras字段定义
表9 参数描述
字段名
必选/可选
类型
参数描述
commandId
必选
int
参数说明:命令字(十进制表示)
parameter
可选
string
参数说明:命令参数
响应示例
    "command_id": "1641970324270870620",
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33029,
            "resultCode": 0
        "result_code": 0
响应参数(终端通用响应)
paras字段定义
表10 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号
msgId
int
参数说明:对应的平台的消息ID
resultCode
int
参数说明:结果
终端管理-查询终端属性
接口说明
请求对应的消息ID:0x8107
响应对应的消息ID:0x0107
请求示例
    "command_name": "QueryTerminalProperty",
    "paras": {}
响应示例
    "command_id": "1641970411683486238",
    "response": {
        "paras": {
            "clientType": {
                "passenger": true,
                "dangerousGoods": true,
                "track": true,
                "taxis": true,
                "video": true,
                "splitter": false,
                "trailer": false
            "manufacturerId": "2D_AN",
            "deviceType": "BSJ-GF-06",
            "nodeId": "5kw3noL",
            "iccId": "12345678901234567890",
            "hardwareVersion": "3.0.0",
            "firmwareVersion": "1.1.25",
            "gssn": {
                "galileo": true,
                "gps": true,
                "bds": true,
                "glonass": true
            "communication": {
                "other": false,
                "gprs": true,
                "cdma": true,
                "tdscdma": true,
                "wcdma": true,
                "cdma2000": true,
                "tdlte": true
        "result_code": 0
响应参数
paras字段定义
表11 参数描述
字段名
类型
参数描述
clientType
JsonObject
参数说明:终端类型。
  • passenger:false-不适用客运车辆,true-适用客运车辆
  • dangerousGoods:false-不适用危险品车辆,true-适用危险品车辆
  • track:false-不适用普通货运车辆,true-适用普通货运车辆
  • taxis:false-不适用出租车辆,true-适用出租车辆
  • video:false-不支持硬盘录像,true-支持硬盘录像
  • splitter:false-一体机,true-分体机
  • trailer:false-不适用挂车,true-适用挂车
manufacturerId
string
参数说明:制造商ID
deviceType
string
参数说明:终端型号
nodeId
string
参数说明:终端ID
iccId
string
参数说明:终端SIM卡ICCID
hardwareVersion
string
参数说明:终端硬件版本号
firmwareVersion
string
参数说明:终端固件版本号
gssn
jsonObject
参数说明:GNSS模块属性
  • galileo:false-不支持Galileo定位,true-支持Galileo定位
  • gps:false-不支持GPS定位,true-支持GPS定位
  • bds:false-不支持北斗定位,true-支持北斗定位
  • glonass:false-不支持GLONASS定位,true-支持GLONASS定位
communication
jsonObject
参数说明:通信模块属性
  • other:false-不支持其他通信方式,true-支持其他通信方式
  • gprs:false-不支持GPRS通信方式,true-支持GPRS通信方式
  • cdma:false-不支持CDMA通信方式,true-支持CDMA通信方式
  • tdscdma:false-不支持TD-SCDMA通信方式,true-支持TD-SCDMA通信方式
  • wcdma:false-不支持WCDMA通信方式,true-支持WCDMA通信方式
  • cdma2000:false-不支持CDMA2000通信方式,true-支持CDMA2000通信方式
  • tdlte:false-不支持TD-LTE通信方式,true-支持TD-LTE通信方式
位置及报警-位置信息查询
接口说明
请求对应的消息ID:0x8201
响应对应的消息ID:0x0201
请求示例
    "command_name": "QueryLocation",
    "paras": {}
响应示例
    "command_id": "1641971430850245415",
    "response": {
        "paras": {
            "flowNo": 0,
            "locationReport": {
                "alarm": {
                    "overSpeedAlarm": 1,
                    "dangerousDrivingAlarm": 1,
                    "powerOffAlarm": 0,
