文档首页/
云容器引擎 CCE/
用户指南(阿布扎比区域)/
最佳实践/
网络/
通过模板包部署Nginx Ingress Controller/
Nginx Ingress Controller高级配置
更新时间:2025-05-16 GMT+08:00
高并发业务场景参数优化
针对高并发业务场景,可通过参数配置进行优化:
- 通过ConfigMap对Nginx Ingress Controller整体参数进行优化。
- 通过InitContainers对Nginx Ingress Controller内核参数进行优化。
优化后的value.yaml配置文件如下:
controller:
image:
repository: registry.k8s.io/ingress-nginx/controller
registry: ""
image: ""
tag: "v1.5.1" #controller版本
digest: ""
ingressClassResource:
name: ccedemo #同一个集群中不同套Ingress Controller名称必须唯一,且不能设置为nginx和cce
controllerValue: "k8s.io/ingress-nginx-demo" #同一个集群中不同套Ingress Controller的监听标识必须唯一,且不能设置为k8s.io/ingress-nginx
ingressClass: ccedemo #同一个集群中不同套Ingress Controller名称必须唯一,且不能设置为nginx和cce
service:
annotations:
kubernetes.io/elb.id: 5083f225-9bf8-48fa-9c8b-67bd9693c4c0 #ELB ID
kubernetes.io/elb.class: performance #仅独享型ELB需要添加此注解
# Nginx参数优化
config:
keep-alive-requests: 10000
upstream-keepalive-connections: 200
max-worker-connections: 65536
# 内核参数优化
extraInitContainers:
- name: init-myservice
image: busybox
securityContext:
privileged: true
command: ['sh', '-c', 'sysctl -w net.core.somaxconn=65535;sysctl -w net.ipv4.ip_local_port_range="1024 65535"']
extraVolumeMounts: # 挂载节点上的/etc/localtime文件,进行时区同步
- name: localtime
mountPath: /etc/localtime
readOnly: true
extraVolumes:
- name: localtime
type: Hostpath
hostPath:
path: /etc/localtime
admissionWebhooks: # 关闭webhook验证开关
enabled: false
patch:
enabled: false
resources: # 设定controller的资源限制,可根据需求自定义
requests:
cpu: 200m
memory: 200Mi
defaultBackend: # 设置defaultBackend
enabled: true
image:
repository: registry.k8s.io/defaultbackend-amd64
registry: ""
image: ""
tag: "1.5"
digest: ""
admissionWebhook配置
Nginx Ingress Controller支持admissionWebhook配置,通过设置controller.admissionWebhook参数,可以对Ingress对象进行有效性校验,避免因配置错误导致ingress-controller不断重新加载资源,导致业务中断。
开启admissionWebhook的value.yaml配置文件如下:
controller:
image:
registry: ""
image: ""
digest: ""
service:
annotations:
config:
- name: localtime
readOnly: true
extraVolumes:
- name: localtime
type: Hostpath
hostPath:
admissionWebhooks:
annotations: {}
enabled: true
extraEnvs: []
failurePolicy: Fail
port: 8443
certificate: "/usr/local/certificates/cert"
key: "/usr/local/certificates/key"
namespaceSelector: {}
objectSelector: {}
labels: {}
existingPsp: ""
networkPolicyEnabled: false
service:
annotations: {}
externalIPs: []
loadBalancerSourceRanges: []
servicePort: 443
type: ClusterIP
createSecretJob:
resources: #注释{}
limits:
cpu: 20m
memory: 40Mi
requests:
cpu: 10m
memory: 20Mi
patchWebhookJob:
resources: {}
patch:
enabled: true
image:
registry: registry.k8s.io #registry.k8s.io为webhook官网镜像仓库,需要替换成自己镜像所在仓库地址
image: ingress-nginx/kube-webhook-certgen #webhook镜像
tag: v1.1.1
digest: ""
pullPolicy: IfNotPresent
priorityClassName: ""
podAnnotations: {}
nodeSelector:
kubernetes.io/os: linux
tolerations: []
labels: {}
securityContext:
runAsNonRoot: true
runAsUser: 2000
fsGroup: 2000
requests:
cpu: 200m
memory: 200Mi
enabled: true
image:
registry: ""
image: ""
tag: "1.5"
digest: ""
验证Ingress配置错误annotation场景下,admissionWebhook是否会进行校验。
例如,为Ingress配置以下错误的annotation:
annotations:
nginx.ingress.kubernetes.io/auth-tls-pass-certificate-to-upstream: "false"
nginx.ingress.kubernetes.io/auth-tls-verify-client: optional
nginx.ingress.kubernetes.io/auth-tls-verify-depth: "1"
创建此Ingress服务,将会出现以下拦截信息:
