Data Type Mappings Between Standard HTAP Instances and TaurusDB Instances
Standard HTAP instances support the native syntax of StarRocks. Character string comparison and the names of databases, tables, views, users, and roles are case sensitive, but the names of columns and partitions are case insensitive. For details, see StarRocks' official documentation.
When data of TaurusDB instances is synchronized to HTAP instances, the data types will be converted. For details, see Table 1.
| Data Type | TaurusDB Instance Data Type | HTAP Instance Data Type |
| NUMERIC TYPES | TINYINT | TINYINT |
| TINYINT UNSIGNED | SMALLINT CAUTION: Unsigned integers in TaurusDB are converted to a larger integer type for storage. When an integer is converted to an unsigned integer, ensure that no negative number exists in historical data. | |
| SMALLINT | SMALLINT | |
| SMALLINT UNSIGNED | INT | |
| MEDIUMINT | INT | |
| INTEGER/INT | INT | |
| INTEGER/INT UNSIGNED | BIGINT | |
| BIGINT | BIGINT | |
| BIGINT UNSIGNED | LARGEINT | |
| DECIMAL/NUMERIC | DECIMAL NOTE: If the precision of DECIMAL is greater than 64, the DECIMAL data type of TaurusDB instances will be converted to VARCHAR when being synchronized to HTAP instances. | |
| FLOAT | FLOAT | |
| DOUBLE/REAL | DOUBLE | |
| BIT | BIT | |
| DATE TIME | DATE | DATE |
| DATETIME | DATETIME | |
| TIMESTAMP | DATETIME | |
| TIME | VARCHAR | |
| YEAR | INT | |
| STRING | CHAR | CHAR/VARCHAR |
| VARCHAR | VARCHAR | |
| BINARY | VARBINARY | |
| VARBINARY | VARBINARY | |
| BLOB | VARBINARY | |
| TEXT | TEXT | |
| ENUM | VARCHAR CAUTION: 1. When the ENUM and SET types are used, set the binlog_row_metadata parameter of TaurusDB instances to FULL. 2. Use the case-sensitive character string format during query. | |
| SET | VARCHAR | |
| SPATIAL | GEOMETRY | Not supported |
| POINT | Not supported | |
| LINESTRING | Not supported | |
| POLYGON | Not supported | |
| MULTIPOINT | Not supported | |
| MULTILINESTRING | Not supported | |
| MULTIPOLYGON | Not supported | |
| GEOMETRYCOLLECTION | Not supported | |
| JSON | JSON | JSON |
