Updated on 2026-06-04 GMT+08:00
Enabling ALT
This section describes how to enable ALT.
- The TaurusDB instance's kernel version must be 2.0.54.240600 or later, and the proxy instance's kernel version must be 2.24.06.000 or later. For details about how to check the kernel version, see How Can I Check the Version of a TaurusDB Instance?
- When you enable ALT for the first time, the TaurusDB instance will reboot. Enabling or disabling ALT will cause a proxy instance to reboot. Once ALT is disabled for all proxy instances, the TaurusDB instance will also reboot. Rebooting an instance will clear its cache. To prevent traffic congestion during peak hours, you are advised to reboot it during off-peak hours.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, click the name of the target TaurusDB instance.
- In the navigation pane, choose Database Proxy.
- Click a proxy instance to go to its Basic Information page.
- In the Proxy Instance Information area, click
under ALT. - In the displayed dialog box, click OK. Figure 1 Enabling ALT
To disable ALT, click
. Disabling ALT will cause the proxy instance to reboot. Once ALT is disabled for all proxy instances, the TaurusDB instance will also reboot. - On the Basic Information page of the proxy instance, check that the proxy instance status changes from ALT is being configured to Available.
- To keep read workloads as uninterrupted as possible during read replica changes, toggle on the switch
next to Read Replica ALT. In the displayed dialog box, click OK. Figure 2 Enabling read replica ALT
