Help Center/ TaurusDB/ User Guide/ Database Proxy (Read/Write Splitting)/ Changing Configurations of a Proxy Instance/ Changing the Port of a Proxy Instance
Updated on 2026-07-16 GMT+08:00
You can change the port for a proxy instance.
- Changing the port of a proxy instance will interrupt the database connection. You are advised to change the port during off-peak hours.
- Changing the port of a proxy instance does not reboot the proxy instance.
- Only the port of the current proxy instance will be changed.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region. - On the Instances page, click the instance name.
- In the navigation pane, choose Database Proxy.
- Click the name of a proxy instance.
- On the Basic Information page, click
under Proxy Port. Proxy port range: 1025 to 65534 (except for 1033, 5342, 5343, 5344, 5345, 12017, 20000, 20201, 20202, 33060, 33062, and 33071, which are reserved by the system)
- Click
to submit the change.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
