Deleting a Read Replica
You can delete read replicas billed on a pay-per-use or serverless basis on the Basic Information page.
- Deleted read replicas cannot be recovered. Exercise caution when performing this operation.
- You can only delete a read replica when the instance has two or more read replicas. At least one read replica must be retained in the instance.
- If another operation is being performed on the instance, its read replicas cannot be manually deleted.
- For multi-AZ deployment, make sure that the primary node and remaining read replicas are located in different AZs after a read replica is deleted.
If a primary node and a read replica are deployed in AZ1 and the other read replica is deployed in AZ2, the read replica in AZ2 cannot be deleted.
- Before deleting the last serverless read replica, ensure that the function for adjusting the number of serverless read replicas has been disabled.
Billing
Deleted pay-per-use or serverless read replicas are no longer billed.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region. - On the Instances page, click the instance name to go to the Basic Information page.
- In the Node List area, locate the read replica to be deleted and choose More > Delete in the Operation column.
- In the displayed dialog box, click Yes. Refresh the Instances page later to confirm that the deletion has completed.
- If you have enabled operation protection, click Send Code in the displayed Identity Verification dialog box and enter the obtained verification code. Then, click OK.
Two-factor authentication improves the security of your account. For details about how to enable operation protection, see Identity and Access Management User Guide.