                    "cameraErrorAlarm": 1,
                    "overSpeedWarning": 1,
                    "overParkAlarm": 0,
                    "gasolineAlarm": 0,
                    "stolenAlarm": 0,
                    "rolloverAlarm": 0,
                    "gnsserrorAlarm": 1,
                    "lcderrorAlarm": 1,
                    "ttserrorAlarm": 0,
                    "icerrorAlarm": 0,
                    "vssalarm": 0,
                    "gnssantennaShortCircuitAlarm": 1
                "status": {
                    "accStatus": 0,
                    "longitudeStatus": 1,
                    "encryptedStatus": 1,
                    "loadStatus": 0,
                    "oilStatus": 1,
                    "powerStatus": 0,
                    "doorStatus": 1,
                    "firstDoorStatus": 1,
                    "secondDoorStatus": 1,
                    "galileoStatus": 0,
                    "vehicleStatus": 0,
                    "gpsstatus": 0,
                    "bdsstatus": 0,
                    "glonassstatus": 0
                "longitude": 0.041957,
                "latitude": 0.056143,
                "height": 48243,
                "speed": 10001,
                "direction": 300,
                "dateTime": "220112151406",
                "extend": []
        "result_code": 0
响应参数
表12 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号
locationReport
jsonObject
参数说明:字段定义参考表13
表13 协议报文字段与属性对应表
起始字节
字段
数据类型
对应属性
0
报警标志
DWORD
alarm
4
状态
DWORD
status
8
纬度
DWORD
latitude
12
经度
DWORD
longitude
16
高程
WORD
height
18
速度
WORD
speed
20
方向
WORD
direction
21
时间
BCD[6]
dateTime
位置及报警-临时位置跟踪控制
接口说明
请求对应的消息ID:0x8202
请求示例
    "command_name": "LocationTrace",
    "paras": {
        "timeInterval": 10,
        "period": 20
请求参数
paras字段定义
表14 参数描述
字段名
必选/可选
类型
参数描述
timeInterval
必选
int
参数说明:时间间隔,单位为秒(s)
period
必选
int
参数说明:位置跟踪有效期,单位为秒(s)
响应示例
    "command_id": "1641971752394383473",
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33282,
            "resultCode": 0
        "result_code": 0
响应参数
paras字段定义
表15 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号
msgId
int
参数说明:对应的平台的消息ID
resultCode
int
参数说明:结果
位置及报警-人工确认报警信息
接口说明
对应的消息ID:0x8203
请求示例
    "command_name": "AlarmConform",
    "paras": {
        "flowNo": 123,
        "criticalAlarm": false,
        "dangerousWarning": false,
        "areaAlarm": true,
        "routeAlarm": false,
        "drivingTimeAlarm": false,
        "startingAbnormalAlarm": false,
        "displacementAbnormalAlarm": false
请求参数
paras字段定义
表16 参数描述
字段名
必选/可选
类型
参数描述
flowNo
必选
int
参数说明:报警消息流水号
criticalAlarm
必选
boolean
参数说明:确认紧急报警
dangerousWarning
必选
boolean
参数说明:确认危险预警
areaAlarm
必选
boolean
参数说明:确认进出区域报警
routeAlarm
必选
boolean
参数说明:确认进出路线报警
drivingTimeAlarm
必选
boolean
参数说明:确认路段行驶时间不足/过长报警
必选
boolean
参数说明:确认车辆非法点火报警
必选
boolean
参数说明:确认车辆非法位移报警
响应示例
    "command_id": "1641971845905632317",
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33283,
            "resultCode": 0
        "result_code": 0
