Creating a Security Group
A security group consists of inbound and outbound rules to control the traffic that is allowed to flow into or out of instances (such as ECSs) in the security group. Security group rules are commonly used to allow or deny network traffic from specific sources or over specific protocols, block certain ports, and define specific access permissions for instances.
When creating an instance (for example, an ECS), you must associate it with a security group. If no security group has been created yet, a default security group will be created and associated with the instance. For details, see Default Security Groups. You can also create a security group and add inbound and outbound rules to allow specific traffic. For more information about security groups and rules, see Security Group and Security Group Rule Overview.
Preset Security Group Rules
When creating a security group, you can select a template. The templates have preset inbound and outbound rules. You can select one as needed to quickly create a security group. Table 1 describes the security group templates.
| Template | Direction | Protocol & Port & Type | Source or Destination | Description | Scenario |
| General-purpose web server | Inbound | TCP: 22 (IPv4) | 0.0.0.0/0 | Allows all IPv4 addresses to access instances in the security group over port 22 (SSH) for remotely logging in to Linux instances. |
| TCP: 3389 (IPv4) | 0.0.0.0/0 | Allows all IPv4 addresses to access instances in the security group over port 3389 (RDP) for remotely logging in to Windows instances. | |||
| TCP: 80 (IPv4) | 0.0.0.0/0 | Allows all IPv4 addresses to access instances in the security group over port 80 (HTTP) for visiting websites. | |||
| TCP: 443 (IPv4) | 0.0.0.0/0 | Allows all IPv4 addresses to access instances in the security group over port 443 (HTTPS) for visiting websites. | |||
| ICMP: All (IPv4) | 0.0.0.0/0 | Allows all IPv4 addresses to access instances in the security group over any port for using the ping command to test connectivity. | |||
| All (IPv4) All (IPv6) | Current security group | Allows the instances in the security group to communicate with each other over an internal network over any protocol. | |||
| Outbound | All (IPv4) All (IPv6) | 0.0.0.0/0 ::/0 | Allows all traffic from the instances in the security group to external resources over any protocol. | ||
| All ports open | Inbound | All (IPv4) All (IPv6) | Current security group | Allows the instances in the security group to communicate with each other over an internal network over any protocol. | This template allows any traffic to enter and leave the instances in the security group, which has security risks. |
| All (IPv4) All (IPv6) | 0.0.0.0/0 ::/0 | Allows any IP address to access the instances in the security group over any protocol. | |||
| Custom rule | Inbound | All (IPv4) All (IPv6) | Current security group | Allows the instances in the security group to communicate with each other over an internal network over any protocol. | The preset rule does not open any port in the inbound direction. That is, no external traffic can enter the instances in the security group. You can add security group rules as required. |
- Go to the security group list page.
- In the upper right corner, click Create Security Group.
The Create Security Group page is displayed.
- Configure the parameters as prompted. Figure 1 Creating a security group
Table 2 Parameter description Parameter
Example Value
Region
Mandatory
Regions are geographic areas isolated from each other. Resources are region-specific and cannot be used across regions through internal network connections. For low network latency and quick resource access, select the nearest region.
An instance must be in the same region as its associated security group.
CN-Hong Kong
Name
Mandatory
The name of the security group. The name:- Can contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
NOTE:You can change the security group name after a security group is created. It is recommended that you give each security group a different name.
sg-AB
Enterprise Project
Mandatory
When creating a security group, you can add the security group to an enabled enterprise project.
An enterprise project facilitates project-level management and grouping of cloud resources and users. The name of the default project is default.
For details about creating and managing enterprise projects, see the Enterprise Management User Guide.
default
Tag
Tag (Optional)
You can add tags to the security group. Tags help you to identify, classify, and search for your security groups.
For details, see Managing Security Group Tags.
Tag key: test
Tag value: 01
Description (Optional)
Optional
Supplementary information about the security group.
The description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
N/A
Template
Mandatory
For details about preset security group rules and their application scenarios, see Table 1.
- Check the preset rules and do the following as required:
- Add rules.
- Replicate rules.
- Modify rules.
- Delete rules.
- For details about inbound rule parameters, see Table 2. For details about outbound rule parameters, see Table 3.
- On the page for creating a security group, an inbound rule that uses the current security group as the source cannot be modified. Deleting such a rule prevents instances in the security group from communicating with each other.
- On the page for creating a security group, an outbound rule that uses 0.0.0.0/0 or ::/0 as the destination cannot be modified. Deleting such a rule prevents instances in the security group from accessing the external network.
- Click Create Now.
Follow-Up Operations
Each cloud server must be associated with at least one security group. You can add a cloud server to multiple security groups based on service requirements. For details, see Adding an Instance to or Removing an Instance from a Security Group.
