Updated on 2026-08-06 GMT+08:00
Application Management Configuration
You can configure tenant application management rules on the Workspace console to manage applications in a unified manner.
  • Before using application management, you need to contact O&M personnel to check whether the basic components of your desktops have been upgraded to a version that supports application management.
  • HDA version: Only 25.1.0 and later versions are supported.
  • This operation can be performed only on Windows desktops.
Adding an application rule
  1. Log in to the console.
  2. In the navigation pane, choose App Center > App Management.
    The App Management page is displayed.
  3. On the top navigation bar, click App Management.
  4. Click Add App Rule to go to the Add App Rule page.
  5. Search for and select the application rule to be added by rule name, and click OK.
Delete an application rule
  1. On the top navigation bar, click App Management.
  2. Delete added application rules as required.
    • Deletion of a single application rule:
      1. Click Delete in the Operation column of the desired application rule to go to the Delete Application Rule page.
      2. Enter DELETE or click Auto Enter to quickly enter the value. Click OK.
    • Batch deletion:
      1. Select the application rules to delete in batches and click Batch Delete to go to the Delete Application Rule page.
Modifying application management configuration
  1. Click Modify Configuration on the right of the App Management tab to go to the page for modifying application management configuration.
    • App Management: After enabling this function, you can determine whether to enable periodic monitoring.
      • : application management disabled
      • : application management enabled
        Blacklist policy rules:
        1. When a desktop user opens a blacklisted application, the application is forbidden to run.
        2. The policy cannot take effect on running processes.
        3. The policy takes effect in five to ten minutes.
        4. Periodic monitoring and force application killing are supported only for HDA 25.1.0 or later.
    • App Management Mode: Do not run apps in the list
    • Periodic Monitoring: This parameter is available only after App Management is enabled. You can determine whether to enable this parameter (disabled by default).
      • : periodic monitoring disabled
      • : periodic monitoring enabled
      • Monitoring Period (min): This parameter is available only after you enable App Management and Periodic Monitoring. The monitoring period ranges from 5 minutes (default) to 60 minutes.
      • Force Application Killing: This parameter is available only after you enable App Management and Periodic Monitoring. You can determine whether to enable this parameter (enabled by default).
        • : disabled
        • : enabled
