Updated on 2025-11-13 GMT+08:00
Editing Server Information
If you select Cloud Mode - CNAME or Dedicated Mode when adding a website to WAF, you can edit the server information of your website.
Applicable scenarios:
  • Edit server information.
    • Cloud Mode - CNAME access: You can modify configurations for Client Protocol, Server Protocol, Server Address, Weight, and Server Port.
    • Dedicated mode: You can modify configurations for Client Protocol, Server Protocol, Server Address, VPC, Weight, and Server Port.
  • Add server configurations.
  • Update a certificate by referring to Updating the Certificate Used for a Website.
If you have enabled enterprise projects, ensure that you have all operation permissions for the project where your WAF instance locates. Then, you can select the enterprise project from the Enterprise Project drop-down list and configure server information for the domain names.
  • If PCI DSS/3DS compliance check is enabled, the client protocol cannot be changed, and no origin server addresses can be added.
  • Server configuration information can be modified in batches only for domain names connected to WAF in the same access mode.
Impact on the System
Modifying the server configuration does not affect services.
Modifying Server Information of One Website
  1. Log in to the WAF console.
  2. Click in the upper left corner and select a region or project.
  3. (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
  4. In the navigation pane on the left, click Website Settings.
  5. On the Website Settings page, click the target website domain name.
  6. In the Origin Servers area, click Edit.
  7. In the Edit Server Information dialog box, edit the server configurations and associated certificates as needed.
    • For cloud mode CNAME access, a client protocol, origin server protocol, origin server address, origin server port, and weight are configured for a server. For more details, see Table 1.
    • For dedicated mode access, a client protocol, origin server protocol, dedicated engine VPC, origin server address, origin server port, and weight are configured for a server. For more details, see Table 1.
    • For details about certificate, see Updating the Certificate Used for a Website.
    • WAF supports configuring of multiple backend servers. To add a backend server, click Add.
    • You can click Enable in the IPv6 Protection row if needed.
  8. Click OK.
Batch Modifying Origin Server Information of Websites
Batch modifying origin server information is supported only for domain names connected to WAF in the same access mode.
  1. In the navigation pane on the left, choose Website Settings.
  2. Select domain names whose server configurations need to be modified. In the upper part of the website list, click Modify.
  3. Edit the server configurations and associated certificates as needed.
  4. Click OK.
    This action will take a while. Please be patient. After the modification is successful, the domain names with server information modified will be displayed.
Verification
After the server information is modified, it takes about two minutes for the modification to take effect.