响应参数
paras字段定义
表17 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号
msgId
int
参数说明:对应的平台的消息ID
resultCode
int
参数说明:结果
位置及报警-链路检测
接口说明
请求对应的消息ID:0x8204
请求示例
    "command_name": "CheckConnection",
    "paras": {}
响应示例
    "command_id": "1641971911322353065",
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33284,
            "resultCode": 0
        "result_code": 0
响应参数
paras字段定义
表18 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号
msgId
int
参数说明:对应的平台的消息ID
resultCode
int
参数说明:结果
车辆管理-设置圆形区域电子围栏
接口说明
请求对应的消息ID:0x8600
    "service_id": "VehicleManagement",
    "command_name": "SetRoundArea",
    "paras": {
        "type": 1,
        "areas": [{
            "areaId": 1,
            "areaProperty": 1,
            "latitude": 0,
            "longitude": 0,
            "radius": 0,
            "startTime": "211119170110",
            "endTime": "211119170111",
            "maxSpeed": 0,
            "durationOverSpeed": 0,
            "maxNightSpeed": 0,
            "areaName": "test"
请求参数
paras字段同协议中消息的映射关系
表19 参数描述
字段名
类型
协议字段
参数描述
type
int
设置属性
0:更新区域
1:追加区域
2:修改区域
areas
jsonObject
区域
参数说明:圆形区域列表
Area字段说明
表20 参数描述
字段名
类型
协议字段
参数描述
areaId
int
区域ID
参数说明:区域ID
areaProperty
int
区域属性
参数说明:区域属性
latitude
int
中心点纬度
参数说明:以度为单位的纬度值乘以10的6次方,精确到百万分之一。
longitude
int
中心点经度
参数说明:以度为单位的经度值乘以10的6次方,精确到百万分之一。
radius
int
半径
参数说明:单位为米
startTime
string
起始时间
参数说明:格式为YYMMDDHHMMSS
endTime
string
结束时间
maxSpeed
int
最高速度
参数说明:单位为千米每小时(km/h)
durationOverSpeed
int
超速持续时间
参数说明:单位为秒(s)
maxNightSpeed
int
夜间最高速度
参数说明:单位为千米每小时(km/h)
areaName
string
区域名称
参数说明:区域的名称描述
区域属性说明
表21 属性说明
位
标志
0
是否开启起始时间与结束时间的判断规则,0:否;1:是
是否启用最高速度,超速持续时间和夜将最高速度的判断规则,0:否;1:是
2
进区域是否报警给驾驶员,0:否;1:是
3
进区域是否报警给平台,0:否;1:是
4
出区域是否告警给驾驶员,0:否;1:是
5
出区域是否告警给平台,0:否;1:是
6
0:北纬;1:南纬
7
0:东经;1:西经
8
0:允许开门;1:禁止开门
9-13
保留
14
0:进区域开启通信模块;1:进区域关闭通信模块
15
0:进区域不采集GNSS详细定位数据;1:进区域采集GNSS详细定位数据
响应示例
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33284,
            "resultCode": 0
        "result_code": 0
响应参数(终端通用响应)
paras字段定义
表22 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号
msgId
int
参数说明:对应的平台的消息ID
resultCode
int
参数说明:结果
车辆管理-删除圆形区域电子围栏
接口说明
请求对应的消息ID:0x8601
请求示例
    "command_name": "RemoveRoundArea",
    "paras": {
        "areaIds": [
请求参数
paras字段同协议中消息的映射关系
表23 参数描述
字段名
类型
协议字段
参数描述
areaIds
stringList
区域ID列表
响应示例
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33027,
            "resultCode": 0
        "result_code": 0
响应参数(终端通用响应)
paras字段定义
表24 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号
msgId
int
参数说明:对应的平台的消息ID
resultCode
int
参数说明:结果
车辆管理-设置多边形区域电子围栏
接口说明
请求对应的消息ID:0x8604
请求示例
    "command_name": "SetPolygonArea",
    "paras": {
        "areaId": 1,
        "areaProperty": 1,
        "maxSpeed": 0,
        "vertices": [
                "latitude": 0,
                "longitude": 1
        "maxNightSpeed": 0,
        "areaName": "test"
请求参数
paras字段同协议中消息的映射关系
表25 参数描述
字段名
类型
协议字段
参数描述
areaId
int
区域ID
参数说明:区域ID
areaProperty
int
区域属性
参数说明:区域属性
startTime
string
起始时间
endTime
string
结束时间
