Updated on 2026-04-20 GMT+08:00
Deleting a Proxy Instance
You can delete a proxy instance as required.
If a proxy instance is deleted, read/write splitting is disabled and workloads using the proxy address are interrupted. You need to connect your applications to the TaurusDB instance address.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Instances page, click the instance name.
  4. In the navigation pane, choose Database Proxy.
  5. Locate a proxy instance and choose More > Delete in the Operation column.
    Figure 1 Deleting a proxy instance
  6. In the displayed dialog box, enter DELETE and click OK.
    Figure 2 Deleting a proxy instance
  7. Check the task progress on the Task Center page and refresh the Basic Information page of the proxy instance later. If the TaurusDB instance status becomes Available, the proxy instance is deleted successfully.
