Scheduled Startup
This section describes how to start a cloud desktop or a desktop pool periodically.
Impact on the System
This operation has no adverse impact on the system.
Scheduled startup can be performed only on desktops that have been shut down.
- Log in to the Workspace console.
- In the navigation pane, choose Tasks > Scheduled Tasks.
The Scheduled Tasks page is displayed.
- Click Create Scheduled Task in the upper right corner of the page.
The Create Scheduled Task window is displayed.
- Configure a scheduled task.
- Task Type: Select Startup.
- Task Name: This parameter is user-defined.
- Execution Interval: You can select one of the following intervals:
- Specified time: The time is accurate to seconds.
- By day: You can specify Time, Executed Once Per, and Expires At.
- By week: You can specify Weekday, Time, and Expires At.
- By month: You can specify Month, Day, Time, and Expires At.
- Click Next: Select Object.
The Select Target Object page is displayed.
- In the Available Objects area, select All desktops, Desktops, or Desktop pools from the drop-down list box, and select the desired objects.
- Click Create Now.
