Help Center/ TaurusDB/ User Guide/ Database Proxy (Read/Write Splitting)/ Changing Configurations of a Proxy Instance/ Changing the Number of Nodes for a Proxy Instance
Updated on 2025-12-31 GMT+08:00
You can change the number of proxy instance nodes as required.
- Your TaurusDB instance must be available.
- If a proxy instance is abnormal, you can only add nodes to it but cannot reduce nodes.
- The number of proxy nodes ranges from 2 to 16.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, click the instance name to go to the Basic Information page.
- In the navigation pane, choose Database Proxy. Click the name of a proxy instance.
- In the Proxy Instance Information area, click Change under Proxy Instance Nodes.
- In the displayed dialog box, set the number of proxy instance nodes and click OK. Number of recommended proxy instance nodes = (Number of vCPUs of the primary node + Total number of vCPUs of all read replicas)/(4 x Number of vCPUs of the proxy instance), rounded up.Figure 1 Changing the number of proxy nodes
- After several minutes, check that the proxy instance status changes from Adding nodes to Available.
