Updated on 2026-09-01 GMT+08:00
Buying Cloud Mode WAF
If you plan to use cloud CNAME access or cloud load balancer access, you need to buy cloud mode WAF.
Before You Start
  • You can select only one billing mode for your WAF instance in an account.
  • You can switch between yearly/monthly and pay-per-use billing modes for your WAF. For details, see Can I Switch Between Yearly/Monthly and Pay-per-Use Payments for WAF?
  • If you cancel the subscription to your yearly/monthly cloud mode WAF or it expires, you can buy yearly/monthly or pay-per-use WAF again.
    • If you buy a pay-per-use WAF in the same project where your original WAF is deployed, the WAF configuration data will be retained.
    • If you buy a yearly/monthly WAF in the same region where your original WAF is deployed, the WAF configuration data will be retained.
  • You can disable pay-per-use billing mode and then buy yearly/monthly or pay-per-use WAF.
    After the pay-per-use billing mode is disabled, the WAF billing stops, the WAF configuration data is retained, and the protection status of the protected domain name changes to Unprotected. WAF forwards your website traffic without inspecting traffic.
Function
Constraint
Region
  • WAF supports protection for all regions. For details about supported regions, see In Which Regions Is WAF Available?
  • Only one edition can be selected in a larger geographical region using the same account. For example:
    • CN North-Beijing1 and CN North-Beijing4 share the same edition.
    • CN East-Shanghai1, CN East-Shanghai2, and CN Southwest-Guiyang1 share the same edition.
    • CN South-Guangzhou and CN South-Shenzhen share the same edition.
Non-standard ports
With professional or enterprise WAF, you can protect any non-standard ports for your website. To do so, submit a ticket to enable them first.
IAM users for logging in to the WAF console must have the WAF Administrator and BSS Administrator permissions. For details, see Creating a User Group and Granting Permissions.
Buying a Yearly/monthly Cloud WAF Instance
  1. Log in to the WAF console.
  2. Click Buy WAF.
  3. On the Buy Web Application Firewall page, complete the following configurations.
    Table 1 Parameters for purchasing yearly/monthly cloud mode WAF.
    Example Value
    Basic Settings
    WAF Mode
    WAF mode you want to buy. If you select Cloud Mode, you can use cloud CNAME access or cloud load balancer access to connect websites to WAF.
    Cloud Mode
    Billing Mode
    Billing mode of WAF.
    • Yearly/Monthly: a prepaid billing mode.
    • Pay-per-use: a postpaid billing mode.
    For details about billing modes, see WAF Billing Overview.
    Yearly/Monthly billing
    Region
    Region where the WAF instance will be deployed. Select a region from the Region drop-down list. Only one WAF edition can be purchased in a region.
    Generally, a WAF instance purchased in any region can protect web services in all regions. To make a WAF instance forward your website traffic faster, select the region nearest to your services.
    CN-Hong Kong
    Edition
    Edition
    Select Basic course. WAF provides many tiered specifications, including Starter, Standard, Professional, and Enterprise editions, ranking from low to high specifications.
    • For details service scale and function differences, see Edition Differences.
    • To use cloud load balancer access, you need to buy the standard, professional, or enterprise edition first.
      Cloud load balancer shares its domain name, QPS, and rule expansion package quotas with Cloud CNAME, and the service specifications are the same as those of the basic package for cloud mode you buy.
    Professional
    Expansion Packages
    You can buy domain name, bandwidth, and rule expansion packages to obtain extra quotas based on the basic package. For more details, see Expansion Packages (Optional).
    • Domain expansion packages: 1
    • Bandwidth expansion package: 1
    • Rule expansion packages: 1
    Final Specifications
    After you select Basic course, Advanced Functions, and Expansion Packages, WAF calculates the total number of selected quotas in real time.
    Usage Settings
    Required Duration
    Select the purchase duration. The duration ranges from one month to three years.
    1 year
    Auto-Renewal
    Whether to automatically renew the WAF service when it expires. If you enable this, WAF will automatically renew the subscription upon expiration based on the required duration you configure.
    Hover over View Billing Rules and Renewal Durations and click Learn More. For details, see Auto-Renewal Rules.
    Auto-renewal
  4. Confirm the product details and click Buy Now.
  5. On the Confirm Configuration page, confirm the order details, select I have read and agree to the WAF Disclaimer, and click Pay.
  6. On the payment page, select a payment method and complete the payment.
    After WAF is enabled, you can go to the WAF console. In the navigation pane on the left, choose Edition Management to view details about the purchased instance. For details, see Edition Management.
Buying Pay-per-Use Cloud Mode WAF
To buy pay-per-use WAF instances, submit a service ticket to enable the service.
  2. Click in the upper left corner and select a region or project.
  3. (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
  4. In the upper right corner of the page, click Buy WAF.
  5. On the Buy Web Application Firewall page, select Pay-per-use for Billing Mode and select a region.
    Figure 1 Pay-per-use
  1. In the lower right corner of the page, click Next.
  2. Click Back to Website Settings and add domain names of the target websites on the Access Management page.
    After WAF is enabled, choose Edition Management. In the Cloud Mode area, click Disable Pay-per-Use Billing to disable the pay-per-use billing.
    • If you want to check the WAF edition in use and when it will expire, choose Edition Management in the navigation pane on the left and view details. For details, see Edition Management.
    • If you no longer need WAF, click Disable Pay-Per-Use Billing next to the Cloud Mode column on the Edition Management page.
Follow-up Operations
  1. Connecting a Website to WAF: With cloud mode, you can use CNAME access and ELB load balancer access to connect a website to WAF over website domain names or IP addresses.
  2. Viewing Protection Events: After a domain name or IP address is connected to WAF, by default, WAF enables General Check in Basic Web Protection, with Protective Action set to Log only and Protection Level to medium, and enables Scanner in Anti-Crawler, with Protective Action set to Log only. You can view and handle protection events on the Events page.
  3. Configuring Protection Policies: If default protection rules cannot meet your website security requirements, you can configure custom protection rules.
Related Operations
