Updated on 2026-09-18 GMT+08:00
Unsupported VPC Peering Configurations
The VPC peering connection configurations are not supported in Table 1.
Table 1 Scenarios that VPC peering connections are invalid
Example
  • If VPCs with the same CIDR block also include subnets that overlap, VPC peering connections are not usable.
  • If two VPCs have overlapping CIDR blocks but some of their subnets do not overlap, you cannot create a VPC peering connection to connect specific subnets that do not overlap.
Invalid VPC Peering for Overlapping VPC CIDR Blocks
VPC peering connections cannot enable ECSs in their VPCs to share an EIP to access the Internet.
If VPC-A and VPC-B are peered and ECS-A01 in VPC-A has an EIP, ECS-B01 in VPC-B cannot access the Internet using the EIP bound to ECS-A01.
Invalid VPC Peering for Sharing an EIP
If two VPCs have overlapping CIDR blocks, the VPC peering connection may not take effect due to route conflicts. The following describes the reasons and configuration suggestions.
  • VPCs with the same CIDR block also include subnets that overlap.
    VPC peering connections are not usable. As shown in Figure 1, VPC-A and VPC-B, and their subnets have the same CIDR block. If you create a VPC peering connection between VPC-A and VPC-B, their route tables are shown in Table 2.
    In the rtb-VPC-A route table, the custom route for routing traffic from VPC-A to VPC-B and the local route have overlapping destinations. The local route has a higher priority and traffic will be forwarded within VPC-A and cannot reach VPC-B.
    Figure 1 Networking diagram (IPv4)
    Table 2 VPC route table details
    Route Table
    Destination
    Next Hop
    Route Type
    rtb-VPC-A
    10.0.0.0/24
    Local
    System
    Local routes are automatically added for communications within a VPC.
    10.0.1.0/24
    Local
    System
    10.0.0.0/16 (VPC-B)
    Peering-AB
    Custom
    Add a route with the CIDR block of VPC-B as the destination and Peering-AB as the next hop.
    rtb-VPC-B
    10.0.0.0/24
    Local
    System
    10.0.1.0/24
    Local
    System
    10.0.0.0/16 (VPC-A)
    Peering-AB
    Custom
    Add a route with the CIDR block of VPC-A as the destination and Peering-AB as the next hop.
    If two VPCs want to use their IPv6 CIDR blocks for communication by a VPC peering connection but the IPv4 CIDR blocks of the VPCs or subnets overlap, the connection is not usable.
    Figure 2 Networking diagram (IPv6)
  • Two VPCs have overlapping CIDR blocks but some of their subnets do not overlap.
    VPC peering connections will not take effect in the following scenarios:
    • Connecting overlapping CIDR blocks of VPCs
      As shown in Figure 3, if you create a VPC peering connection between VPC-A and VPC-B, the VPC peering connection will not take effect because the two VPCs have the same CIDR block.
    • Connecting overlapping subnets from different VPCs
      If you create a VPC peering connection between Subnet-A01 and Subnet-B02, the route tables are shown in Table 3. In the rtb-VPC-B route table, the custom route for routing traffic from Subnet-B02 to Subnet-A01 and the local route have overlapping destinations. The local route has a higher priority and traffic will be forwarded within Subnet-B02 and cannot reach Subnet-A01.
      Figure 3 Networking diagram (IPv4)
      Table 3 VPC route table details
      Route Table
      Destination
      Next Hop
      Route Type
      rtb-VPC-A
      10.0.0.0/24
      Local
      System
      10.0.1.0/24
      Local
      System
      10.0.2.0/24 (Subnet-B02)
      Peering-AB
      Custom
      Add a route with the CIDR block of Subnet-B02 as the destination and Peering-AB as the next hop.
      rtb-VPC-B
      10.0.0.0/24
      Local
      System
      10.0.2.0/24
      Local
      System
      10.0.0.0/24 (Subnet-A01)
      Peering-AB
      Custom
      Add a route with the CIDR block of Subnet-A01 as the destination and Peering-AB as the next hop.
    If the subnets connected by a VPC peering connection do not overlap, the connection will take effect. As shown in Figure 4, you can create a VPC peering connection between Subnet-A02 and Subnet-B02. In this case, the routes do not conflict and the VPC peering connection takes effect.
    Figure 4 Networking diagram (IPv4)
    Figure 5 Networking diagram (IPv6)
As shown in Figure 6, although VPC-A and VPC-B are peered and ECS-A01 in VPC-A has an EIP, ECS-B01 in VPC-B cannot access the Internet using the EIP bound to ECS-A01. If you want multiple resources to share an EIP, refer to Using NAT Gateway and VPC Peering to Enable Communication Between VPCs and Internet.
Figure 6 Networking diagram
