Obtaining the Peer Project ID of a VPC Peering Connection
If you create a VPC peering connection between two VPCs in different accounts, you can refer to this section to obtain the project ID of the region where the peer VPC resides.
The owner of the peer account logs in to the management console.
- Go to the VPC peering connection list page.
- In the upper right corner of the page, select My Credentials from the username drop-down list.
The My Credentials page is displayed.
Figure 1 My Credentials
- In the project list, obtain the project ID.
