Viewing the Replication Latency and Traffic of a RegionlessDB Cluster
After a RegionlessDB cluster is created, you can monitor the database status and performance based on related metrics.
- Click
in the upper left corner and select the region and project of the primary instance. - Click
and select Cloud Eye under Management & Governance. - In the navigation pane, choose Cloud Service Monitoring > TaurusDB.
- Click
in the front of a RegionlessDB cluster. Locate a standby instance and click View Metrics in the Operation column.
- You can view the performance metrics in the last 1 hour, last 3 hours, last 12 hours, last 1 day, or last 7 days.
Figure 1 Viewing RegionlessDB metrics
- For details about metrics supported by RegionlessDB clusters, see Table 1. For details about the metrics of primary and standby instances, see TaurusDB Metrics.
Table 1 RegionlessDB cluster metrics Metric ID
Metric Name
Value Range
Monitored Object
Monitoring Interval (Raw Data)
gdb_replication_latency
GDB Replication Delay
Data replication latency of the measured object
≥0 ms
Standby instances in a RegionlessDB cluster
1 minute
gdb_replication_capacity
GDB Replication Traffic
Data replication traffic of the measured object
≥0 bytes/s
1 minute
Use a MySQL client tool to connect to the TaurusDB instance and run the following command to query the RegionlessDB status:
mysql> select * from information_schema.global_db_status;
In the command output, each row indicates an instance in the RegionlessDB cluster (the first row indicates the primary instance and other rows indicate the standby instances). For details about the parameters contained in each row, see Table 2.
Parameter |
Description |
HW_REGION |
Region code of the standby instance. The first row in the table is the primary instance, and the region code of the primary instance is an empty string. |
IS_PRIMARY |
Whether the instance is the primary instance. true: it is the primary instance. false: It is the standby instance. |
MAX_PERSIST_LSN |
Maximum LSN of the current redo logs of the instance that have been persisted to the shared storage. |
REPLICATION_LAG_IN_MILLISECONDS |
Latency from the time when data is written to the primary instance to the time when data can be read from the standby instance, in ms. The replication latency of the primary instance is 0. |
REPLICATION_CAPACITY_IN_MB |
Throughput of data replication from the primary instance to a standby instance, in MB/s. The replication throughput of the primary instance is 0. |
