Subscribing to an Event
Configure SMN to obtain desktop status information in a timely manner, such as desktop creation, creation failure, startup, startup failure, shutdown, shutdown failure, and deletion failure, and report the information to Cloud Trace Service (CTS) to improve the desktop access speed and operation accuracy.
Event notifications may cause message queue blocking or failure of calling CTS, so users cannot solely depend on event notifications. Instead, they need to periodically call APIs to update data. For any questions, submit a service ticket for technical support.
Configuring a subscription event
- Enable CTS.
Enabling CTS will automatically create a system tracker for your use.
- Create an SMN topic.
- Add a subscription.
- Configure key event notifications.
Configure parameters for key event notifications as follows.
- Notification Name: This parameter is user-defined, for example, keyOperate_Workspace.
- Operation: Select Custom. In the operation list, set Select Service to Workspace, Select Resource to workspace, and Select Operation to createDesktops, stopDesktops, startDesktops, or deleteDesktops.
- User: Not specified.
- Send Notification: Yes
- Topic: Select the topic created in 2.
Verifying the subscription event
- Events (including desktop creation, startup, and shutdown; failure of creating, starting, stopping, or deleting a desktop) are automatically reported to CTS. You will receive a message based on the protocol configured in 3. For example, if you select email, you will receive a notification email.
- You can also view all traces on the CTS console.
- Click Service List and choose Management & Governance > Cloud Trace Service.
- Choose Trace List. On the Trace List page, set Trace Source to Workspace, Resource Type to Workspace, and Filter By to Trace Name.
Traces are classified into the following types:
- createDesktops: creates a desktop
- stopDesktops: stops a desktop
- startDesktops: starts a desktop
- deleteDesktops: deletes a desktop
- Click Query.
- Take desktop purchase as an example. View the desktop purchase trace and start the purchase, as shown in Figure 1.
View the desktop purchase trace to complete the purchase, as shown in Figure 2.
- When desktop purchase or deletion fails, a failure trace is reported. In the trace details, the value of Message is FAILED.
- If the desktop is stopped, the BEGIN message is not reported by CTS. Only the message indicating that the desktop has been stopped will be reported.
- Three minutes after the desktop is started, if the login status of the desktop is not Ready on the desktop management page, a timeout trace is reported. In the trace details, the value of Message is TIMEOUT.
- Three minutes after the desktop is stopped, if the login status of the desktop is not Stopped on the desktop management page, a timeout trace is reported. In the trace details, the value of Message is TIMEOUT.
