文档首页/ 云容器引擎 CCE/ 用户指南/ 模板(Helm Chart)/ Helm v2 Release转换成Helm v3 Release
更新时间:2026-05-26 GMT+08:00
背景介绍
当前CCE已全面支持Helm v3版本,用户可通过本指南将已创建的v2 release转换成v3 release,从而更好地使用v3的特性。因Helm v3底层相对于Helm v2来说,一些功能已被弃用或重构,因此转换会有一定风险,需转换前进行模拟转换。
该指南参考社区文档:https://github.com/helm/helm-2to3
注意事项:
  • Helm v2 release信息存储在configmap中,Helm v3 release信息存储在secrets中。
  • 若用户通过前端console操作,在获取实例、更新实例等操作中CCE会自动尝试转换v2模板实例到v3模板实例。若用户仅在后台操作实例,需通过该指南进行转换操作。
转换流程(不使用Helm v3客户端)
  1. 在CCE节点上下载helm 2to3转换插件。
    wget https://github.com/helm/helm-2to3/releases/download/v0.10.2/helm-2to3_0.10.2_linux_amd64.tar.gz
  1. 解压插件包。
    tar -xzvf helm-2to3_0.10.2_linux_amd64.tar.gz
  1. 模拟转换。
    以test-convert实例为例,执行以下命令进行转换的模拟。若出现以下提示,说明模拟转换成功。
    # ./2to3 convert --dry-run --tiller-out-cluster -s configmaps test-convert
    NOTE: This is in dry-run mode, the following actions will not be executed.
    Run without --dry-run to take the actions described below:
    Release "test-convert" will be converted from Helm v2 to Helm v3.
    [Helm 3] Release "test-convert" will be created.
    [Helm 3] ReleaseVersion "test-convert.v1" will be created.
  2. 执行正式转换。若出现以下提示,说明转换成功。
    # ./2to3 convert --tiller-out-cluster -s configmaps test-convert
    [Helm 3] ReleaseVersion "test-convert.v1" created.
    [Helm 3] Release "test-convert" created.
    Release "test-convert" was converted successfully from Helm v2 to Helm v3.
    Note: The v2 release information still remains and should be removed to avoid conflicts with the migrated v3 release.
    v2 release information should only be removed using `helm 2to3` cleanup and when all releases have been migrated over.
  3. 转换完成后进行v2 release资源的清理,同样先进行模拟清理,成功后正式清理v2 release资源。
    模拟清理:
    # ./2to3 cleanup --dry-run --tiller-out-cluster -s configmaps --name test-convert
    WARNING: "Release 'test-convert' Data" will be removed.
    [Cleanup/confirm] Are you sure you want to cleanup Helm v2 data? [y/N]: y
    Helm v2 data will be cleaned up.
    [Helm 2] Release 'test-convert' will be deleted.
    [Helm 2] ReleaseVersion "test-convert.v1" will be deleted.
    正式清理:
    # ./2to3 cleanup --tiller-out-cluster -s configmaps --name test-convert
    [Helm 2] ReleaseVersion "test-convert.v1" d
转换流程(使用Helm v3客户端)
  1. 安装Helm v3客户端,参见安装Helm v3。
  2. 安装转换插件。
    # helm plugin install https://github.com/helm/helm-2to3
    Downloading and installing helm-2to3 v0.10.2 ...
    Installed plugin: 2to3
  3. 查看已安装的插件,确认插件已安装。
    # helm plugin list
    NAME VERSION DESCRIPTION
    2to3  0.10.2      migrate and cleanup Helm v2 configuration and releases in-place to Helm v3
  4. 模拟转换。
    以test-convert实例为例,执行以下命令进行转换的模拟。若出现以下相关提示,说明模拟转换成功。
    # helm 2to3 convert --dry-run --tiller-out-cluster -s configmaps test-convert
  5. 执行正式转换。若出现以下提示,说明转换成功。
    # helm 2to3 convert --tiller-out-cluster -s configmaps test-convert
  6. 正式转换成功后,用户可通过helm list查看已转换成功的模板实例。
    # helm list
    NAME                NAMESPACE    REVISION UPDATED                           STATUS      CHART              APP VERSION
    test-convert      default   1                2022-08-29 06:56:28.166918487 +0000 UTC       deployed    test-helmold-1
  7. 转换完成后进行V2 release资源的清理,同样先进行模拟清理,成功后正式清理V2 release资源。
    模拟清理:
    # helm 2to3 cleanup --dry-run --tiller-out-cluster -s configmaps --name test-convert
    正式清理:
    # helm 2to3 cleanup --tiller-out-cluster -s configmaps --name test-convert
    [Helm 2] ReleaseVersion "test-convert.v1" deleted.
    [Helm 2] Release 'test-convert' deleted.
    Helm v2 data was cleaned up successfully.