vertices
jsonObject
区域定点
参数说明:多边形区域定点信息
maxSpeed
int
最高速度
参数说明:单位为千米每小时(km/h)
durationOverSpeed
int
超速持续时间
参数说明:单位为秒(s)
maxNightSpeed
int
夜间最高速度
参数说明:单位为千米每小时(km/h)
areaName
string
区域名称
参数说明:区域的名称描述
vertice字段同协议中消息的映射关系
表26 参数描述
字段名
类型
协议字段
参数描述
latitude
int
中心点纬度
longitude
int
中心点经度
响应示例
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33027,
            "resultCode": 0
        "result_code": 0
响应参数(终端通用响应)
paras字段定义
表27 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号
msgId
int
参数说明:对应的平台的消息ID
resultCode
int
参数说明:结果
车辆管理-删除多边形区域电子围栏
接口说明
请求对应的消息ID:0x8605
请求示例
    "command_name": "RemovePolygonArea",
    "paras": {
        "areaIds": [
请求参数
paras字段同协议中消息的映射关系
表28 参数描述
字段名
类型
协议字段
参数描述
areaIds
stringList
区域ID列表
响应示例
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33027,
            "resultCode": 0
        "result_code": 0
响应参数(终端通用响应)
paras字段定义
表29 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号
msgId
int
参数说明:对应的平台的消息ID
resultCode
int
参数说明:结果
实时音视频-实时音视频传输请求
接口说明
请求对应的消息ID:0x9101
请求示例
    "command_name": "VideoLiveRequest",
    "service_id": "VideoLive",
    "paras": {
        "serverIp": "***.***.***.***",
        "port": 8557,
        "channelNo": 1,
        "dataType": 0,
        "streamType": 0
请求参数
paras字段同协议中消息的映射关系
表30 参数描述
字段名
类型
协议字段
参数描述
serverIp
string
服务器地址
参数说明:视频服务器地址
port
int
服务器端口
参数说明:视频服务器端口
channelNo
int
逻辑通道号
参数说明:逻辑通道号
dataType
int
音视频资源类型
参数说明:音视频资源类型
0:音视频,
1:视频
2:双向对讲
3:监听
4:中心广播
5:透传
streamType
int
码流类型
参数说明:码流类型
0:主码流1:子码流
响应示例
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33027,
            "resultCode": 0
        "result_code": 0
响应参数(终端通用响应)
paras字段定义
表31 参数描述
字段名
类型
参数描述
flowNo
int
参数说明:应答流水号
msgId
int
参数说明:对应的平台的消息ID
resultCode
int
参数说明:结果
实时音视频-音视频实时传输控制
接口说明
请求对应的消息ID:0x9102
请求示例
    "command_name": "VideoLiveControl",
    "paras": {
        "channelNo": 1,
        "commandId": 0,
        "mediaType": 0,
         "streamType": 1
请求参数
paras字段同协议中消息的映射关系
表32 参数描述
字段名
类型
协议字段
参数描述
channelNo
int
逻辑通道号
参数说明:逻辑通道号
commandId
int
控制指令
参数说明:平台可以通过该指令对设备的实时音视频传输进行控制:
0:关闭音视频传输指令。
1:切换码流
2:暂停该通道所有流的发送
3:恢复暂停前流的发送
4:关闭所向对讲
mediaType
int
关闭音视频资源类型
参数说明:关闭音视频资源类型
0:关闭该通道有关的音视频数据
1:只关闭该通道有关的音频,保留该通道有关的视频。
2:只关闭该通道有关的视频,保留该通道有关的音频。
streamType
int
码流类型
参数说明:将之前申请的码流切换为新申请的码流,音频与切换前保持一致。新申请的码流为:
0:主码流 1:子码流
响应示例
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33027,
            "resultCode": 0
        "result_code": 0
实时音视频-查询视频资源列表
接口说明
请求对应的消息ID:0x9205
响应对应的消息ID:0x1205
请求示例
    "command_name": "GetVideoResource",
    "service_id": "VideoResource",
    "paras": {
        "channelNo": 0,
        "startTime": "220314093900",
        "endTime": "220314174000",
        "warningMark":0,
        "warningMarkHigh":0,
        "mediaType": 0,
        "streamType": 0,
        "memoryType": 0
请求参数
paras字段同协议中消息的映射关系
表33 参数描述
字段名
类型
协议字段
参数描述
channelNo
int
逻辑通道号
0标识所有通道
startTime
string
开始时间
YYMMDDHHMMSS,全0表示无起始时间
endTime
string
结束时间
YYMMDDHHMMSS,全0表示无结束时间
warningMark
int
告警标志
告警标志位定义,全0表示无报警类型条件
warningMarkHigh
