Updated on 2026-02-02 GMT+08:00
Configuring Security Group Rules
A security group is a collection of access control rules for ECSs and TaurusDB instances that are within the same VPC, have the same security requirements, and are mutually trusted. To ensure database security and reliability, you need to configure security group rules to allow only specific IP addresses and ports to access the TaurusDB instances.
When you attempt to connect to a TaurusDB instance through a private network, check whether the ECS and TaurusDB instance are in the same security group.
  • If they are in the same security group, they can communicate with each other by default. No security group rules need to be configured.
  • If they are in different security groups, you need to configure security group rules for the ECS and TaurusDB instance, respectively.
    • TaurusDB instance: Configure an inbound rule for the security group that the TaurusDB instance is associated with.
    • ECS: The default security group rule allows all outbound data packets. In this case, you do not need to configure a security group rule for the ECS. If not all outbound data packets are allowed in the security group, you need to configure an outbound rule for the ECS.
This section describes how to configure an inbound rule for a TaurusDB instance.
For details about the requirements of security group rules, see Adding a Security Group Rule in Virtual Private Cloud User Guide.
You have associated a security group with an instance when buying it.
Precautions
The default security group rule allows all outbound data packets. This means that ECSs and TaurusDB instances associated with the same security group can access each other by default. After a security group is created, you can configure security group rules to control access to and from TaurusDB instances associated with that security group.
  • By default, you can create up to 500 security group rules.
  • Too many security group rules will increase the first packet latency. You are advised to create up to 50 rules for each security group.
  • One instance can be associated with only one security group.
  • To access a TaurusDB instance from resources outside the security group, you need to configure an inbound rule for the security group associated with the instance.
To ensure data and instance security, use permissions properly. You are advised to use the minimum access permission, change the default database port 3306, and set the accessible IP address to the remote server's address or the remote server's minimum subnet address to control the access scope of the remote server.
The default value of Source is 0.0.0.0/0, indicating that all IP addresses can access the TaurusDB instance as long as they are associated with the same security group as the instance.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Instances page, click the instance name to go to the Basic Information page.
  4. Configure security group rules.
    In the Network Information area, click the security group name under Security Group.
    Figure 1 Configuring security group rules
  5. On the Inbound Rules tab, click Add Rule. In the displayed dialog box, set required parameters and click OK.
    You can click to add more inbound rules.
    Figure 2 Adding inbound rules
    Table 1 Inbound rule parameter description
    Example Value
    Protocol & Port
    Network protocol for which the security group rule takes effect.
    • Currently, the value can be All, TCP (All ports), TCP (Custom ports), UDP (All ports), UDP (Custom ports), ICMP, GRE, or others.
    • All: indicates all protocol ports are supported.
    TCP (Custom ports)
    Port: the port over which the traffic can reach your DB instance.
    When connecting to the instance through a private network, enter the port of the instance.
    • Individual port: Enter a port, such as 22.
    • Consecutive ports: Enter a port range, such as 22-30.
    • All ports: Leave it empty or enter 1-65535.
    Type
    Currently, only IPv4 and IPv6 are supported.
    IPv4
    Source
    Source of the security group rule. The value can be a security group or an IP address.
    xxx.xxx.xxx.xxx/32 (IPv4 address)
    xxx.xxx.xxx.0/24 (subnet)
    0.0.0.0/0 (any IP address)
    0.0.0.0/0
    Supplementary information about the security group rule. This parameter is optional.
    The description can contain a maximum of 255 characters and cannot contain angle brackets (<>).
    Operation
    You can replicate or delete a security group rule. However, if there is only one security group rule, you cannot delete it.
  6. If you have enabled operation protection, click Send Code in the displayed Identity Verification dialog box and enter the obtained verification code. Then, click OK.
    Two-factor authentication improves the security of your account. For details about how to enable operation protection, see Identity and Access Management User Guide.
