Help Center/
Database and Application Migration UGO/
User Guide/
Database Evaluation/
Resuming a Stopped Project
Updated on 2024-05-28 GMT+08:00
- Project Status of an evaluation project is Stopped.
- Frozen accounts cannot resume a stopped project.
- Log in to the UGO console.
- In the navigation pane on the left, choose .
- In the evaluation project list, locate the project whose Project Status is Stopped and click Resume in the Operation column.
Figure 1 Resuming an evaluation task
- To use the current settings, click OK.
- (Optional) To modify the current settings, click Edit. Then, configure DB Connection Timeout and Data Collection, and click OK.
Figure 2 Editing settings
- DB Connection Timeout: specifies the time limit within which the system attempts to connect to the database, in millisecond. Value: 30000 to 1800000.
- Skip Collection Timeout Object
- Select this option: If the database connection times out, the system skips some objects and records the objects that failed to be collected, and continues to create an evaluation project.
- Deselect this option: If the database connection times out, the evaluation project creation will be stopped. You need to change the database connection timeout and resume the creation of the project.
Parent topic: Database Evaluation
