Media Content Review
Huawei Cloud VOD provides the content review function to detect and filter out pornographic, terrorism-related, and politically sensitive information in media files. In doing so, inappropriate media files can be removed in a timely manner to avoid or reduce the adverse impact.
Notes
This function is not available in AP-Bangkok.
Review Process
VOD provides two review methods, review after upload and review before upload. Review after upload is available on the VOD console. It means, you upload audio and video and then review the content. If you want to use review before upload, call a VOD API.
- Intelligent review: The review module identifies pornographic, terrorism-related, and politically sensitive content in text, thumbnails, and snapshots. By default, this function is disabled.
- Manual review: In review details, check the suspected non-compliant media file again. If you confirm the problem, block the media file. Otherwise, approve it.
- Block: After you block a media file, its status changes to Unpublished. Media files in the Unpublished status can only be previewed on the console and cannot be downloaded or played. The streaming URL referenced by Internet is inaccessible.
By default, a system template is used for review. If you need to use a custom template, create a review template and set it as the default template.
Video Content Review
Intelligent review checks the thumbnail, title, description, and content of a video file.
- Log in to the VOD console.
- In the navigation pane, choose Review Management > Content Moderation.
- Select a video file and click Review. The video review is based on its configured default review template. You can edit the review template on the Review Settings page.
If the video status changed to Approved, Pending review, or Rejected, intelligent review is complete.
- Determine whether to start manual review.
You can start manual review in either of the following ways:
- Click
on the left of the video. A maximum of 10 video snapshots are displayed. The system marks non-compliant snapshots. You can re-check the marked snapshots.
- If snapshots are just part of a video and you need to re-check the whole video, click View Details.
On the displayed page, snapshots containing pornographic, terrorism-related, or politically sensitive content are marked and texts containing such content are highlighted red. In the preview area, you can play the video for stricter review.
- Click
- Go back to the audio and video list and select multiple video files to approve or block them in batches.
Audio Content Review
Intelligent review checks the thumbnail, title, and description of an audio file.
- Select an audio file and click Review. The audio review is based on its configured default review template. You can edit the review template on the Review Settings page.
If the audio status changed to Approved, Pending review, or Rejected, intelligent review is complete.
- Click View Details to view review details.
On the displayed page, the thumbnail containing pornographic, terrorism-related, or politically sensitive content is marked and texts containing such content are highlighted red. You can block or approve the audio based on your re-check results.
- Go back to the audio and video list and select multiple audio files to approve or block them in batches.
