Help Center/ Workspace/ User Guide (Administrators)/ Tenant Configuration/ Basic Configuration/ Upgrading Client and VM Components and Rotating Authentication Credentials
Updated on 2025-08-07 GMT+08:00
To continuously optimize user experience on Workspace desktops, the administrator can enable Upgrading Client and VM Components and Rotating Authentication Credentials on the Basic Settings page. After this function is enabled, the administrator can upgrade client and desktop components based on version features and rotate machine-machine authentication credentials of a desktop.
  1. Log in to the console.
  2. In the navigation pane, choose Tenant Configuration > Basic Settings.
    The Basic Settings page is displayed.
  3. In the Upgrading Client and VM Components and Rotating Authentication Credentials area, perform operations as required.
    • Authorization defaults to Disabled. If you click Enable, the client and desktop components will be upgraded based on the version features, and machine-machine authentication credentials of a desktop will be rotated based on desktop users' requirements.
    • If authorization is not needed, click Close. After the function is disabled, the function of upgrading client and VM components and rotating authentication credentials is unavailable.
