Help Center/ TaurusDB/ User Guide/ Metrics and Alarms/ Event Monitoring/ Creating Alarm Rules for Event Monitoring
Updated on 2025-12-16 GMT+08:00
If you need to focus on core events, you can create alarm rules and alarm notifications for specified events. This way, you get timely alerts and can quickly troubleshoot or switch services. This section describes how to create an alarm rule to monitor an event.
  1. Log in to the Cloud Eye console.
  2. In the navigation pane, choose Event Monitoring.
  3. On the event list page, click Create Alarm Rule in the upper right corner.
  4. On the displayed page, set parameters as needed.
    Table 1 Parameter description
    Name
    Specifies the name of the alarm rule. The system generates a random name, but you can change it if needed.
    (Optional) Provides supplementary information about the alarm rule.
    Enterprise Project
    You can select an existing enterprise project or click Create Enterprise Project to create an enterprise project.
    Alarm Type
    Specifies the alarm type corresponding to the alarm rule.
    Event Type
    Specifies the event type of the metric corresponding to the alarm rule.
    Event Source
    Specifies the service the event is generated for.
    Example value: TaurusDB
    Monitoring Scope
    Specifies the monitoring scope for event monitoring.
    Method
    Specifies the event creation method.
    Alarm Policy
    Events indicate the instantaneous operations users performed on system resources, such as login and logout.
    For details about events supported by Event Monitoring, see Events Supported by Event Monitoring.
    You can select a trigger mode and alarm severity as needed.
    Click to enable alarm notification. The validity period is 24 hours by default. If the topics you require are not displayed in the drop-down list, click Create an SMN topic.
    Table 2 Alarm notification parameters
    Alarm Notification
    Specifies whether to notify users when alarms are triggered. Notifications can be sent by email or text message, or through HTTP/HTTPS request to servers.
    Notification Object
    Specifies the object an alarm notification is to be sent to. You can select the account contact or a topic.
    • Account contact is the mobile phone number and email address of the registered account.
    • Topic is used to publish messages and subscribe to notifications. If the required topic is unavailable, create one first and add subscriptions to it.
      For details, see Creating a Topic and Adding Subscriptions.
    Validity Period
    Cloud Eye sends notifications only within the validity period specified in the alarm rule.
    If you set Validity Period to 08:00-20:00, Cloud Eye sends notifications only within 08:00-20:00.
    Trigger Condition
    Specifies the condition for triggering the alarm notification.
  5. After the configuration is complete, click Create.
