- What's New
- Function Overview
- Getting Started
User Guide
- Working with CodeArts TestPlan
- Enabling CodeArts TestPlan
- Accessing CodeArts TestPlan Homepage
- Configuring a Test Plan
- Configuring a Test Version
Configuring a Test Case
- Generating a Test Case
- Creating a Test Case by Using Mind Map
- Creating a Manual Test Case
Creating an Automated API Test Case
- Using Automated API Test Cases
- Creating an Automated API Test Case Template
- Adding an API Test Script by Using a Custom URL Request
- Adding an API Script by Importing a Postman File
- Adding an API Script by cURL
- Adding an API Script by Keyword Library
- Adding Logic Control to an API Script
- Setting Test Case Parameters of an API Script
- Setting Environment Parameters of an API Script
- Importing an Automated API Test Case Dataset
Built-in Functions
- Binary Addition Function
- Binary Subtraction Function
- Binary Multiplication Operation
- Binary Division Operation
- Obtaining the Current Timestamp
- Obtaining a Specified Timestamp
- Converting a Date into a Timestamp
- Converting a Timestamp into a Date
- Timestamp Addition and Subtraction Operations
- Generating Base64 Encoding
- Generating SHA512 Encoding
- Generating SHA256 Encoding
- Generating an MD5 Hash Value
- Generating a Random Number in a Specified Range
- Generating a Random String of a Specified Length
- Generating a Random Decimal in a Specified Range
- Generating a UUID
- Obtaining an Array via Reverse Index
- Obtaining the Element Values of an Array via Reverse Index
- Converting Uppercase Letters into Lowercase Letters
- Converting Lowercase Letters into Uppercase Letters
- Concatenating Strings
- Cutting Strings
- Obtaining String Length
System Keywords
- Overview
- GetIAMToken
- MySQLQuery
- MySQLUpdate
- MySQLInsert
- MySQLDelete
- OpenGaussQuery
- OpenGaussUpdate
- OpenGaussInsert
- OpenGaussDelete
- PostgreSQLQuery
- PostgreSQLUpdate
- PostgreSQLInsert
- PostgreSQLDelete
- MongoDBQuery
- MongoDBInsert
- MongoDBUpdate
- MongoDBDelete
- RedisGet
- RedisSet
- OBSWrite
- OBSDelete
- OBSQuery
- KafkaProducer
- KafkaConsumer
- TCP
- UDP
- WSConnect
- WSRequest
- WSWriteOnly
- WSReadOnly
- WSDisConnect
- DubboClient
- Executing a Test Case
- Managing Test Cases
- Creating and Executing a Test Suite
- Viewing and Evaluating Test Quality
- Settings
- API Reference
- Best Practices
- What Do I Do If No Test Case Exists in a Test Suite?
- What Can I Do If I Do Not Have the Operation Permission?
- Why Am I See a Message Indicating that an API Automation Test Suite Is Being Executed or Queuing?
- What Do I Do If a Test Suite Does Not Exist?
- Why Can't I Download the Document in a Manual Test Case?
- What Do I Do If No Test Case Exists In a Test Plan
- Why Can't I Add Work Items of the Task Type When a Test Plan Is Created or Updated?
- What Do I Do If Test Cases Cannot Be Associated with Work Items of the Task Type?
- What Do I Do If the Test Case Completion Rate in the Test Report Is Lower Than 100%?
- Why Is the Status of Test Cases in a Test Plan Inconsistent with That in a Test Case Library?
- How Are Variables Passed Between Steps in API Automation Cases?
- How Do I Set Checkpoints for Test Procedures in API Automation Cases?
- Videos
On this page
Show all
