Creating an ECS
This section describes how to create an ECS for subsequent ECS configuration and image creation.
- You have obtained the username and password for logging in to the console.
- You have registered a private image using an ISO file.
- Log in to the console.
- Choose Compute in All Services and choose Image Management Service.
The IMS console is displayed.
- Click Create ECS in the Operation column of the private image created in Registering a Private Image Using an ISO File.
- On the displayed page, configure the parameters in Table 1 and retain the default settings for other parameters.
Table 1 ECS parameters Parameter
Example Value
AZ
Select an AZ as needed.
NOTE:An AZ is a physical region where resources use independent power supplies and networks. AZs are physically isolated but connected through an intranet. If an AZ becomes faulty, other AZs in the same region will not be affected.
Flavor
Select the planned ECS flavor.
4 vCPUs | 8 GiB is recommended.
VPC
Select the planned VPC.
fa_vpc
Subnet
Select the planned subnet.
subnet-fa
Name
The value can be customized.
WKS-desktop_temp
Enterprise Project
Select an enterprise project.
default
- Click OK.
After the request is successful, the created ECS is displayed in the ECS list on the ECS console.
