Migrating Data to TaurusDB Using the Export and Import Functions of DAS
Data Admin Service (DAS) is a one-stop management platform that allows you to manage Huawei Cloud databases on a web console. It offers database development, O&M, and intelligent diagnosis, making it easy to use and maintain databases.
During data backup or migration, DAS can help you export data to a local PC or OBS bucket, and import the data to the target data table. DAS allows you to export an entire database, some data tables, or SQL result sets.
- The file to be imported should be no larger than 1 GB.
- Only data files in .sql, .csv, or .xlsx format can be imported.
- If data files are exported as a .zip package, they cannot be directly imported. You need to extract the files first.
- Binary fields cannot be imported, including BINARY, VARBINARY, TINYBLOB, BLOB, MEDIUMBLOB, and LONGBLOB.
- Data cannot be exported from or imported to cross-region OBS buckets.
Exporting Data
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region. - On the Instances page, locate an instance and click Log In in the Operation column.
- On the displayed DAS login page, enter the username and password and click Log In.
- On the top menu bar, choose Import and Export > Export.
- Export an entire database.
Method 1: Use the quick export function.
- Click Quick Export and select the database to be exported.
- In the displayed dialog box, select a storage path and click OK.
- DAS does not store any data. The exported data files are stored in the OBS bucket that you have created.
- Creating an OBS bucket is free, but you will be billed for storing files in the bucket.
Method 2: Create an export task.
- Click .
- In the displayed dialog box, configure task information.
Table 1 Parameter description Category
Basic Information
Database
Select the database to be exported and select Export all tables.
- You can also select Export from standby database as required. If this option is selected, DAS connects to your standby database to export data. This prevents the primary database from being affected by data export. However, if the standby database has a high replication delay, the exported data may not be the latest.
- Databases are classified into user databases and system databases. System databases cannot be exported. If system database data is required, deploy system database services in a user database, so that you can export the system database data from the user database.
Allowed Rows
Select the maximum number of rows in a single table.
File Type
Select SQL, CSV, or EXCEL.
Object to Export
Select Data, Structure, or Data and structure.
Charset
Select UTF8 or GBK.
Select an OBS bucket for storing data files.
Options
- Combine INSERT statements.
If you select this option, INSERT statements will be combined into files, with each file smaller than 5 MB.
- Generate a file for each table.
If you do not select this option, all data files will be exported as a .zip package, which cannot be directly imported. You need to extract the package first.
If you select this option, the data file (in .sql, .csv, or .xlsx format) of each table will be exported and can be directly imported again.
Remarks
Enter remarks as required.
Advanced Settings
You can configure advanced options as required.
- Click OK.
- Click
- Click .
Table 2 Parameter description Category
Basic Information
Database
Select the database to be exported and select the tables to be exported in the Tables area on the right.
Allowed Rows
File Type
Object to Export
Charset
Select UTF8 or GBK.
Options
Remarks
Advanced Settings
- Click OK.
- Click
- Click .
Table 3 Parameter description Category
Basic Information
Database
Select the database to be exported.
Allowed Rows
File Type
Select SQL-Insert, CSV, or EXCEL.
Charset
Select UTF8 or GBK.
Options
- Generate one file for each result.
If you select this option, the data file (in .sql, .csv, or .xlsx format) of each result set will be exported and can be directly imported again.
SQL to Execute
Enter a SQL statement.
To export multiple SQL result sets at once, enter multiple SQL statements, with each on a separate line and ending with a semicolon (;). After the export task is complete, SQL files are generated. One SQL statement corresponds to one file.
Remarks
Advanced Settings
- Click OK.
Importing Data
- Click
- On the top menu bar, choose Import and Export > Import.
- Click Create Task.
Table 4 Parameter description Parameter
Import Type
Set this parameter based on the type of an exported file. Currently, only SQL and CSV files are supported.
File Source
Import a file from your local PC or an OBS bucket.
- Upload file
If you select Upload file for File Source, you need to set Attachment Storage and upload the required file.
To keep your data secure, provide your own OBS bucket to store the attachments you upload. In this way, DAS automatically connects to your OBS bucket for in-memory reading. No data is stored on DAS.
Select an OBS bucket to store the file. Click Bucket ACL Info to check whether a public OBS bucket is selected.
- SAFE: The bucket ACL permission set does not contain ALL USERS.
- WARN: The bucket ACL permission set contains ALL USERS.
- UNKNOWN: The bucket ACL permission set is unknown, maybe due to the lack of IAM permissions. You are advised to go to the OBS page to view the bucket ACL configuration.
If you select Delete the uploaded file upon an import success, the file you uploaded will be automatically deleted from the OBS bucket after being imported to the destination database.
- Choose from OBS
If you select Choose from OBS for File Source, you need to select a file from the bucket.
The file uploaded from an OBS bucket will not be deleted upon an import success.
Database
Select the destination database.
Charset
Select UTF8, GBK, or Auto Detect.
Options
If you select Ignore errors, that is, skip the step where the SQL statement fails to be executed, the system will skip any errors detected when SQL statements are being executed.
Remarks
- Upload file
- Click Create.
- In the displayed dialog box, confirm the information and click OK.
- After the data is imported successfully, log in to the destination database to query the imported data.
