Creating a Custom Parameter Template
You can create custom parameter templates and apply them to one or more DB instances.
There are default parameter templates and custom parameter templates.
You can use database parameter templates to manage DB engine configurations. A database parameter template acts as a container for engine configuration values that can be applied to one or more instances.
If you create a DB instance without specifying a custom parameter template, the system applies a default one to the instance. Each default parameter template contains DB engine defaults and system defaults that are configured based on the engine, compute class, and storage space allocated of an instance. Parameter values in the default template cannot be changed, but you can create a custom template with whatever values you require. If you want to use a custom parameter template, you simply create a parameter template and select it when you create a DB instance or apply it to an existing DB instance by following the instructions provided in Applying a Parameter Template.
When you have already created a parameter template and want to include most of the custom parameters and values from that template in a new parameter template, you can replicate that parameter template by following the instructions provided in Replicating a Parameter Template.
Precautions
- Each user can create a maximum of 100 parameter templates.
- All TaurusDB engines share the parameter template quotas.
- After you modify a parameter in the current instance's parameter template and save the change, it applies only to that instance and does not affect other instances.
- Changes to parameter values in a custom parameter template are not applied to your instance until you apply the template to the instance. For details, see Applying a Parameter Template.
- Inappropriate parameter settings may have unintended consequences, including reduced performance and system instability. Exercise caution when modifying database parameters. Always back up your data first. Before applying parameter template changes to a production DB instance, you should try out these changes on a test DB instance.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - In the navigation pane, choose Parameter Templates. On the Parameter Templates page, click Create Parameter Template.
- In the displayed dialog box, set required parameters and click OK. Figure 1 Creating a parameter template
Table 1 Parameter description Parameter
DB Engine Version
Select TaurusDB V2.0.
New Parameter Template
The template name consists of 1 to 64 characters. Only letters (case-sensitive), digits, hyphens (-), underscores (_), and periods (.) are allowed.
The description consists of up to 256 characters. It cannot contain carriage returns or any of the following special characters: >!<"&'=
- Check that the custom template is displayed on the Custom Templates tab.
