Resetting a Parameter Template
You can reset all parameters in a custom parameter template to their default settings.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Parameter Templates page, click Custom Templates. Locate the parameter template to be reset and choose More > Reset in the Operation column.
- Click OK to reset all parameters to their default values.
Figure 1 Confirming the reset
After you reset a parameter template, view the status of the instance to which the parameter template applies in the instance list. If the status is Parameter change. Pending reboot, you must reboot the instance.