int
高位告警标志
高位告警标志位定义,全0表示无报警类型条件
mediaType
int
音视频资源类型
0:音视频,1:音频,2:视频3:视频或者音视频
streamType
int
码流类型
0:所有码流1:主码流2:子码流
memoryType
int
存储器类型
0:所有存储器,1:主存储器,2:灾备存储器
响应示例
    "command_id": "c4eafd52-7411-483d-901c-858a2b7bc2a7",
    "response": {
        "paras": {
            "flowNo": 0,
            "count": 1,
            "items": [
                    "channelNo": 1,
                    "startTime": "200101000000",
                    "endTime": "201231235959",
                    "warningMark": 0,
                    "warningMarkHigh": 0,
                    "mediaType": 1,
                    "streamType": 1,
                    "memoryType": 1,
                    "size": 1024
        "response_name": null,
        "result_code": 0
响应参数
paras字段定义
表34 参数描述
字段名
类型
参数描述
flowNo
int
应答流水号
count
int
录像文件数量
items
jsonObject
录像列表
录像文件说明
表35 参数描述
字段名
类型
协议字段
参数描述
channelNo
int
逻辑通道号
0标识所有通道
startTime
string
开始时间
YYMMDDHHMMSS格式的视频开始时间
endTime
string
结束时间
YYMMDDHHMMSS 式的视频结束时间
warningMark
int
告警标志
告警标志位定义
warningMarkHigh
int
高位告警标志
高位告警标志位定义
mediaType
int
音视频资源类型
streamType
int
码流类型
0:所有码流1:主码流2:子码流
memoryType
int
存储器类型
历史视频上传
接口说明
请求对应的消息ID:0x9206
请求示例
    "command_name": "Upload",
    "paras": {
        "port": 10020,
        "username": "******",
        "password": "******",
        "path": "20220307",
        "channelNo": 1,
        "startTime": "220307153900",
        "endTime": "220307154000",
        "warningMark":0,
        "mediaType": 0,
        "streamType": 1,
        "memoryType": 1,
        "condition": 7
请求参数
paras字段同协议中消息的映射关系
表36 参数描述
字段名
类型
协议字段
参数描述
serverIp
string
服务器地址
FTP服务器地址
port
int
服务器端口
FTP服务器端口
username
string
用户名
FTP服务器用户名
password
string
密码
FTP服务器密码
path
string
文件上传路径
FTP服务器文件上传路径
channelNo
int
逻辑通道号
标识所有通道
startTime
string
开始时间
YYMMDDHHMMSS格式的起始时间
endTime
string
结束时间
YYMMDDHHMMSS格式的结束时间
warningMark
int
告警标志
告警标志位定义
warningMarkHigh
int
高位告警标志
高位告警标志位定义
mediaType
int
音视频资源类型
streamType
int
码流类型
0:所有码流1:主码流2:子码流
memoryType
int
存储器类型
condition
int
任务执行条件
Bit0:WIFI,为1时表示WI-FI下可下载;
Bit1:LAN,为1时表示LAN连接时可下载;
Bit2:3G/4G, 为1时表示3G/4G连接时可下载。
响应示例
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33027,
            "resultCode": 0
        "result_code": 0
响应参数(终端通用响应)
paras字段定义
表37 参数描述
字段名
类型
参数描述
flowNo
int
应答流水号
msgId
int
对应的平台的消息ID
resultCode
int
结果
文本信息下发接口说明
请求对应的消息ID:0x8300
请求示例
    "command_name": "SendTextMessage",
    "service_id": "Message",
    "paras": {
        "flag": 2,
        "lcdflag": true,
        "ttsflag": true,
        "text": "hello",
        "textType": 1
请求参数
paras字段同协议中消息的映射关系
表38 参数描述
属性名
协议字段
类型
参数描述
flag
文本信息标志
int
1: 服务
2: 紧急
3: 通知
lcdflag
终端显示标志
boolean
为true时终端显示器显示
ttsflag
终端播读标志
boolean
为true时终端TTS播读
textType
文本类型
int
1:通知
2:服务
text
文本信息
string
最长1024字节
响应示例
    "response": {
        "paras": {
            "flowNo": 0,
            "msgId": 33027,
            "resultCode": 0
        "result_code": 0
响应参数(终端通用响应)
paras字段定义
表39 参数描述
字段名
类型
参数描述
flowNo
int
应答流水号
msgId
int
对应的平台的消息ID
resultCode
int
结果
