Updated on 2026-09-01 GMT+08:00
Querying a Protection Event
WAF collects statistics on top 10 attacks, attacked targets, attack source IP addresses, and attacked URLs in the selected period, and records the blocked or logged attack events on the Events page. You can view details of WAF protection events for the past 30 days. You can check the time an event occurred, client IP address, geographic location of the client IP address, malicious load, and hit rule.
  • On the WAF console, you can view the event data for all protected domain names over the last 30 days. You can authorize LTS to log WAF activities so that you can view attack and access logs and store all logs for a long time. For more details, see Using LTS to Record WAF Logs.
  • There are a large number of access logs. To prevent WAF engine performance from being affected, WAF does not record access logs by default. To mask tokens and passwords, you can configure data masking rules, with Masked Field set to Params and Field Name to token and password.
    If you want to store logs for a longer period, you can enable Log Tank Service (LTS) for WAF to record attack logs and access logs. You can also use LTS to transfer logs to Object Storage Service (OBS) or Data Ingestion Service (DIS) for long-term storage.
    • Logs stored in LTS are retained for 30 days by default. You can customize a retention duration from 1 to 365 days. Logs will be automatically deleted when the retention duration expires. For more details, see Log Tank Service (LTS).
    • If you enable LTS logging, logs in LTS will be billed by traffic volume. For details about LTS billing, see LTS Pricing Details.
  • If you switch the WAF working mode for a website to Suspended, WAF only forwards all requests to the website without inspection. It does not log any attack events either.
  • After an attack occurs, it takes about 2 to 3 minutes for the attack to be logged as a protection event.
Viewing Protection Event Logs
  1. Log in to the WAF console.
  2. Click in the upper left corner and select a region or project.
  3. (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
  4. In the navigation pane on the left, choose Security Operations > Events.
  5. On the Search tab, set search criteria.
    Figure 1 Setting search criteria
    • Domain name (① in Figure 1): You can select a specific domain name, multiple domain names, or all domain names to view the security statistics.
    • Instance (② in Figure 1): You can select a specific instance or all instances to view security statistics.
    • Query time (③ in Figure 1): You can view bot protection statistics for yesterday, today, past 3 days, past 7 days, past 30 days, or any time range within 30 days.
  6. View the statistical charts and event details.
This area displays the event trends and top 10 events for a specified protected domain name, instance, and time range.
Figure 2 Tables and Charts
Function Module
Related Operation
Events over Time (① in Figure 2)
Displays the WAF protection status for the selected website within a specified period.
Top Tens (② in Figure 2)
Displays the top 10 attacks, attacked targets, attack source IP addresses, and attacked URLs in the selected period.
  • Click next to Attacks (1-5), Attacked Targets (1-5), Attack Source IP Addresses (1-5), and Attacked URLs (1-5) to view the attack data of top 6 to 10 attacks, attacked targets, attack source IP addresses, and attacked URLs.
  • You can click next to Attacks, Attacked Objects, Attack Source IP Addresses, or Attacked URLs to copy the data in the statistical charts.
  • You can click a domain name, client IP address, or URL listed in Top Attacked Objects, Attack Source IP Addresses, or Attacked URLs charts to make a quick search in the event list, as WAF automatically adds filter criteria to the event search box after you click an object.
A maximum of 10,000 logs are displayed on the console. To query more logs, specify a time range or transfer logs to Log Tank Service (LTS).
Figure 3 Events
  1. Set matching conditions (① in Figure 3) based on filter condition fields. The matching conditions you set will be displayed above the event list. For details about the condition fields, see Table 1.
    Table 1 Filter condition fields
    Client IP Address
    Public IP address of the web visitor/attacker.
    By default, All is selected. You can view logs of all attack source IP addresses, select an attack source IP address, or enter an attack source IP address to view corresponding attack logs.
    Host
    Attacked domain name.
    Rule ID
    ID of a built-in protection rule in WAF basic web protection.
    URL
    Attacked URL.
    Event Type
    Type of the attack.
    By default, All is selected. You can view logs of all attack types or select an attack type to view corresponding attack logs.
    Protective Action
    The protective action configured in the hit rule. The options are Block, Log only, Verification code, and Mismatch.
    • Verification code: In CC attack protection rules, you can set Protective Action to Verification code. If a visitor sends too many requests, with the request quantity exceeding the rate limit specified by the CC attack protection rule used, a message is displayed to ask the visitor to provide a verification code. Visitor's requests will be blocked unless they enter a valid verification code.
    • Mismatch: If an access request matches a web tamper protection rule, information leakage prevention rule, or data masking rule, the protective action is marked as Mismatch.
    Status Code
    HTTP status code returned on the block page.
    Malicious Load
    Location or part of the attack that causes damage or the number of times that the URL was accessed.
    Event ID
    ID of the event.
    Location
    Geographic location where the client IP address is located.
    Enterprise Project
    Enterprise project your website belongs to.
  2. Click (② in Figure 3) in the upper right corner of the event list and set the fields to be displayed. You can sort the time, client IP address, host, geographical location, rule ID, and event type in ascending or descending order. You can filter the protective action and status code by type. Table 2 describes the parameters.
    Table 2 Parameters in the event list
    Example Value
    Time
    When the attack occurred.
    2021/02/04 13:20:04
    Client IP Address
    host
    www.example.com
    Geolocation
    Rule ID
    URL
    Attacked URL.
    /admin
    Event Type
    Type of attack.
    SQL injection
    Application Component
    Application component that was attacked.
    pgAdmin4
    Protective Action
    Protective actions configured in the rule. The options are Block, Log only, and Verification code.
    Block
    Status Code
    418
    Malicious Load
    • In a CC attack, the malicious load indicates the number of times that the URL was accessed.
    • For blacklist protection events, the malicious load is left blank.
    id=1 and 1='1
    Access Mode
    Method of connecting websites to WAF.
    Dedicated Mode
    Load Balancer Name
    Name of the ELB (Load Balancer) associated with the protected domain name in cloud mode load balancer access.
    If the required permission is not in place, the load balancer name cannot be displayed. To use WAF securely, click Authorize Now to update the cloud service resource permissions. Do not change the permissions after authorization.
    elb-18ce
    Enterprise Project
    default
    After the preceding configurations are complete, as shown in Figure 3, you can view the events that meet the search criteria in the event list.
  3. Locate the target event and click Details in the Operation column (③ in Figure 3) to view details about the event. You can check the event overview, malicious payloads, response details, and request details.
    You need to submit a service ticket to enable the response details function, and configure the length of the response body to be logged. In this way, WAF can display the response details and record the response body based on specified length.
Related Operations
  • Handling False Alarms: If normal traffic is blocked by a WAF protection rule, you can perform this operation to generate a bypass rule in one-click mode to handle the false alarm.
  • Handling False Positives Based on Client IP Addresses: If you are sure a client IP address is blocked mistakenly, you can add the IP address to an address group and add the IP address to a blacklist/whitelist rule to allow it.
  • : Export events.
    In the upper left corner of the event list, click Export to export events. If the number of events is less than 200, the events are exported to your local PC.
