Help Center/ TaurusDB/ User Guide/ Instance Management/ Configuration Changes/ Enabling or Disabling Event Scheduler
Updated on 2025-12-04 GMT+08:00
You can enable or disable event scheduler on the TaurusDB console. Read Disclaimer carefully before using it.
Disclaimer
Normal product functions on Huawei Cloud can meet the daily needs of most customers. For trigger-related functions, you are advised to implement them on the business program side. If you do need to enable event scheduler, be aware of the following issues due to known community risks:
  • The actual time for triggering the event scheduler is inconsistent with the configured time.
  • The event scheduler is not triggered.
  • Due to the particularity of the event scheduler, the actual execution may be different from what you expected.
  • The event scheduler may impact analysis and judgment for issues with database usage.
  • Heterogeneous disaster recovery cannot be used.
  • Other unknown issues.
If any of these issues occur, your workloads may be affected.
When the instance is being rebooted or its specifications are being changed, event scheduler cannot be enabled or disabled.
  1. Log in to the TaurusDB console.
  2. On the Instances page, click the instance name to go to the Basic Information page.
  3. Expand Instance Information. In the Configuration area, click under Event Scheduler.
    Figure 1 Enabling event scheduler
  4. In the displayed dialog box, read the disclaimer and click Agree and Continue.
    Figure 2 Reading the disclaimer
  5. In the displayed dialog box, confirm the instance information and click OK.
    Figure 3 Confirming information
  6. On the Basic Information page, expand Instance Information and check that the event scheduler status becomes .
    Figure 4 Disabling event scheduler
  4. In the displayed dialog box, click OK.
    Figure 5 Confirming information
  5. On the Basic Information page, expand Instance Information and check that the event scheduler status becomes .
