On this page
Changing the Internet Access Mode
Updated on 2024-10-23 GMT+08:00
On the Workspace console, you can change your Internet access mode.
  1. Log in to the console.
  2. In the navigation pane, choose Tenant Configuration > Basic Settings.
    The Basic Settings page is displayed.
  3. Click Disable or Enable on the right of Internet Access Address or Direct Connect Access Address. Wait for about one minute for the change to take effect. For details, see Table 1.
    Workspace supports Internet access and Direct Connect access at the same time. At least one access mode must be enabled.
    Table 1 Modifying the network access mode
    Operation
    Disable Internet access
    If Direct Connect Access Address and Internet Access Address are enabled, you can disable Internet access.
    1. In the Network Configuration area, click Disable next to Internet Access Address.
    2. In the confirmation dialog box, click OK.
    Enable Internet access
    After the Internet access address is disabled, you can enable Internet access again. After the function is enabled again, the IP address changes. You need to notify the desktop user to use the new IP address to access the desktop.
    1. In the Network Configuration area, click Enable next to Internet Access Address.
    Disable Direct Connect access
    If Direct Connect Access Address and Internet Access Address are enabled, you can disable Direct Connect access.
    1. In the Network Configuration area, click Disable next to Direct Connect Access Address.
    Enable Direct Connect access
    Tenants who have enabled Direct Connect can configure Direct Connect access for cloud desktops.
    1. In the Network Configuration area, click Enable next to Direct Connect Access Address.
    2. In the displayed dialog box, configure Direct Connect network segment.
      • Check whether the service subnet of the cloud desktop and the subnet of the Direct Connect are in the same range.
        If yes, you do not need to configure the Direct Connect network segment.
        If no, you need to configure the Direct Connect CIDR block in the Direct Connect network segment area. You can view the service subnet of the cloud desktop and the subnet network segment of the Direct Connect on the VPC page.
      • A maximum of five network segments can be configured. Use semicolons (;) to separate multiple network segments.
      • The network segment is as follows:
        192.168.11.0/24;172.10.240.0/20
    3. In the Enabling Direct Connect Access Addresses dialog box, select I have confirmed that I've confirmed that a VPC endpoint needs to be created to enable Direct Connect access. (Do not modify the VPC endpoint after creation. Otherwise, Direct Connect access will be affected. VPC endpoint creation is a charged service.).
    4. In the confirmation dialog box, click OK.
    5. (Optional) Modify the Direct Connect network segment.
      If the Direct Connect network segment is incorrect, click Amend on the right of Direct Connect network segment in the network configuration area. In the displayed dialog box, modify the network segment as required. Click OK.
